Question about BenQ (5232W) (5232W-BULK) CD-RW Burner
Neither reads nor burns, the device, that is, BenQ 5232W is well registered in BIOS and on the OS.
    Guru:
  • 382 Answers
Greetings!
This is a bit complicated so we have to be very careful in doing so. The main goal that we have is to Delete the Upper and Lower Filters on your registry, and that's what makes it complicated.
To start with
>Click on START
>Type REGEDIT on the search bar on START Menu
>Expand HKEY_LOCAL_MACHINE
>Expand SYSTEM
>Expand CurrentControlSet
>Expand Control
>Expand Class
>Click {4D36E965-E325-11CE-BFC1-08002BE10318}
>Look for the Upper Filters / right click on it / click on Delete
>Look for the Lower Filters / right click on it / click on Delete
>Restart computer
>Try you CD / DVD ROM
I hope it helped you out. Rating my assistance will greatly be appreciated. Should you have any followup questions feel free to post it here and I always get back to my resolutions. Thank you for choosing FixYa! Have a good one.
Step by step resolution available on my blog. Click Here to get there.
Posted on Apr 04, 2011
I have an old BenQ joybook 2000. I have installed another anti-virus in my unit, however, after I restarted the computer I can only go to the administrator log in page then it will open few seconds, t
If you go into the bios and set the boot sequence to CD/DVD first bot device, place your OS disc in the drive it will boot from there and allow you to have a clean install as the CD/DVD drive is recognized by the system at boot up.'It is your sofyware that corrupts the index.
Jan 23, 2014 | Computers & Internet
I m getting c6 code on my msi motherboard 7642
Hello here is the homepage:
http://www.msi.com/product/mb/890GXM-G65.html#/?div=Manual
Make sure ALL the drivers is installed on the mainboard:
http://www.msi.com/product/mb/890GXM-G65.html#/?div=Driver&os=All
Post Status
FF Power on and first initialize CPU.
C0, C1, C2 Early CPU Initialize.
C4, C6 Initialize chipset.
D4, D5 Initialize memory.
08 Initialize keyboard.
2A, 31 Initialize onboard devices. Load Option ROM (VGA and RAID
option ROM) form BIOS to memory.
37 Displaying sign-on message, CPU information, setup key
message and any OEM specific information.
38 Initialize USB device and different devices.
3C Mid POST initialization of chipset registers. Detect different
devices (parallel ports, serial ports and coprocessor in CPU...etc.)
75, 78 Initialize INT 13 devices and IPL devices. (include SATA/ PATA
HDD and CD/DVD ROM).
87 Enter setup screen. BIOS setup if needed/ requested.
A4 W ait for user input at configuration display if needed.
A7 Display the system configuration screen if enabled.
B1 Save system context for ACPI (Advanced Configuration and Power
Interface). Prepare give control to OS loader (INT 19H).
00 Pass control to OS Loader (typically INT 19H).
AA Enter OS (Vista or W indows XP).
Look also here:
http://www.dewassoc.com/support/bios/awardbios_error_messages.htm
Did you upgrade the ram memory, or the cpu ??
When and how did this problem occur ??
Jan 31, 2013 | Computers & Internet
What is the position of the link do I need to change to master/ slave etc
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
The BIOS is AMI. Under ADVANCED SETUP:
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
Jan 28, 2011 | BenQ CRW-5232W 52X32X52 IDE CD-ReWriter...
Computer starts to reboot but stops at exactly the halfway mark every time.
Hmmm...
Looks like ur Hard disk is not working, OS needs reinstalling , and the power supply that supplies power to ur HD is malfunctioning!
better check ur BiOS and read ur check ur HD if it registers in ur BiOS and set ur BiOS to DEFAULT!
tell us afterwards....
Dec 02, 2010 | Dell Inspiron 531 Athlon 64 X2 4400+...
I have IBM System x3400 server and when im installing the OS it is saying “SETUP DID NOT FOUND ANY HARD DRIVES”
Check your BIOS setting first to make sure the system is registering all devices attached. If you do not see the hard drive in the BIOS, check the cable connections and reboot the system. Once the BIOS 'see' the hard drive, you should be able to install any os that support your hardware configuration.
Good Luck
C2S
Jun 28, 2010 | IBM x3400 Server
I lost the bios password for my Benq joybook 5000.
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
Jun 15, 2009 | BenQ Joybook 5000 Notebook
Vista Driver : Benq 4300 scanner
This is the best way to download the drivers of all your devices which are connected to the system for free.
You can download them easily using the software application called "Driver Magician"
Here : http://www.drivermagician.com/DriverMagician.exe
Install and register with the following details,
"username"="Angels"
"serialnumber"="8974-9325-643"
You are ready to go download unlimited and all the drivers for all the devices you connect.
Good Luck.
Live, Love, Laugh
Aug 20, 2008 | Computers & Internet
Cd burning
Usual clenaning of the lens maybe can solve your problem but olso there is great posibility that somehov your cdrs are not good...
May 26, 2008 | BenQ (5232W) (5232W-BULK) CD-RW Burner
Not Reading/writing not even detecting
You need to check the bios on start up. You should have your CD/DVD drive as the first boot device.
Apr 20, 2008 | BenQ (5232X-0C1) CD-RW/DVD-ROM (Combo)...
Benq 52x32x52 seamless link
I have aseamless link dvr 52x32x52 it is not recording, it keeps initialising or resetting
Feb 18, 2008 | BenQ (5232W) (5232W-BULK) CD-RW Burner
BenQ (5232W) (5232W-BULK) CD-RW Burner Logo
Top BenQ Computers & Internet Experts
Tony
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
