Yahoo will not connect but all other programs are working.
  • 3 Answers
Try reinstalling yahoo again or install a new version of yahoo messenger.
Posted on Apr 04, 2011
Cant log in to yahoo messenger
First, make sure your internet connection is working properly. I assume it is as you are posting on this website :) But just in case...
Yahoo's messenger network may be down due to technical issues. I would recommend visiting their messenger site to check.
http://messenger.yahoo.com/
I recommend checking that you have a messenger account created and you are using the most recent version of the program, which you can do both at the link above.
If all the above is fine, you may have a program blocking the messenger program such as a firewall or anti virus program. You can try creating an exception for yahoo messenger with in your firewall or anti virus program.Or alternatively, disable them to see if this resolves the problem!
Regards,
G33k
May 05, 2011 | Yahoo Messenger
Tip
Yahoo Messenger can't sign in - Unable to Connect to Yahoo Messenger
If you are having trouble signing into Yahoo Messenger you should read this article for some Tips and Tricks to get signed in.
There are a couple of things you will want to check first as they are common causes for being unable to sign in.
1) Make sure your internet is working. The easiest way to do this is by trying to visit other websites. After you have tried to visit some websites(it is best to test sites you have never been to before) and you confirm your internet is working but still unable to sign in, then continue to the other tips.
If you can't connect to other websites, you can read my tech article on Resolving Internet Connectivity Issues - "Can't connect to the Internet"
2) Sometimes, Yahoo Messenger will be down completely for everybody on a global level. This can be caused by problems Yahoo may be having or just general technical maintenance. Your only option if this is the case is to wait until it is over. You can confirm the Yahoo Messenger status at the Yahoo Messenger Support page.
If none of the above are the issue then continue below with Advanced steps
1) This tip is a recommendation from Yahoo Tech Support
1. Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "Firewall with no proxies" option.
3. Select the correct Internet connection type and country from the pull-down menus.
4. Click the "OK" button at the bottom of the window.
5. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
6. Enter your Yahoo! ID and password and click the "Sign In" button.
The above configuration works in most situations. (However, if you connect in this way, you won't be able to use the Voice feature.) If this configuration doesn't work, follow these steps:
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
If neither of the above options work, you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps:
2. Enable the "Use proxies" option.
3. Enter your firewall or proxy server's address and port number. Contact your network administrator (if you're at work), or your Internet service provider (if you're at home) to determine the correct firewall and proxy settings.
5. Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the "OK" button.
2) In some cases you may have a local firewall or anti virus program that is blocking Yahoo Messenger or causing connectivity issues with it. You can try to disable any Firewalls you have and Anti Virus programs and see if you can now sign in. If so, then you will probably need to add exceptions in your firewall or anti virus program to allow Yahoo Messenger. If you need assistance with this step you will need to reach out directly to the company that makes the software. A google search by the application name or company name will bring you to the website where you can find help and contact information.
3) I have worked in Technical Support for many years and a simple but often overlooked step that works is to unistall or reinstall the program. There can be any number of causes for Yahoo Messenger program files to be corrupted or lost. A simple reinstall of Yahoo Messenger can get you back up and running. The best way to do this is through Control Panel in Windows.
-Go to Control Panel > Add and Remove Programs and find Yahoo Messenger in the program list.
-Click unistall and once removed go ahead and reboot your computer.
-Once rebooted, download Yahoo Messenger and install. Click here for the files.
-Once installed, reboot your computer again.
-Once rebooted try to launch Messenger and see if you can sign in.
4) At this point, if you have exhausted all the above steps, I recommend you contact Yahoo Messenger Tech Support directly. Click here for Tech Support.
I hope my article was informative. Check out some of my other Tips and Tricks by clicking on my Username at the top of this article and then going to "Tips" under my profile.
Regards,
G33k
Keywords
unable to sign in to yahoo messenger, can't connect to yahoo messenger, can't sign in to yahoo messenger, yahoo messenger not working, connect to yahoo messenger
on Jun 05, 2011 | Yahoo Messenger
My yahoo has occured a problem with the http connection how can i fix this..
If u have new yahoo look out or the old yahoo there is boot file hooked to it
left click start go to ((control panel)) left click
control panel this is your control panel views
1) if you have classic view left click programs and features left click to open>>>>left click yahoo to unistall
or
2) if you have the Control Panel Home under
program left click ((uninstall a program)) delete yahoo there
{ now go back to start left click ((( search ))) }
{ type in yahoo delete all yahoo files there }
restart your pc
go to www.old version yahoo messenger .com get an older version 8.1 works the best
works better than the new yahoo too much **** to down load
after this go back to control panel
delete(((( yahoo updates only))))) that way yahoo cant change anything on your pc
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 13, 2011 | Yahoo Messenger
Yahoo Messenger Your computer is not connected to the network
When I try to make video or voice call with yahoo messenger I have this error
"Your computer is not connected to the network"
On both computers is installed yahoo messenger 10 same
May 09, 2010 | Yahoo Messenger
The message i type and accumulate doesn't appear in the box
There are generic problems on yahoo. Please be patient.
Jan 24, 2010 | Yahoo Messenger
Yahoo messanger say internet connection not connected
I would like to help you with your issue. but we have to check the following first
http://webmessenger.yahoo.com/ try log into the Web Messenger
> Step 1: Test Your Internet Connection
> Step 2: Verify Your Yahoo! ID and Password
Open Internet explorer and www.mail.yahoo.com
Check by sign in to you account
> Step 3: Test Your Access to Secure Pages
Make sure that you can access secure pages from Internet Explorer
Try to sign in to Yahoo! by going to the Yahoo! sign in page and enter the same Yahoo! ID and password you were using before.
> Step 4: Verify Credentials
Verify that the same Yahoo! ID and password you used before in the last step also works in the online version of Messenger, Yahoo! Messenger for the Web:
> Step 5: Check Connection Settings
Click the Messenger menu and select Connection Preferences.
Click Connect directly to the Internet, and then click OK.
Check by Changing the connection type to a connection via a proxy server:
Click Connect via a proxy server, then under this option, select HTTP proxy, and then click OK.
Last is Uninstall all the Yahoo Tool Bars and Yahoo applications , Yahoo Messenger, and Yahoo Updates from Program list i.e Control panel - Add/Rem Programs ..
And reinstall the Yahoo Messenger again -
Hoping the above info will be useful for you
Jan 20, 2010 | Yahoo Messenger
Why do my contacts say the same thing almost word for word? sounds like they are not real
> Step : Test Your Access to Secure Pages
> Step : Verify Credentials
> Step : Check Connection Settings
When someone sends me an offline message on yahoo mobile messenger the message is duplicated
I cant insall yahoo messenger. it says: incorect command line parameters and portions of this software are based in part on the work of the independant JPEG group, and it also says this application failed...
from www.yahoo.com
Jan 19, 2010 | Yahoo Messenger
Why won't IM let me sign in? It keeps going to sleep
Jan 18, 2010 | Yahoo Messenger
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
