How to connect thermostat/switching relay/circulator
    Scholar:
  • 133 Answers
Are you working with 2 separate transformers and a single 2 stage thermostat? Please provide a little more information on the components you are controlling. Please rate my answer for me. Good or bad, it all helps me to be better. Thanks for writing. Roger
Posted on Apr 04, 2011
Can not get fan on to turn on. All else fine. heat only furnace. No air conditioning...only air circulation.I used to set it on "Cool" and "Fan On"and get air to circulate. Do I need new thermostat?
Since you have two thermostats that operate the heating unit and the fan, and the fact that neither will turn the blower on, I would suspect the furnace/ air handler. Turn the thermostat to heat and see if the heat and the fan comes on, if it does operate normally in heat, the fan relay or the high speed on the blower is most likely the culprit. (If the furnace is equipped with a circuit board, the fan relay is integral to the board, if it an older furnace it has a separate fan relay). If it does not operate normally in the heating mode, verify power to the furnace, see if the flame comes on, if it does: the fan motor, circuit board or the fan relay are most likely the cause. hope this helps!
Jul 20, 2015 | Heating & Cooling
HOW TO FIND THE CAUSE OF THE BLOWER RUNNING CONTINUOUS
Does the mail switch turn of the power? some fans keep going unles you turn them of for circulation.
Jan 08, 2015 | Heating & Cooling
Overheating
First make sure that the fans are turning on if it is check for circulation of water in the radiator you might have a clogged radiator or bad water pump if that's ok check thermostat make sure that it opens at the right temp some new ones come defected
Apr 12, 2014 | 1997 Chrysler Sebring
My new radiator fan wont come on and I checked it before I put it on what else could be wrong?
Hello Barry,you have not specified the make of vehicle,Make sure that the thermostat is opening thus allowing free circulation of water.check the relay for the fan,thermo switch on the radiator, and temperature switch.
Oct 05, 2013 | Yamaha 2007 Grizzly 450 Auto 4x4
The blower motor/circulating fan will not shut off. I have changed the thermostat, did not fix the problem. Removed fan wire from the thermostat, had no effect. The only way to stop the fan is to turn of...
Hello, yes you are are correct. If you remove the green wire from the G terminal at the board and blower keeps running, the relay is stuck and the control board must be replaced.
Oct 07, 2011 | Goodman GMS90703BXA Heater
Running hot all water going straight to overflow tank
Check the thermostat. If the upper hose does not feel very hot to the touch when the car is warmed up already, this indicates the thermostat is not opening, and therefore the water cannot circulate causing the overheating problem. Second possiblity is the radiator fan. If the car tends to overheat only on city driving it is a the radiator fan not coming on. This is either due to a bad radiator fan, blown fuse,bad relay, or a bad temperature sensor or temperature switch. If the car tends to overheat at highway speed, then it is the radiator being clogged up, and not letting enough water circulation when demand is at its highest which is high engine rpm.
Nov 11, 2009 | 2003 Dodge Neon
Looking for simple wiring diagram to wire ******** aquastat
What are you fanning??? the fire?
Do you have a circulator that circulates when the water is up? Many controls have a AUX connection ... wire the AUX to your fan --- alaternatively, wire directly fron your circulator connection to the fan.
I hope I understood your question ...
Let me know what happens.
a
Oct 16, 2009 | Honeywell International Honeywell&...
Intertherm gas furnace model number m6bb070abfc01
Check for a open limit switch caused by a dirty filter or poor air flow
Dec 24, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
