Question about All-Pro Propane Garage Shop Heaters - All Pro SPC 125 Forced Air Propane Space Heater
I have an All-Pro SPC 40 forced air propane heater. The thermocouple on it has finally gone bad. I purchased a "generic: thermocouple from the hardware store, but it appears this will not work because the thermocouple which I am a replacing has some sort of sensor unit attached to it. Do you know where I can buy the proper replacement thermocouple for this unit?
    Brigadier General:
  • 4,736 Answers
Yes, I do. Master Distributors stocks parts for All Pro heaters. http://www.masterparts.net/
Posted on Apr 04, 2011
Www.masterparts.net
6654 TC 13" 40/85/125 113884-01 RDLP85V, SPC-125,SPC-85,125-F,85-FAC
Posted on Nov 16, 2011
Where to find a thermo couple for all pro spc40
It could be your thermocoupler or the thermoelectric valve. Contact the company below for your troubleshooting and parts. I am sure they can help you.
Good luck....Jim
www.theheaterguys.com
Feb 19, 2011 | All-Pro Propane Garage Shop Heaters - All...
My all pro heater will only keep burninig if I push and hold the red fuel button in,so I rigged it in a way that the red button stays pushed in.my question is : can this be dangerous,please no PC answers...
The fuel button allows the heater to burn long enough to warm up the thermocouple. If the thermocouple doesn't sense a flame it shuts the gas valve to keep gas from building up to potentially explosive levels it the heater should go out for some reason. Do yourself a favor and replace your faulty thermocouple. It's cheaper than a new house or building.
Jan 06, 2011 | All-Pro Propane Garage Shop Heaters - All...
My all-pro propane heater will not stay lit for over thirty seconds after I release the red fuel start button,before the flame goes out it makes an air hissing noise right before it shuts off.Heater will...
This sounds like a problem with your thermocouple.
Just remove the end of the thermocouple from where is goes into the gas valve and leave the end that goes into the flame in place.
Clean the end of the thermocouple connect by scraping off just a little metal from the end just about there the nut tightens the thermocouple into the gas valve. After you have exposed some new metal do the same inside the valve where the thermocouple seats into the gas valve.
Use a small pic or similar item to scrape inside the gas valve to expose some new metal there also.
Now reassemble the thermocouple into the gas valve and see if the heater works.
Here is a link with some more instructions.
http://www.msservice.net/ts/reseat_thermo-clean_pilot-ODS.htm
If this does not solve the problem you may need a new thermocouple and you can find that at www.desaparts.com
Thanks
Jan 04, 2011 | All-Pro Propane Garage Shop Heaters - All...
SPC-40 wont stay lit
Problem is either the thermocouple or the thermoelectric valve. I have one of these as well with the same problem. On mine it is not the thermocouple. I have replaced the thermocoupler and still have the problem. A thermoelectric valve is $42.25 at http://www.masterheaters.com/propane/
Im looking for a cheaper part. Any suggestions?
Gru es 1234 @yah oo.c om
Jan 12, 2010 | All-Pro Propane Garage Shop Heaters - All...
Heater won't stay lit after releasing yellow button
you need to replace the thermocouple at the burner tip it will be a copper line with a bulb in the flame tip with a copper tube leading back to the gas valve and it senses the flame and keeps the gas valve open
Dec 24, 2009 | All-Pro Propane Garage Shop Heaters - All...
SPC-12 SPACE HEATER WON'T STAY LIT?
When holding button in,you are overiding themocouple funtion. You probably need to replace the thermocouple
Feb 27, 2009 | All-Pro Propane Garage Shop Heaters - All...
All pro spc-85
going through the backplate to the nozzle location is the thermocouple. it is a copper like tube that sits back from the actual flame. if you are looking for a replacement go to www dot desatech dot com.
Dec 11, 2007 | All-Pro Propane Garage Shop Heaters - All...
All-Pro Propane Garage Shop Heaters - All Pro SPC 125 Forced Air Propane Space Heater Logo
1,109 people viewed this question
Top All-Pro Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
