Question about Toshiba Televison & Video
Hello my tv keeps turning off on its own and when it goes back on the screen is back you can heat the audio only... the res light is on but the green light is flashing.. thank you
  • 3 Answers
There is a hardware problem in your T.V.Repair it from a mechanic.
Posted on Apr 04, 2011
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
When I try to turn the TV there is a click and the green power light comes on for about 4 seconds, then the green light goes off , it then turns on again and then goes off, it then comes back on and then...
Hello
Your TV has horzontal output problem I thinks. It may be due to Line Output Transformer {LOT}; fault or its drive transitor fault. If LOT has trouble; its drive transitor also will get overheated,and finally will go leaky. You just open your Tv, and locate the line drive transistor mentioned above. It can be easly located very near to the LOT and will be three leged component, in black colour, screwed onto a metal heatsink to radiate heat out of it when working. Just resolder it out from the circuit board, and check it for colletor to emitter leak. Anyway replace it with a similar type and number, and see the effect. After replacing it, switch on the TV for just 5 seconds of so, and feel the heat gentated from it. It may be warm, but not get heated more. If it overheats, it is a clear evidence of LOT shor, and it also shoud be replaced with similar type and number. Insist on similar type and number for both the above said components, since they are critical parts of any Tv. Never use substitutions. They may work, but it will effect the clarity of the picture. OK.
Nov 09, 2010 | RCA F32650 32" TV
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Some games won't run on my PS3 40mb
Hello.
All games should run regardless of the settings. Are they PS3 games or games from the PS1 or PS2? That could also make a huge difference. The 40GB PS3 is not fully backwards compatible. Also, if they are PS3 games, try the reset default video settings. That might even work. Here is how to do that.
Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
I hope this helps. Good luck!!
Jul 24, 2008 | Sony Playstation 3 (PS3) Console
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
Sony tv KDF55WF655
same problem... tv turns on and off repeadly while the green light flashes. seems as if the tv keeps restarting. please help.
Dec 13, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
87 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
