Question about NRS Kinetic Road Machine Trainer
My Kinetic trainer increases resistance when I increase speed. How can I maximize resistance at low cadence of say 60 rpm?
    Guru:
  • 347 Answers
You can't with this type of trainer. You have to have a trainer where you can manually adjust the resistance. The closest you can do is shift your gearing.
Posted on Apr 04, 2011
Saw starts runs good then when i start cutting it
Hi Jason:
Make and model might help but here's two ideas:
1) Remove muffler and clean it. They can get plugged up with carbon and the saw will run at low RPM but will quit because of excess back pressure when you try to rev it up.
2) Set the high and low speed carb settings. Start the saw then gradually increase engine speed until full throttle. Screw the hi-speed needle in slowly. If RPM immediately drops, back it out until Rpm increases, then starts to drop. Screw back in until peak rpm reached, then starts to drop. Back out to peak, then 1/3 turn more.
Set low speed so engine runs smoothly but chain does not turn.
Hope this helps.
Feb 01, 2016 | Garden
Why does the rpm increase on a 98' ford explorer while traveling at a steady speed of 60 miles per hour when it used to be lower ?
Failed Transmission
It is slipping
Has to be rebuilt
Used it-- when you know it
had problems & ruined it
Aug 15, 2014 | 1998 Ford Explorer
576i resistance not increasing precor
If the display stays at 1, then the UP button may be at fault, in which case you would need a new keypad.
Jan 02, 2014 | Precor EFX 546i Elliptical Version 4
Do you put the bike computer on the front of spokes or back
Traditionally the front. Some units are wireless, but have a minimal range and cannot transmit through the riders obstruction. Most cabel harnesses will route up the front brake line.
If you are desiring it to work on a "trainer", its best to invest in a cadence (crank arm rpm)sensor. Your speed is not as important on the trainer, but monitoring your cadence in relation to your heart rate is key.
Jan 01, 2013 | Schwinn 12 Function Bike Computer
Poor performance at high revs
In this case i suggest you to go through this following help links.Click the link below to troubleshoot the procedure :----High rpm in neutral? Inconsistant high RPM in neutral? http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html----------rpm needle bounces? http://technoanswers.blogspot.in/2012/02/mitsubishi-lancer-rpm-needle-bounces.html--------------How to adjust rpm ? http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html---------Engine cuts out at 3000 RPM? http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html----------consuming more fuel? http://repairhelpcenter.blogspot.com/2012/01/toyota-tercel-consuming-more-fuel.html-----------How to maximize fuel economy on your vehicle? http://schematicsdiagram.blogspot.com/2011/11/how-to-maximize-fuel-economy-on-your.html----------
How to Perform a Basic Engine Tune-Up
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up.html-----------How to Increase gas mileage? http://schematicsdiagram.blogspot.com/2011/12/how-to-increase-gas-mileage-on-2011.html----------
Adding performance chip to increase Fuel mileage MPG? http://technoanswers.blogspot.com/2012/01/adding-performance-chip-to-increase.html
----------This will help.Thanks.
Feb 16, 2012 | Cars & Trucks
How to increase resistance on Blackburn Tech Fluid Trainer? I know it is supposed to increase with rpm's, but I am not a strong rider and I just rode 90 minutes in my biggest gear with only moderate...
Fluid trainers work by providing resistance that increases as your effort increases, much like riding on the road. There is not a switch or lever to increase the resistance with this specific trainer. So in short you have to put in a bigger effort to get more resistance. Putting in more effort and increasing your Cadence (rpm's) will provide a harder resistance and will decrease your duration attainable. This is OK. One of the benefits of using a trainer is that you can get more accomplished in less time.
Mar 25, 2011 | Cycling
What is the function of the motor relay on my master 110,000btu heater The relay,capacitor,or overload has an ID # Murata 60 PTH491A01 AS3RN160. The Motor does not start strong after multiple starts.
The PTH491 is a ptc thermistor. Its low resistance when off allows a maximum current to flow in the starting winding. As the temperature increases, so does its resistance. The starting winding is essentially isolated from the running winding once the motor has reached operating speed because of this increase in resistance.
Jan 05, 2011 | Master Heaters M125AT
How to use garmin edge 705 cadence/speed sensor
you must disable the gps speed and enable the sensor
Feb 02, 2010 | Cadence Garmin Edge 705 Bundle W/spd Hrm...
I have a Coleman Powermate Pulse 1750 generator. The engine runs fine but lately I've noticed I'm only getting approx. 105 volts. Any suggestions.
Engine speed is low, does your meter read frequency? Set for 60 Hz @ speed. I doubt there is a voltage regulator adjustment. This may help
Jun 25, 2009 | Coleman Powermate Premium Plus 6250W...
Low voltage
Most generators use a flyball type governor within the engine to control rpm; also there is a voltage regulator that tries to maintain voltage at about 115v. The voltage regulator varies the voltage to the armature increasing /adjusting magnetic force. Use a meter with htz or freq setting to adjust engine governor to 60 cycles. When the generator is producing 60 cycles, the engine should be turning 3600 rpm, max power range. At 3600 rpm the voltage should be 115 to 120 volts. Loading the generator will cause governor to try to maintain 3600 rpm. Check engine manual for proper adjustment of gonvernor and linkage. The governor mech should last the life of the engine, however governor system does wear out. Expensive repair. enjoy
Nov 26, 2008 | Yamaha Electrical Supplies
NRS Kinetic Road Machine Trainer Logo
Top NRS Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a NRS Cycling Expert? Answer questions, earn points and help others
