The wireless button is non functional can not acess the wireless
Tip
How to Acess the update screen on your Dell Axim PDA
hold down your power button and your wireless button both at the same time.
then press your reset button on the back of your Dell axim and release your reset button quickly, but keep on holding the power button and the wireless button until a white screen pops up saying something about updating.
If a screen comes up about resetting to factory default, get out of that screen.
on Apr 10, 2010 | Dell Axim X50 Pocket PC
Tip
Acessing Menu with universal remote
We used a One4All model URC3021BOO remote. We programmed BOTH the TV function and the DVD/vcr button with code 0807.  To access the menu PRESS TV then MENU button then DVD/VCR button will allow you to change menu functions using left and right and select buttons. *TV button will access Menu screen BUT NO menu functions. * DVD/VCR button will NOT access menu screen but WILL control menu functions if menu is already displayed. May work with other sharp products, or other universal remotes? These original (RRMCG1330PESA) remotes run 38.00+ to buy new so try this FIRST!
on Oct 29, 2008 | Sharp 13VT-J100 13 in. Combo
How to use cwa-854 other than bridge mode?I would like to have an internet access point obtained with user name and pasword where i can conetct more than one comp (ip obtained automatically)?
Two aspects have to be considered to establish a network with brideable functions
1. The computer infrustrure have to be built, for example the computers have to be connected to each other by physcal cables to achieve the first steps the the second steps requiring wireless functionality.
2.The wireless devices like modems transfer signals between the two device to communicate otherwise would have communicated by wire connectivty of cables. The wireless device creates a bridge between the two devices also called an access point located on the computer networking area ( open my computer, click system settings and select networking functionality for any alteration purposes)
3.Once each device in the connection is ready functioning, the access point becomes visible message that could be manipulted by the computer administrator.
4. Clicking on the system networking settings will allow customisable features explanable
a. The network area would have the option of creating passwords to every device for reasons of that each device on the network is a separate entity only possible to achieve connectivey by another device providing wireless capability.
b. manipulate the wireless features that would only be displayed after each gadget on the infrastructure has been phically connected with wires amongs one another and to power supply in which instance to be powered on.
c. the modem once powered on should recognise an available computer physical establishment because wireless chips are embeded in every entity of the setup.
d. The computer display of message about wireless signal recognistion is then manipulated to suit the administrators specifications explanable.
1. A user name and password are established for reasons of contolling access to the connection of several devices
2. The device could function without passwords and username only becomes available to every demander making possible connectivty so several untilities and infructure.
Important notes
1. Your computer set up of networks are a network that when capable of communicating elswhere with additional networks insfrustures together is an internet.
2. Rememer to setup your newkwork properly or esle access could not be made into another network and vise versa.
3. If you set up any passwords and user names in the process of establishing a network,, other persons requiring connectivety woudld requrre what is called Codes in computer temnology to acess the network. whenever the passwors are lost would compromise your acess to the link of wireless signals as well.
Dec 02, 2010 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
Need to secure it
their is a security function in every wireless adopter enable it fronmits setup if you have a router acess it from192.168.1.1from your brower
Aug 16, 2009 | NetGear Computers & Internet
No factory remote i can't acess to the menu system
Most televisions and monitors have a menu button next to the power, volume, and channel buttons on the face, top, or side of the set. It can be a pain but you can usually press the menu button to bring the menu up and then select and change settings by pressing menu again to choose a setting and using the channel and/or volume up and down buttons to raise or lower the setting. The exact function varies based on the set so you may need to fiddle around a bit. Unfortunately some sets do require the remote to perform some functions.
Jul 02, 2009 | Toshiba MV13L2 13 in. TV/VCR Combo
Wireless internet on my computer is switched off
If you're using a laptop, you need to turn on the wireless switch. For most laptops, there is a wireless button or the combination of Fn + F2 keys.
Jun 16, 2009 | Computers & Internet
How do I acess the video in function. all buttons are in chinese.
oh!you need a translator.just kidding.if you can find same model with the english version the better.or you can push each button to know what happens.
May 07, 2009 | Televison & Video
Wireless Connection
delete all aspects of this wireless installation.make sure wireless button is turned OFF, connect via wired. make sure you can get into internet function. ensure toolbar has an icon that shows ' wireless', disconnet wired cable and turn on the wireless button. do a ''connectivity doctor scan' and see if any wireless devices in your area for secured/non-secured status. turn off wireless for now and reinstall device software driver.
Jun 29, 2008 | Toshiba Satellite M35X-S311 Notebook
Rookie attempting to connect two computers via router wireless
to make sure its setup properly you should reset it up, to do this press the reset button on the back of router, and then when its up to a ready state acess it through your web browser. the adress is 192.168.2.1 ,then click the login button, the defualt password is blank. after that your are logged into the router you can run the setup wizard located on the left hand side of the page. once setup is complete you should be able to acess the internet.
Jun 09, 2008 | Belkin (F5D7231-4) Wireless Router
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
