Question about HP Pavilion dv6000z Notebook
@Hotmail.comOk i Have an hp pavillion dv6 and when i turn it on it it loads normally , says microsoft bla bla bla is loading and as it gets to the part where it shows the user log and i gotta enter my password it doesnt show up on screen. the screen goes completely blue. i left it like that for a while to see if there would be any change but there wasnt. HELPPPPP!! i seriously wanna throw this in the garbage!
    Novelist:
  • 100 Answers
Hi the problem is basically with ur operating system or any previously new software that u might have loaded recently it might have been corrupted if u have tried several times after switching it on and of u should reboot ur laptop 1.step go to the boot menu by pressing F2 at the very beginning when ur system starts and u will see a boot menu will be appeared on the screen in that u will see reset/remove password type ur original password two times as asked to do so and remove it and in the exit tab save changes and exit and see that ur OS loads this time or not
step2.reboot ur system by installing a new OS and u will see a pop up message boot from CD and install a new windows this might solve ur problem if u liked my solution pls rate it
with warm regards- bonefirediv.
Posted on Apr 04, 2011
Do you have to turn on bluetooth on hp pavilion dv6 notebook and if, where to connect with other bluetooth devices?
dv6 is not the full name, use full names
NO OPS SYS ,stated, XP , VISTA, W7, W8, W10 , what?
each DV6 made can or can not have bluetooth.
its an options, at DAY 1. buy.
see this service tag, (HP .com will ask you same question.)
On one laptop I have the bluetooth is part of the wifi card.
if you have the cheap model , its missing.
and would need to upgrade that module. to both.
WIFI+bluetooth mini PCI card,
the first step (not me I use my PCI scanner first)
but look in device, manager.
if blue tooth is missing there,
that means , driver missing, chip missing or you have a virus.
there are tests to find out which it is.
there are 2 possible blue-tooth STACKS,
HP,s or Microsofts. both can work, but you can NOT mix them.
or boom , blown Stack ! (mangled)
what id do is get the HP driver for your blue tooth and load it.
per the instructions at HP.
if the chip is missing the HP installer tells you it is.
example of only one tag. see that red arrow that be the real model number in fULL,
here is why DV6 means NOTHING., see all those.
which one do you own?
https://support.hp.com/us-en/drivers/selfservice/identify?q=dv6&filter=
Jun 05, 2017 | HP Computers & Internet
Hp pavillion dv6 on but dark screen
sounds like the black screen of death
a lot of dv hp laptop have this problem the gpu has to reflowed are your keys also blinking. if they are count the number of blinks it will point to problem
HP DV7 Laptop Graphics Fix Black Screen of Death
would not fix it his way
Jul 04, 2015 | HP Pavillion DV6-1355DX Notebook PC -...
My hp Pavillion dv6 laptop can no longer use Constant Guard which Comcast supplies. Also Quattro Pro quit working midstream. How do I fix it?
More then likely running System Tuneup replaced critical files that Comcast Constant Guard and Quattro Pro uses... I recommend doing the following three steps but only if you have the Original or backup copies of the installation disc/media for both applications: 1) uninstalling the Comcast Constant Guard application 2) then do a normal shutdown and reboot once it has rebooted 3) install the Comcast Constant Guard once that's done and successfully do the same three steps but for the Quattro Pro application
Jan 02, 2015 | HP Pavilion Computers & Internet
How to get a replacement for a HP Pavilion DV6 motherboard??
You will want to contact HP support directly to order the necessary part. The serial number of the machine in question will allow them to locate the correct part for you and set up a purchase and ship unless they prohibit non-HP repairs.
Mar 28, 2014 | Computers & Internet
I recovered my HP pavillion dv6 laptop to it's factory default. but now the HP smart webcam software doesn't work. when i click it it do nothing but the camera is working fine with skype! please give me a...
Have you loaded the Windows updates?
Re load the drivers for the camera as there may be a problem with the software. Go online to HP and get the latest version.
Hope that helps.
Nov 19, 2010 | Computers & Internet
Hp pavillion dv6 laptop no power
1. Check the adapter
2. Check the processor
3. Check the motherboard if defective replace new one.
Note: You need to know the right spare part number of your motherboard e.i 443776-001. Here's a sample video
May 04, 2010 | HP Pavilion DV6500Z Notebook
My hp pavilion dv6-1030us is all of a sudden not booting up. It turns on fine but when it comes to the loading screen that says Microsoft Corporation and has the loading bars running across the bottom it...
try going into safe mode F5. reboot and keep tapping F5 if you can get into safe mode try a system restore back to the time it was working. if not reload from recovery drive (F11 i think) or from recovery disc.
hope this helps.
Apr 29, 2010 | HP Pavilion dv6-1030us Notebook
None of my quick touch buttons work. HP Pavillion dv9000
My thoughts is that you may have had a Microsoft update to which has knocked out your drivers for these features. You may have to go back to HP's Web site and re-load the drivers for these two features.
Blessings,
A/V Media Guy
Nov 19, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
I need de manual of de HP Pavillion dv6 1245dx
you can download it by clicking on the link below:
http://h10032.www1.hp.com/ctg/Manual/c01035677.pdf
Nov 08, 2009 | HP Computers & Internet
HP Pavilion dv6000z Notebook Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
