I need a Yorkville Sound Traynor Monoblock-b Guitar amp Power supply wiring diagram
AutoDoc
  • 169 Answers
SOURCE: wiring diagram
Do you still need help with this?
Posted on Aug 31, 2008
  • 1138 Answers
SOURCE: i need the pin out details of a digitech rp6 guitar effects pedal
Try contacting the service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply which is PS0912.
Posted on May 26, 2009
  • 1138 Answers
SOURCE: digitech rp6
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
PolyrhythmFX
  • 109 Answers
SOURCE: Need to see the wiring diagram for Yamaha guitar EG112C
Here is how your guitar is wired. Good luck with your project!
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=HSS_1v_1t_5w
Posted on Aug 27, 2009
Testimonial: "great response time ...got what we needed"
  • 70 Answers
SOURCE: hp power supply wiring diagram
www.pavouk.org/hw/en_atxps.html
using this link and get your power supply diagram.
Posted on Jan 05, 2010
Planet audio
Sounds like your power supply to the amp. Make sure you location has plenty of air flow around it and use at least 10 gauge wire to the power input. Same size on the ground and make sure all contacts are clean. Your alternator will run hot when the sound is cranked and the car is moving. The heat lowers the amperage output of the alternator and will cause the amp to cut in and out.
Nov 07, 2013 | Planet Audio PX1500M - 1500W MOSFET...
I have a YORKVILLE AUDIOPRO 1212 mixing board. When I turn it on the PROTECT power LED light comes on and stays on (does not go off.) What can the problem be?
That's your Amp Protect. Only a Yorkville certified technician can help you now. Email Tom Keefer at tkeefer@yorkville.com for a return authorization number, then mail it to Yorkville. They'll fix the problem.
Nov 17, 2011 | Audio Players & Recorders
I have a dean vendetta xm and it wont make sound through an amp they wiring is correct (checked through diagram provided by dean)
can be a number of things . i'll do my best with a check list. 1. Are they active pick ups.? (they need power source , usually 9 volt battery). 2. Check your cords. 3. check your amp. ( what i do, if you can, use a guitar that you know works. and check cords and amp with that. or try your guitar thru a different amp).AND THAT'S IF,. as you say your wiring is correct , and you've eliminated that part of it .I'd start with that
Jan 20, 2011 | Dean Vendetta XM Electric Guitar
I get no sound at all when I plug in to the input and its not my lead or guitar, how can I fix the amp?
This is probably not a DIY repair. You best take it to a repair shop. Likely the power amp has failed or other common problems are broken connectors/jacks, broken volume pots, and finally circuit board cracks.
Nov 20, 2010 | Fender Frontman 212R 100W 2x12 Guitar...
My son's guitar amp Epiphone guitar amplifier model ep-800, does not work after someone plugged a bass guitar on high settings. He tried it the next day, only to find out it didn't work. Could the bass...
it could have blown the speaker, a regular guitar amp is not meant to handle a bass, you should be able to look into the back of the amp and see if any of the speaker is damaged, or there may be a blown fuse inside the amp, if you check for this please MAKE SURE TO UNPLUG THE AMP FROM THE POWER SOURCE FIRST, and if needed replace the fuse with the exact same type
Mar 21, 2009 | Music
Guitar amp shows power but has no sound, could it be a blown fuse
Nine times out of ten, any problem with an amp having no sound coming out, it's a wiring issue. Make sure all of the wires internal to the amp are propely hooked up. Also, try switching out the quarter inch cord you are using from your guitar to your amp. Could be a bad cable. Unless you have blown the speaker completely, something is loose or not hooked up properly.
Feb 27, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Trying to figure out what kind of amp i got amercian pro vs-3507?
The VS3507 Is a class D monoblock.
Your optimum wiring for this amplifier is a 2 Ohm load - so it produces its full potential power of 350W RMS.
To Achieve a 2 ohm load, the most common load is one of the following...
(1) Dual 4 Ohm Voicecoil Subwoofer Wired in Parallel.
(2) 4 Ohm Voicecoil Subwoofers wired in Parallel.
(1) Quad 2 Ohm Voicecoil Subwoofer wired in Parallel/Series.
(1) Single 2 Ohm voicecoil subwoofer.
American Pro VS3507 2000W Car Audio Monoblock Amplifier
American Pro VS3507 Monoblock Amplifier Details
  • Built-In Crossover
  • Variable High/Low Pass Filters
  • Phase Shift Control
  • Subsonic Filter
  • Bass Boost Control
  • Dancing Lights at the Rhythm of Music
  • Protection Circuits
  • Gold Plated Terminals
  • Power & Protection Circuit LED
  • 1 x 250 Watts RMS @ 4 Ohms
  • 1 x 350 Watts RMS @ 2 Ohms Thanks for using FixYa - A FixYa rating is appreciated!!
Jan 29, 2009 | American Pro Car Audio & Video
Bass amp for guitar?
i say it can! u would get a nice clean sound! acoustic guitar sounds nice through a bass amp!
you probably wouldnt get distortion out of bass amp though! depends on the bass amp! some bass amps have built in effects! e.g distortion
Oct 15, 2007 | 3Com SuperStack II advanced RPS...
81 people viewed this question
 Grubhead
Grubhead
