Question about GE Spacemaker JVM1640SJ Microwave Oven
Model jvm1642wb002...pad has some numbers working and some not working
  • 80 Answers
Try to clean by cleaning spray specialized for this purpose.
Posted on Apr 04, 2011
The control pad only works on a few numbers.
Check to see if there is a ribbon cable between the touch pad and the circuit board. If there is, clean both ends with electronic contact cleaner, and re-connect.
If that doesn't fix it, you may have a bad touch pad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jan 11, 2017 | Microwave Ovens
Frigidaire troubleshooting key pad seems to be stuck on child lock
If you have your owner's manual, read the section on how to disable the child lock. If that doesn't work the touchpad could be defective.
Jul 17, 2014 | GE SpaceMaker Microwave Ovens
Touch pad not working
If you'll let me know your full model number and remind me of your symptoms, I can give you detailed help at no charge.
Jan 08, 2014 | Sanyo Microwave Ovens
THE KEY PAD QUICK WORKING. I HAVE REPLACED THE CONTROL BOARD BUT THEY STILL DO NOT WORK.
Hello, Thank You for using FixYa. I will be helping you today.If the buttons are not working replace the touch membrane. I would list the part number but you didnt give full model number.
Thank You and please rate my answer if it was helpful..
Jun 27, 2011 | Frigidaire PLMB209DC Microwave Oven
Numbers 4,7,8,9,0 and Beverage on pad do not work. Others do work, do I have to replace the oven? (Spacesaver JVM1440WH04) Over stove oven installed in Feb 2007, in use 4 months each year. This problem...
No you can have the keypad replaced. It may be something as simple as a dis-lodged keypad ribbon connection where it mates to the control panel recepticle. If you look here: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JVM1440 there are several model numbers it seems you did not provide all of the numbers but the keypad is the same. The key panel here is $75.00 http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JVM1440 Then you add a service call or shop charge your looking at well over a $100.00 repair. Your call on how to proceed. Good luck.
Jan 12, 2010 | GE JVM1440 Microwave Oven
After pressing the TIME button, the number pad does not react.
A hard reset, that is, removing the unit from the electric source and restarting it after a few seconds, solved the problem.
Apr 05, 2009 | LG LMV1630 Convection/Microwave Oven
No numbered touch pad for use setting clock
I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
If that doesn;t work, press STOP / CLEAR then try the above again.
Let us know if it does not work.
Mar 05, 2009 | Sharp Microwave Ovens
Microwave will not heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 10, 2008 | Microwave Ovens
Microwave panasonic in demonstrateion mode and won't heat remove from lthis mode
First try hitting the Clock pad three times.
Or if it has a Function pad, hit that, then follow the prompts. On some models, it's Function > 0 > 2.
If this is a model NE1257 (the model under which you posted) then it doesn't have a Function pad.
If none of this works, I'd suggest unplugging it for a few seconds or so, then trying again.
If none of this works, then please reply back with your brand and full model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 20, 2008 | Panasonic Pro NE1257 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
26 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
