Question about Garden
Good afternoon,I have Qualcast Panther 30 handpush lawnmower,how do I adjust the cutting height.May I have a step by step instruction. kind regards Paul Braithwaite
3 Suggested Answers
Asbestos 56
  • 191 Answers
SOURCE: how do I adjust the
The blades on you rotary lawn mower could well be dull. I does not take to long for them to become dull. Figure about 8 hours of cutting. They are quite easy to sharpen. The blades can sometimes be sharpened on the machine, but it is much easier to remove the blade. 1 pull the wire going to the spark plug off the spark plug (this is so it won't start with your hands in the way. then tip it to one side. but make sure you do not spill gas everywhere. Then remove the blade there is generally a bolt in the center holding it on - -this bolt of quite often reverse threaded- - your manual will have any specific information on removing the blade. then using a file, bench grinder, or a purpose built sharpener sharpen the blade. It generally is only beveled on one side. don't take off very much material from the blade and make sure it balances before you put it back. Make sure it is on correctly, and that the bolt is properly tightened. No way do you want that geting loose
Posted on Dec 09, 2010
SOURCE: how to assemble a qualcast
Yoy posted this in the Telescope Forum.
Posted on Jun 10, 2011
How do I repair height adjustment on a CMM1200?
The front wheels link to the height adjustment controlled at the right rear wheel. The spring loaded link arm attaches to a pin on the height adjustment control. The link arm has come off the pin.
Tools: Long shaft bladed screwdriver and a pry bar.
Adjust the rear height adjustment so the second to last notch is engaged.
Position yourself with one knee on the front deck. This will allow you to control the height of the front and the back-n-forth movement of the link arm.
Position the pry bar with the short "L" section upwards, under the lawnmower. This will allow you to control the side-to-side position of the link arm.
Insert the screwdriver from the rear of the lawnmower. The rear wheel axle can be used for leverage This will allow you to control the up-and-down position of the control arm.
A little perseverance and you will be able to position the link arm back on the pin. It may be useful to remove the plastic cover of the lawnmower to allow a better view of the mechanism and link arm
Aug 05, 2012 | Black & Decker Cmm1200 24v 19" Cordless...
I need the size of the poly v belt for a qualcast 4000 lawnmower.
Most time you don't have to get original parts like belts from the manufacturer. Suggest you go to a reputable lawn and tractor supply store where they can easily measure the belt and give you a comparable one for your machine. Hope this helps!
Mar 26, 2012 | Computers & Internet
I have a Craftman 19 HP riding lawnmower - used Model 944607192 My question is how do I adjust cutting blade depth since I do not have a manuel
There should be a long lever to your right when seated, move that lever forwards and backwards for height adjustment. Good Luck...
Aug 16, 2011 | Garden
Qualcast Suffolk Punch 35s lawnmower running problems
There is a small idling mixture screw on the side of the carburettor.
As the engine is not well suited to the carb. it mainly runs on the idle setting!
As long as you are not leaving the choke on. This is a little tab on the top of the carb. You start with it set on C then soon set it on the middle position, and after about 3 mins turn it off.
Jul 12, 2010 | York Yankees Bedding MLB Comforter
Can't remember how to keep my Qualcast Suffolk running!
There is a video on u tube and a wed site the old lawnmowers club .
Jan 10, 2018 | Garden
Engine cut out!
could have water in fuel bowl or tank,coil could be heating up and stop firing or the plug
Sep 09, 2009 | Garden
My mower is not cutting level. I have a new base
If the baseplate meets the cutting cylinder across the entire cutting width, it's adjusted properly.
Check that the front roller is level - it usually IS as simple as that.
If the roller has ben replaced with wheels, check that they are the same height.
Aug 22, 2009 | Garden
MODEL 5521 RS
hi have a 550 horsepower lawnmower and the height adjuster handle has broke where do i get my hands on a new one anybody out that can help please let me know thanks mossieirwin@hotmail.com
Oct 14, 2008 | Husqvarna 160 CC Honda OHC Engine 21 in
Garden Logo
292 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
