Question about Ricoh Priport VT6000 Copier
Ricoh DX4640PD priport machine with SC556 code - what is this, I can't get past it to open the drum unit or anything? Thanks
And how about error code SC553?i try log in test mode and use program clear mermory.the machine still code SC553
Posted on Apr 06, 2014
5 Suggested Answers
  • 86 Answers
SOURCE: Ricoh priport jp1210
Press Clear mode > 1 0 7 > and press and hold the Stop button for 3 seconds.
Good luck and please rate me, thanks.
Posted on Jan 22, 2009
SOURCE: display screen says: door/covers open close covers of relay unit??
I believe the "relay Unit" on that machine is the section that transports copies to either the finisher (if installed) or the exit tray on the LEFT side of that machine. Sometimes neither of these units are present, but the relay unit may still be installed.
There are 2 flip up covers on that section (left and right), and you will probably see that one of them (usually the left one) has come unclipped, or perhaps the plastic clip that holds it closed is broken. If you flip up this unit. You will see a black button at the back end that is engaged when ther unit is closed. If you simply pree this button with your finger, hopefully the message will go away - this may at least help you troubleshoot what is causing the "cover open" message). Even if the clip is broken, it is often just a matter of seating the unit correctly so that the switch is engaged when the unit is closed. There is also the same switch on the right cover that could be causing the problem, but this cover doesn't sem to get damged as often.
I hope this helps. Please let me know.
Posted on May 26, 2009
goodgold
  • 389 Answers
SOURCE: Paper Sticking to the drum
Check in what condition separators drum.
Posted on Sep 20, 2009
newport74
  • 58 Answers
SOURCE: paper jam message, remove the paper from drum
Try cleaning the feed rollers with soap and water and a damp cloth and see if your situation improves. sounds like the machine is missfeeding but your description was a little vague.
If it does improve youll need new rollers.
Also try flipping the paper over to see if improves.
Lastly does the paper size displayed on the screen match what is actually loaded? if not... correct as nessesary
Good luck
Posted on Apr 19, 2010
Ricoh VT6000 lcd is on but no commands will respond. Have tried everything in the manuals. What's next ?
Ricoh VT6000 and postscript controller cpif-26 ' Adobe Community ...
https://forums.adobe.com/thread/1718082?start=0...0
Adobe Systems
Feb 27, 2015 - 2 posts - ‎1 author
Have printer Ricoh VT6000 - very old but good and still working, have ... But there isno drivers for CPIF controller and also for printer for new windosw 7 for example. ... Canyou advice what to do to install those printer and controller on win xp? ... Dov Isaacs Feb 27, 2015 9:23 AM (in response to witer30).
[PDF]UC5Operators 1-5.PM6
rfg-esource.ricoh-usa.com/stellent/groups/public/.../rfg000936.pdf
or transmitted in any form, including but not limited to electronic, photocopying, mechanical ... holders. Ricoh and PriPort are registered trademarks of Ricoh Japan. ....VT6000/5390/1295/CP390/3400DNP/SD600. ZipRIP Pro A ... Once the UC5 has been installed, you will need to install a GDI printer driver. Please follow the
Jan 18, 2016 | Ricoh Priport VT6000 Copier
What does error code E-06 mean on a ricoh priport duplicator mean?
It's a main motor error. Check the sensors at the back when you remove the drum. Check to see if the sensors are in place.
Jan 21, 2015 | Ricoh Office Equipment & Supplies
I have a ricoh aficio 2035 and there is error code sc 350, what can i do ?
open the right door and you will see a black sensor above the drum unit.
remove the drum unit and clean the sensor in the machine at that position .
rfix the drum unit and power the machine .
please do this carefully as you may damage the drum .
good luck.
May 05, 2014 | Ricoh Aficio 2035E Digital Copier. 35cpm...
Ricoh SP C811DN has a sc 400 error code
open the front door and left door, take out the drum unit after releasing the lock lever if look at the opening from the right you can see a black sensor unit facing inward towards drum clean its inner side with a dry cloth and put back everything it is the id sensor, machine should work now
Apr 03, 2014 | Ricoh Aficio SP C811DN Laser Printer
Sc556
To reset fuser SC codes you need to enter Service Programme Mode and reset SP5-810 to 1, then turn the main switch off and on again. If you need help on entering SP mode etc. then take a look here.
Feb 27, 2012 | Ricoh Aficio AP3800C Laser Printer
Ricoh priport jp 1010 error code E 02 explain this code to me.
when powering on, ricoh priport jp 1050 indicated 02
pls help how can solv
Jun 10, 2011 | Ricoh Office Equipment & Supplies
I have a Ricoh Priport VT2250 duplicator. I keep getting an error
ls lt an image problem? image problem can be occurred if the solid black part of the image is on top. try to reverse the image by scanning it invert the image on the other side meaning the solid part be placed at the bottom.
May 26, 2010 | Ricoh Priport VT6000 Copier
Sep 06, 2009 | Riso RZ220 Duplicator
Dec 21, 2008 | Ricoh Priport VT6000 Copier
278 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
