Keep getting error message Code 100-2105 when trying to scan and print Printer is Kodak ESP5250 have tried recommended solutions but no result.
  • alan caton Apr 07, 2011
    Thank you. Problem now solved. Very grateful.
  • 30scanman667
    30scanman667 Feb 09, 2012
    I had the same problem...The following solution worked for me.
    http://support.en.kodak.com/app/answers/...
    From your computer desktop, select Start > Run.
    Type %windir%, then click OK.
    Double-click the twain_32 folder.
    Right-click the kodak folder, then select Delete.
    Insert the KODAK All-in-One Printer Software CD into the CD drive, then go to D: > printer > scanner.
    NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
    Double-click aioscannr.msi, then follow the instructions to remove it.
    Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
    Start Home Center Software.
    Select Scan Documents and Pictures.
    Scan a document.
    If the error continues using a Wi-Fi connection, make sure you select the correct printer in Home Center Software.
    If the error continues using a USB connection, see the following section to reinstall the printer.
  • 668 Answers
Follow the steps mentioned below:
Close Home Center Software.
Clear the printer of any error conditions.
Upgrade the software and firmware for your printer.
Make more system memory available by closing programs other than Home Center Software.
Clear the Picture tray and then add your pictures or videos back to the tray.
Check that the pictures are supported file formats.
Hope this helps.
Shane
Posted on Apr 04, 2011
Error Code 105-100003
1 Wireless connection
  • Turn off the printer.
  • Wait one minute, then turn it back on.
2 USB or Ethernet cable
  • Check the connections.
  • Turn on the printer.
  • Make sure that the print queue is online.
afor more help visit CBR Tech Solutions
Oct 12, 2012 | Kodak ESP5250 All-In-One InkJet Printer
Error code 3604 Cartidge not recgnized
Easy Solution. Dont buy Kodak. I did and they drove me crazy. I bought a Brother,,,great. and no chips on cartridges to carry out big brother ops.
May 16, 2012 | Kodak ESP5250 All-In-One InkJet Printer
Cannot clear error code 3523 for Kodak ESP 9200 Series all in one printer. Have followed all instructions per Kodak online
Had the same problem error 3523 that would not clear. Tried Kodak support with no results so took matters into my own hands.
Noticed the top tray seemed jammed into the printer. Tried pulling it out but it seemed locked. Flipped the printer over, removed 8 screws, 4 metal plates.
Removed bottom tray, set aside. Remove 3 screws for plastic bracket that holds top tray. Move bracket over, be careful not to damage wires. Remove top tray and reinstall so that it is in extended position. There is two notched in the side of the top tray. Extend so that catch is in back notch.
Reassemble everything in reverse order. Take care that the top tray does not slide into the printer when you turn the printer over. It did for me the first time that the tray jammed again.
Replug everything and startup the printer with top tray extended past bottom tray. The printer will tell you that top tray is jammed, push top tray flush with bottom tray.
Printer now works. Don't know why tray jams in the first place but this solution can keep you from scrapping printer or paying for service.
Very disappointed with Kodak printer. Obviously printers were not their core business and they paid a sub-contractor to build these products for them. My next printer will be an HP.
Jul 24, 2011 | Kodak ESP5250 All-In-One InkJet Printer
Printer works but only color is printing, the black is faded and only partially printing. I have tried 3 new print cartages and it still does not print right. No error message
The print heads for the black cartridge are probably plugged.
You can try using the software to clean the printheads. Go to the Kodak AIO Home Center and under "Maintenance" there will be a button that will allow you to clean the print heads. If you don't notice a difference after 2 or 3 cleanings you will have to remove the print heads (youtube video here: http://www.youtube.com/watch?v=n1AYgfPHy0o) and clean them with warm water and some Q tips.
Mar 06, 2011 | Kodak ESP5250 All-In-One InkJet Printer
Kodak AIO Easyshare 5300 scanning problem
Could be USB connection if you have another cable try it. Try connecting to different USB ports on your PC. If you have a Powerd USB hub lying around try connecting the printer to the PC through that.
Also try disconnecting all USB devices including the printer. Reboot your PC. Connect only the printer and try and scan.
Some times multiple USB devices dont work when they are both connected to the same PC.
Hope this helps!
SDtester
May 20, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Nothing works right
It seems like ur having image quality issue.... Try resetting the printhead first if nothing happens ask for a printhead replacement
Apr 07, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Can't scan with Kodak Easyshare 5300 printer
My Scanner (Barely used, not even through the first set of ink cartridges yet) was working beatifully. Then all of the sudden the same thing happened to mine...blinking lights...Power light flashing Yellow...I contacted Kodak and they had me do the same old thing...Unplug, uninstall, reinstall, restart. Nothing works...They also try and have you redownload firmware (But Hello....You cant if the printer isnt ON!) So I went back to them again to say none of it worked. They said its the print head and they are sending me another one. Ive read a lot of terrible reviews of this printer just because of the crappy print head...You would think they could fix that by now, or have 5 extras in the package when you buy it.
Feb 27, 2008 | Office Equipment & Supplies
1,827 people viewed this question
jasbo
jasbo
