Question about Maytag Refrigerators
Maytag MSD2756DE refrigerator start relay keeps failing. Suspicion is that very short (1-5 second) interruptions in the electric supply are the cause My question: Would an appropriately sized uninterruptable power supply installed in the line between the refrigerator and the circuit breaker box resolve the issue? Since the maximum current draw for the unit is 7.2 amps, it would seem that a UPS which could supply 800 watts should be enough to solve the problem. Given that the maximum current is only drawn momentarily at compressor start, chances are that a unit considerably lower that 800 watts would probably be sufficient. Please advise.
  • barry_bca Aug 05, 2008
    We do know that there have been brief power outages because UPSs for computers have beeped once or twice when clocks and other appliances like VCRs have lost their settings and had to be re-programmed. A UPS seemed like a logical solution for that since it would prevent the power outage from reaching the refrigerator and turning off the compressor and then trying to immediately re-start it. It obviously would not keep a refrigerator going through a longer power failure.
    Replacing the start relay three times in six months is too expensive to not try something and the hard start relay/capacitor sounds like it might be the better way to go. Many thanks.
    Novelist:
  • 116 Answers
An interruption in the power supply would usually show in other electrical fixtures in the house. A UPS is not recommended for a power back up on a refrigerator.
The condition you describe usually indicates that either the compressor is working too hard and drawing too much current or the start relay is gone bad. The starting and stopping that you hear is a safety shut-off within the relay. A good place to start is changing start relay for the factory recommended one.
If the standard relay does not correct the problem, there is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your refrigerator first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system. Outside of this may require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a refrigerant leak.
Check your refrigerator owners manual before making any repairs or modifications to your refrigerator, there may be an extended warranty on the sealed system and compressor if needed.
Posted on Aug 05, 2008
Starting capacitor failed. Replaced it and found new capacitor getting very hot. Does anybody know if this is a capacitor start or permanent split cap electric motor? No easy way to open the motor case to...
hi, more than likely a psc motor on a `small pressure washer.
The usual problems with the capacitors failing is down to a poor power supply, wether it be using a long extension lead of too small a size, or the power supply itself.
check voltage to machine while using it, a voltage drop will cause characteristics of motor to change, phase angles etc..
A refrigerator starting relay would not have the required amperage ratings for a pressure washer..
hope this helps , andy
Oct 12, 2013 | FAIP 1500 PSI Electric Power Washer
I have a Maytag refrigerator model# PTB1953GR, (probably well) over 10 years old, with upper freezer, lower refrigerator and no icemaker. I am a "snowbird" so that it is unused and unplugged for...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Maytag Refrigerators
The refrigerastor and freezer don't operate. I suspect the compressor relay. When I read resistance across the female pins on the relay P/N 6100693, I read a short. Should the relay read open or short...
the maytag relays ormally when they go bad you can shake them and you will here them rattle if they have failed... there are points in there and should be opened until power made to them.
the overload will be closed or as you said shorted and when compressor overheats or binds it will open on excessive current.... you can get a new ptc relay /overload or you can purchase what is called a 3-n-1 " for the unit that actually has the overload and all built into it,plus is for hard starting compressors.... good luck to you.
Mar 12, 2011 | Maytag MSD2756G Side by Side Refrigerator
Model # msd2756de freezer and fridge stopped cooling, Christmas Day!!!!!!! unloaded freezer, fridge overnight the temp the next morning is 15 in freezer and 50 in fridge. moved thermostat back and...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Dec 26, 2010 | Maytag Refrigerators
Maytag 21.9 Cu ft. Bottom-freezer made a loud pop sound and smells like electrical fire. What should we do (besides unplug it, which we did)?
The pop and smell are probably the capacitor blowing up...the refrigerator will not work until you get that replaced...
Check out my tips about capatitors and relays on refrigerators...
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 11, 2010 | Maytag 21.9 Cu. Ft. Bottom-Mount...
Msd2756de--water leaking out of the water supply at bottom of freezer hindge.i think this goes up to ice and water on door.is there an easy way to remove facing if this is the problem .
seal or plumbing has come lose.....not really a easy job....possibly the front of door has to be removed or maybe just face plate of the water disp cane removed to retighten plumbing.
Jul 07, 2010 | Maytag MSD2756G Side by Side Refrigerator
My freezer is not working properly with clicking sound.
The clicking sound is probably the compressor relay trying to start the compressor. When the lights dim, the compressor is trying to start and hence, pulling power from the rest of the unit. If the compressor has a start capacitor, that could possibly be the problem. If not, the compressor itself should be replaced.
Mar 26, 2010 | Maytag MSD2454G Side by Side Refrigerator
Relay keeps clicking on and off
We aren't sure either without putting a tester called an "Annie" on your compressor. Maytag has had a lot of compressor failures, and we have installed overload relays on some of these refrigerators, the compressors ran fine and pulled perfect amps, and hours later the compressors failed anyway. You can remove the overload relay from the compressor, and do a continuity check on the three terminals. You should get continuity between all three, and you should not get any continuity between any terminal and the compressor case or freon lines. If the compressor tests fine, then it is usually, not always, a bad overload relay. If the compressor tests bad, then your refer is not worth repair, usually a 900 to 1100.00 repair in my area in Seattle. You may still have a warrantee on it as most brands still have a full 5 year warrantee on the compressor. Good Luck, Appliance Specialists.
Jan 25, 2010 | Maytag MSD2454G Side by Side Refrigerator
The switch on Maytag water and ice dispenser hangs
Need to enquire from the agents if that dispenser switch is available as a spare part. If so, switch off and strip carefully as logic shows you.
Sep 24, 2009 | Maytag MSD2756G Side by Side Refrigerator
Good evening, My Maytag refrig/frez s/s model #MSD2756DE is very warm inside. This started after a thunder storm. It's making a clicking sound every 2-3 minutes. It sounds like a compressor wants to start...
Sorry to tell you this, but your compressor is stuck, your chance of getting the compressor unstuck is about 1%. Companies warranty their compressors for 5 years on the average. If the fridge is older than that, it doesn't pay to have someone replace it, it would be time for a new fridge.
Jun 23, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
878 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
