Question about Mtd Drive Belt 42"
My MTD riding mower is losing power to the rear wheels when pulling an incline. It will come to a complete stop. the engine RPM and blade rotaion do not seam effected. What am I over looking?
    Brigadier General:
  • 3,911 Answers
Normally sign of a failing hydrostatic transmission. if your mower has one, start looking for a new one, mower that is as a new tranny will cost more than a new mower.
Posted on Apr 04, 2011
  • Johnny M Pool
    Johnny M Pool Aug 12, 2015
    Sorry sir, but that's not true. I have a Craftsman DYS 4500 that I purchased in 2009. I have put over 400hrs on it. My hydrostatic tranny got to the place where it would not go when it got warm. I Changed fluid, belts etc. Finally I purchased a new hydrostatic tranny from Sears Parts Direct. The price..$526.00. I don't have another $2000 dollars for a new mower. but I did have the money to purchase another tranny. The mower is fine now. However I would like to have the original tranny rebuilt and be kept as a spare.
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
Self propell not working right
Leave aside all the puffery about 3-1 and such, you described a front wheel drive (pull) walk-behind (FWD), but are asking why the rear wheels won't propel. When you push down the hand grip the front wheels should spin free. Whan you lower from wheels by releasing pressure on hand grips, turning wheels lowered to ground should propel the mower along with its unpowered rear wheels now turning be ground contact. Reminder, never, ever lift rear drive wheels of any mower off the ground while walking behind with engine running:
  1. You could be struck by blade propelled object.
  2. You could pull mower and spinning blade backward onto your feet.
  3. You could lose balance and be pulled forward in a fall.
Contemporary FWD mowers are recognized by a black chain housing on deck top leading from engine to left front of deck. RWD propelling chains are situated underneath deck so cannot be seen from above.
Jun 25, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
I have a Honda HRR2165VXA mower that is having issues with the smart drive.
hello, hello, Drive belt replacement for front drive mowers. remove the belt coved on top of deckand clean out grass,turn mower on side where carb is facing up,use a pair of vice grips on side of mower deck so the blade can stop,remove the blade,remove the belt cover and clean out the grass,remove belt from rear and front pulley pulleys. install new belt,put belt cover and blade back on,put front belt cover on, should work,if that is not the problem; wheels will not prepeal the mower,wheels turn only when raised off ground, Check the gears or groves on the inside of the wheel for access wear that is a common problem,check the axle drive gears to make sure turns ok, to check gear box if ok pull mower back wards while drive is engaged,if wheels turn backwards than the trams is bad,all of this is caused by the operator,by not disengaging drive while pulling mower backwards or by holding mower back not allowing to propel self completely,hope this helps,any comments welcome,thank you.
Feb 15, 2012 | Garden
Mtd yardmachine 7 speed shift to go is my mower. it runs but want pull. does it have 2 belts or just the deck belt. the deck belt has more play than normal ..i think. as i was cutting the grass it stopped...
There are two belts, one for the deck and one for the main drive. The main drive belt can be seen on the upper pulley under the engine. Check to see if it has slipped or broken.
Aug 02, 2011 | Mtd Garden
I have an mtd riding mower that will not crank. I am not getting current to the starter. I have replaced the switch completely and checked all the fuses and connections. Any suggestions ? I have also...
If any of the following safety switches are not properly made, the mower will not turn over.
Brake/clutch switch. Blade engagement switch.
Gary
Jul 11, 2011 | Mtd Garden
I have a mtd mower grinds going into gear and the blades run constantly .what could be wrong i put on new belts
Hi these machines have to hve the drive belts stop completely for them to go into gear smoothly, Also if non genuine belts are used it will cuase a lot of problems. There is so many variations between different models of mtd units. To check if you have the right belts you can check it up on a site called pats small engines.
Sep 11, 2009 | Garden
Mtd 17.5 will not start
Riding mower have three safety switches. One under the seat, one under the clutch and one on the blade lever. Make sure all are making contact as the button tip can get worn after many uses. These can be replaced. One trick you can try before that..
Sit on the mower and pull the blade engagement lever back further than necessary and hold it in that position while trying to start it. This may work as it puts more pressure on the safety switch button and makes contact possible.
May 21, 2009 | Mtd Products Yard Machines 158CC Tiller
Remove rear wheet
YOU'LL NEED AN EXTENTION FOR A SOCKET,BUT 1'ST REMOVE THE LITTLE CAP AND REMOVE THE COTTERPIN,MAKE SURE IT'S IN GEAR IT WILL KEEP THE WHEEL FROM TURNING.hope this helps
Apr 25, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Mtd Drive Belt 42" Logo
620 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
