Question about Acer NSK8458AN Keyboard
Some number keys also has 3 other functions. how do i use them. for instance the 6 also has ^ and question mark which i can't find.
  • 2,069 Answers
You press shift then 6 to use the other function. it is called a secondary function. newer keyboard may even have up to 3 functions. Regards
Posted on Apr 04, 2011
I have a Casio fx-83wab. How do I calculate to the power of a fraction? So a number to the power of 1/3 for instance - I've tried the x-1 button with the fraction in brackets after it but that comes up as...
Use the general power key that is marked as [^], [Y^x] or [X^y]. Enclose the fractional exponent (1/3) in parentheses.
You can also look for a general root key, marked as [x Root]. To use this key, press the root index (3 for example), followed by [x Root] and then enter the argument. If the index of the root is even ( 2, 4, 6, ...) the argument (inside the root) must be a positive number.
Nov 23, 2014 | Office Equipment & Supplies
What's your problem?when i type o its come 6 then i type L it become 3 ...
NUMBER LOCK
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock.
Oct 06, 2012 | Samsung N150 Series Netbook
How do i solve this factorial equation? 8!/5!x3!
How to calculate 8!/(5!3!)?
For small numbers (8,5,3) you can use the factorial function key (I will tell you later how to access it) and enter 8! divided by 5!, divided by 3! For numbers greater than or equal to 70 you cannot calculate the factorial: the result is too large for the calculator's memory.
However the formula you wrote is an instance of a combination 8C5 or 8C3 (they have the same value.
Most scientific calculator have three functions: the n Factorial n!, the Combination function nCr and the permutation function nPr.
  1. Turn Calculator ON
  2. Select the Run icon and press EXE.
  3. In Run Screen Press the OPTN key
  4. Press F6> to pan to the other tabs
  5. Press F3:Prob
The first tab (F1) is marked x!.That is the factorial.
The tab (F2) is marked nPr is for the permutations
The tab (F3) is marked nCr and it corresponds to the combinations.
To use nPr or nCr you enter the larger number n, you press the F key under nPr or nCr. If you press F2 you see a fat P, if you press F3 you see a fat C. Complete by entering the value of r (the smaller number)
If your problem corresponds to Select 8 objects, 5 at a time regardless or order (combinations) you type 8 F3 5 and EXE Result is 56.
Aug 31, 2012 | Casio CFX 9850GA Plus Calculator
I want to know how to use the function button
The function button, or FN button, is used just like the shift key or ctrl key. Hold the FN button down and press the key with the pre programmed function you desire to use. For instance, on an HP 1245 the function or short cut key to put the computer in sleep mode is FN+F5. The Keys with functions have that feature indicated by a symbol for the function in a squared circle. Most of these are your F keys at the very top row of the keyboard. Some are on the number pad keys.
Oct 27, 2011 | IBM ThinkPad R31 2656 Notebook
I have a new HP keyboard which seems to have three or four choices for upper and lower case. For instance, the number 6 key has a choice of 6 or ? or several other designs likw an arrowhead which I cannot...
Keyboards can have various functions for each key that are enabled by first pressing a modifier key. Some keyboards may have an Fn key that stands for 'Function' that are identified by a bluish-purple color.
You would have to hold down the Fn key before being able to use the corresponding function.
Other keys may have items that can only be used once you press the NmLk (Number Lock) key. Usually you only have to press the NmLk key once to enable these alternate functions and then press it again to disable.
Mar 12, 2011 | Computers & Internet
WHEN I PRESS U I O P J K L ON laptop, it type 4 5 6 - 1 2 3
try pushing the key marks "fn" and "F11" at the same time on your key board.
Feb 28, 2011 | Computers & Internet
In my key board m button tyed show 0 why
You probably have Number-lock active, test and see; u = 4, i = 5, o = 6, j = 1, k = 2 and l = 3.
On the bottom left of your keyboard you should find a key marked Fn. On the top right of your keyboard you should find a key marked Num LK. While pressing the Fn key, press the Num LK key once. this should unlock the number keys and allow you to type letters again.
Good luck ;)
Feb 02, 2011 | Computers & Internet
How to calculate to the power of
To raise a number to some power other than 2 or 3, you use the [y to the x] key. Exemple 2[y to the x] 5 = 2x2x2x2x2=32.
Hope it helps.
PS. I could not understand what you wanted with those expressions.
Apr 11, 2009 | Sharp EL-531VB Calculator
How do you use the question mark
The numeric keypad functions like the numeric keypad on an external keyboard. Each key on the keypad has multiple functions. The keypad numbers and symbols are marked in blue on the right of the keypad keys. To type a number or symbol, press <Fn> and the desired key after enabling the keypad.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Dec 22, 2008 | Dell Inspiron 1501 Notebook
Acer NSK8458AN Keyboard Logo
343 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
