Question about Dell Latitude D600 Notebook
When I Switch on the power botton, the power comes on and tends to to boot up but goes off within 3 seconds of power on!. Please, help.
  • Ryan Garvey Apr 04, 2011
    This sounds to be a motherboard issue. Before I am able to clearly answer this. I would need to know if there is any Beeps once the power button is hit.
  • 2,069 Answers
There must be something wrong on the motherboard.. could be hardware or software. first, remove battery, insert in power cord and power it up if it doesn't, have the motherboard inspected for physical damage.
regards
Posted on Apr 04, 2011
I have hp compaq nc6000 every time i switch it on it comes on and goes off within 5 to 10 seconds. there is no display when during yhat time. what could be the pssible cause
From the description this is a motherboard issue, a common problem with hp, at this point I would recommend having it assessed.
Jul 20, 2012 | HP Compaq nc6000 Notebook
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
Photo 1290 Changing ink cartridge
You may have to reset your printer, for when the green an red are flashing. Please do the following in order to reset the printer;
1-switch off printer itself
2-switch off at socket for 20 seconds
3-hold down both black buttons on front
switch on at mains
4-switch on printer itself
green and red flash together
5-now switch off at mains and leave for 3 seconds
6-while holding down both front buttons again, switch on at mains
both green and red flash together so release
7-quickly hold down the left botton, the one with the scroll icon above it.
Hold this until it resets itself, - the print head will re
charge and it will be obvious.
Restting by unpluggin rather than turning off at mains tends not to work.
This must help you as it worked for me.
Regards,
Anirban Mazumdar
Jun 05, 2010 | Epson Stylus Photo 1290 InkJet Printer
Screen going blank on system boot and on switch off/on
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a fraction of seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 08, 2010 | Sony SDM-HS75 17" LCD Monitor
When i turn on my 98 jeep cherokee, the rear window goes down. it is doing this only sometimes. it wont go up with the window button. the windows are electric
could be a faulty switch and or a faulty Partially making contact with the wire especially if the doors are used quite often as over time and use they tend to bend and wear causing a break in the wire ...if you own a test light i would recommend testing the switch for power 1st as it merely pops out by hand but sometimes needs a bit of help and pry up on the top end of the switch ...pull the plug and with the key in the on position check for power to the connection if none is present check the wires within the rubber boot locate where power begins and ends within the power wire they are colored to help identify which one it is /.
also try opening the door while working the switch and see if ant change occurs this will better give you an idea to what i am saying
Jan 06, 2010 | 1998 Jeep Grand Cherokee
Computer will not turn on
Do you hear the hard disk spin up? is there a hard disk boot password configured? can you see a bios screen as it tries to boot? is the light on the power supply lighting up?
May 28, 2009 | Dell Latitude D810 PC Notebook
M system needs to be bang on before it comes on
STOP BANGING IT ! AND TAKE IT APART TO FIND THE PROBLEM YOU WILL KILL YOUR HARD DRIVE !
Mar 02, 2009 | Dell (E210882) Motherboard
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
Changing font on Epson LX-300+
Just switch off your power switch and turn it on again and then press the paper out button for 3 seconds when you hear 1 beep that is the time you can change font using the font button switch and choose the font that want by pressing it.
Sep 15, 2008 | Epson LX-300 Matrix Printer
Booting
Has the fan been replaced? If not then the laptop will power itself off to protect from overheating. The fan is like a switch in the loop. Like old Xmas lights. One not working then none will work.
Aug 30, 2008 | Gateway M305CRV Notebook
Dell Latitude D600 Notebook Logo
22 people viewed this question
Alun Cox
