Question about LG WFT1071TP Top Load Washer
DRAIN IS NOT WORKING OR FUNCTIONING. HOW CAN i FIX IT?
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 04, 2011
Washing machine did not drain, other functions work properly
Check drain hose first. If ok, possibly belt is shot or pump loosened up to cause slippage. Depending upon design, front of washer removes to view pump. Visually check first and then start washer in drain cycle to observe if pump turns. Belt or pump is simple fix.
May 19, 2014 | Dryers
Spinner is not working E3 error appear
You may have to check your motor brushes; if worn out your spin will not function properly. Go to youtube with your model, make,etc; it is a very easy fix. Hope your filter is clean and your wall drain is not blocked.
Pl click if helped.
Apr 25, 2013 | Washing Machines
Will not drain
Everyone expects their dishwasher will work correctly. They can become nonchalant about it until one day it does not function. Sometimes the dishwasher doesn't drain as expected. Most people immediately call the plumber when their dishwasher doesn't work. There are several things you can try at home before having to pay an expensive service fee.
Instructions below.
  • Basic Tools,Rags
  1. Check the basics. Make sure that the dishwasher has actually finish the cycle. Your dishwasher will not drain until the end of the cycle. Many things may have interrupted the cycle. Check circuit breaker and reset it if appropriate. Also check the fuse. It is possible that you could have tripped a circuit have way through the cycle. Make sure the door is properly closed. Ensure you have chosen a cycle on the dishwasher. It is amazing the problems children could accidentally cause, that are easy fixes.
  2. Remove any excess food at the bottom of the dishwasher. The best way to do this is with your hands. Large food particles can block from going into the drain.This is also another extremely easy fix to make your dishwasher to drain.
  3. Check to ensure that the hoses are still attached. Use your manual to find where the hoses are. If they are not attached the owner's manual will give you instructions on how the attach the hoses to your specific dishwasher.
  4. Attempt to declog the line. Disconnect the hose from under your sink and check to see if there are any clogs. Use a hanger or towels, remove the clog from the hose.
  5. Remove the dishwasher basket. Again refer to your owner's manual for specific instructions.Normally you will remove it with a screwdriver. Make sure to work slowly. As you take the basket apart, you will be able to see if it needs to be cleaned. If there is dirt or debris, you can clean the parts with a rag or paper towel. After cleaning these parts, you can replace the basket.
  6. Call a plumber. If the dishwasher is still not draining, the problems are a little more complex to fix. It is advisable to call plumber to make your dishwasher drain.
Good Luck and thanks for using fixya.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Dec 13, 2010 | Whirlpool DP1040XTX Portable Dishwasher
Loud noise when washing, but not during drain. What wrong?
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
Instructions And material
Needed below.
  • Basic Tools,Rag.
Dec 13, 2010 | Whirlpool GU2700XTSS / GU2700XTSY Built-in...
Will not drain - oe code
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Instructions
  • Basic Tools,Rags
Dec 13, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
Water is not draining
Instructions
Things You'll Need:
  • Basic Tools,Rags.
Hope this help/
thanks.
Nov 06, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
Whirlpool Gold Quiet partner III Mod GU3200XTPQ3 Will not drain? Thank you
Instructions
Things You'll Need:
  • Basic Tools,Rags
Thanks for visiting .
Nov 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher is not draining?
Instructions
Things You'll Need:
  • Basic Tool,Rags
  1. 1 Check the basics. Make sure that the dishwasher has actually finish the cycle. Your dishwasher will not drain until the end of the cycle. Many things may have interrupted the cycle. Check circuit breaker and reset it if appropriate. Also check the fuse. It is possible that you could have tripped a circuit have way through the cycle. Make sure the door is properly closed. Ensure you have chosen a cycle on the dishwasher. It is amazing the problems children could accidentally cause, that are easy fixes.
  2. 2 Remove any excess food at the bottom of the dishwasher. The best way to do this is with your hands. Large food particles can block from going into the drain.This is also another extremely easy fix to make your dishwasher to drain.
  3. 3 Check to ensure that the hoses are still attached. Use your manual to find where the hoses are. If they are not attached the owner's manual will give you instructions on how the attach the hoses to your specific dishwasher.
  4. 4 Attempt to declog the line. Disconnect the hose from under your sink and check to see if there are any clogs. Use a hanger or towels, remove the clog from the hose.
  5. 5 Remove the dishwasher basket. Again refer to your owner's manual for specific instructions.Normally you will remove it with a screwdriver. Make sure to work slowly. As you take the basket apart, you will be able to see if it needs to be cleaned. If there is dirt or debris, you can clean the parts with a rag or paper towel. After cleaning these parts, you can replace the basket.
  6. 6 Call a plumber. If the dishwasher is still not draining, the problems are a little more complex to fix. It is advisable to call plumber to make your dishwasher drain.
Thank for visiting.
Nov 06, 2010 | GE Nautilus 24" Built-in Dishwasher
Water not draining in the bottom of dish washer.
Instructions
Things You'll Need:
  • Basic Tools.Rags..
thanks.
Nov 06, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
LG WFT1071TP Top Load Washer Logo
46 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
