Question about Pioneer PDP5016HD 50 in. Plasma Television
Pioneer plasma model pdp505pg stuck on stand by when i try to turn on my plasma it goes on stand by
I have a Pioneer PDP505PG about 4 years old. About a week ago it started flashing every 7 seconds until it went into standby mode. I turned it off and the next day it worked fine. Last night it did it...
You need to try a hard reset of the television (unplug the set for a couple of hours and plug it back in). If that does not work, you most likely need a new power supply. the safe mode is preventing damage to the unit if the power supply is not working.
Let me know if you need help doing that yourself. You may want to try one of our nearby professionals.
Ken
Jun 24, 2008 | Pioneer Televison & Video
My hp tv wont turn on
hi it sounds like your plasma has gone in stand by mode look on youtube will tell you all about stand by type in how to fix and tv make model stuck in stand by more than likely capacitors blown if your not any good soldering boards id phone tv guy out but if you are then youtube it hope this hopes
Mar 04, 2018 | HP PL5060N 50 in. Plasma HDTV
I have a Pioneer PDP-5030HD plasma and the plasma display does not turn on. The standby/on power indicator light on plasma display is blinking red (after turning it on with my remote, it turns green for a...
First check batteries in the remote are charged.Try pushing one of the channel selection numbers on the remote as it may be the off/on on your remote is stuck or has died completely. if this does not fix the problem try unplugging the set from the wall wait 5 mins (approx) and re plug into wall socket and try turning on .
Oct 25, 2017 | Pioneer PureVision PDP-5030HD 50 in....
Tv won't come on...light in corner just blinks red
OK Its your power supply and it can be fixd for free due to a recall.
PLEASE READ BELOW what I found out.
Here's the whole notice:
Important: Free Power Supply Replacement for Certain Pioneer Plasmas
Pioneer is continuing to offer a free, in-home power supply replacement for certain of its second and third generation plasma models listed below for consumers who experience a problem with the original power supply. If a consumer model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded in your home at no charge.
Consumer Plasma Models (12 listed):
PDP-505HD
PDP-503PU
PDP-5030HD
PDP-5031HD
PDP-433PU
PDP-4300
PDP-4310
PDP-4330HD
PRO-800HD
PRO-800HDI
PRO-1000HD
PRO-1000HDI
The issue with the power supply in the plasmas listed above does not pose any health or safety risk. Pioneer has received reports that the power supply in the affected models may fail. In some cases, a loud popping sound can be heard when a power supply fails. After the power supply fails, the plasma is no longer operable.
We apologize for any inconvenience, and we thank you for your cooperation.
Apr 02, 2010 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Monitor on switch goes onto green for 3 seconds and then turns to a flashing red, which flashes 5 times quickly,and repeats every few seconds. model is pioneer plasma display system noPDP503HDE
Thats a Factory shut down .... caused by a fault usually the power supply
Sorry it's a factory repair issue
make sure all the connections are tight
and try one more time .... sorry
LB
Sep 19, 2008 | Pioneer PureVision PDP-503HDE 50 in....
Pioneer PDP-435PG
I buy receiver of the plasma pdp 435pd my e-mail it is sergiofleitas@yahoo.com.ar
Apr 20, 2008 | Televison & Video
Pioneer PDP5016HD 50 in. Plasma Television Logo
333 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
