Question about Exercise & Fitness
Swich on lights flash once then no functions - Exercise & Fitness
  • 20 Answers
Is the key inserted into the slot of the machine? that would most likely happen if the key is not inserted.
Posted on Apr 09, 2011
Model LC-465B57U flashing power light and opc light
Hi Tracy,
It appears your TV is not sequencing properly. By the order given in your instructions with the controller you are tuning, continue with a code until it satisfies .
Press setup- blinks twice. Enter TV manufacturer code- press enter. Light should flash once. Press on . After it works . Go through all the functions. Up- Down, loudness, channels,& on -off .
Fare .Well.
Dec 12, 2014 | Sharp Televison & Video
2002 chey trailblazer 4by4 light on the swich stay on 2 wheel drive if i put into 4 wheel drive or all wheel drive and one light flash on where ever i put the swich on. feels like is goes in 4 wheel high...
The Transfer Case Control Module (TCCM) in this model year have been known to hang up, try pulling fuse #48 (4WD) in the rear fuse panel located under the left rear seat. Reinstall fuse and see if everything works OK, if not, you probably need to replace the TCCM.
Dec 07, 2010 | 2003 Chevrolet TrailBlazer
VW Golf Mk4 1.4 16v Oil Light Warning on Dash
Measure your oil at normal operating temp, without the engine running of course. This will give you a more accurate reading once the oil has circulated in the system.
The system works like this:
  • With the ignition on, the oil pressure indicator light on the dash should come on and flash. Once the engine is started, the light should go out and stay out as long as the engine is running.
  • If the oil pressure drops below approximately 0.3 bar or 5 psi when the engine is running below 2000 rpm, the light will flash.
  • If the oil pressure drops below approximately 1.8 bar or 27 psi when the engine is running above 2000 rpm for more than 3 seconds, the indicator light will flash and the buzzer will sound.
If either this two warnings occur:
  • The engine should be switched off immediately and the oil level should be checked.
Apr 29, 2010 | 1999 Volkswagen Golf
Blue light flashed on the power swich
Check this site regarding monitors and capacitors. This is very likely a capacitor failure.
Apr 19, 2010 | Computers & Internet
Display is black swich on/off light laptop no work,air work, problem for acer one (mini) cibalis@yahoo.com
hi,
this is one of the repeated problem ,
1.this is a bios problem go to www.support.acer.com.
2. select your model and download bios update driver .
3.save this driver in your flash driver .
4.turn off your device use of power button.
5. use you flash and turn on your device at he same time press function key near altkey and esc key .
6.the power led will blink countinuesly wait until the display power on .
Mar 17, 2010 | Computers & Internet
Cannot turn off the interior lights.
check the door switches this is the push type switch at each door sounds like maybe one is bad ,,like a door is not closed tite hpoe this helps
Jan 08, 2010 | 1997 Buick LeSabre
How can you remove a 5100 error with a canon mp210?
1. Switch off the printer (the button, rather then from wall-plug
2. Press and hold Resume
3. Press Power
4. Holding Power , release and once again two times press Resume , then release simultaneously all button.
5. After indicator is flashing, fall into service rezume.
6. Four times press the button Resume , under each striking Resume indicators are switched: green-orange. Once press the button Power for acknowledgement of the selected action (the unset of the counter pampers). The Button Resume enter prefunction:
- 0 strikings unset main counter in 0%, or
- 1 striking unset additional (platen) of the counter in 0%, or
- 2 strikings installation both counter on 0% .
7. Press Power (is executed service-function, chosen striking Resume )
8. Once again Power - swich off.
Sep 22, 2009 | Office Equipment & Supplies
Blows fuses when parking lights are turned on. Headlights work fine even running lights.
If it only happens when you turn the switchto the parking lights then it is most likely the swich that is the problem. Light swich failure appears to be a common fault with fords
Apr 21, 2009 | 2000 Ford Focus
Flashing lights
the printer when i on the swich the flashing light is on but can't work the printer
Feb 24, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
