Question about Hotpoint Washing Machines
My hotpoint washing machine is not registering the door is closed so it will not start the programme
  • Hotpoint Master
  • 17,129 Answers
If the door is closed and the limit switch is contacting to the program controller to start then the program controller by default must initiate the inlet valve to open and allow the water to flow into the washer. So check voltage at the inlet valve if voltage is present without the valve functioning the valve is faulty. Also unless water flows and the water level is detected only then the program will initiate the motor.
Posted on Apr 04, 2011
My hotpoint aqualtis model number aq9f 492 u is showing f6 what does this mean
F06 Door lock fault
Issue: Washing machine door cannot be opened or closed / when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
Dec 29, 2015 | Hotpoint Washing Machines
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
Hi, I have a Hotpoint wm53w first edition 1200 and the door light does not come on when the door is shut. When I switch it on and set a programme, the amchine sometimes does not start, the door light
Generally the problem lies with a faulty door interlock switch rather than a programmer fault. These are can be purchased easily but don't be fooled into buying cheap alternatives, and if you are a competant diy person no problem to fit.
Feb 27, 2014 | Hotpoint BWM12 Front Load Washer
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
Door lock light will not come on even though door locked and hence no programmes will start hotpoint wf250
There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 18, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Wmf720 hotpoint washing machine,after loading the washer and shutting the door,i switch on the machine it doesn't start the programme.....what is happening is the word door is flashing on the screen and...
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest, sorry ;-0(
Good luck,
John C
Mar 30, 2011 | Hotpoint Washing Machines
Hotpoint Aquarius
I have a hotpoint aquarius washer/drier. I don't know if this will solve your problem but I know with mine, this almost always happens, the only way I can get it to start is by firmly pushing the door a few times around where the lock is, once I hear a little click inside it will start ok. I presume its because it wont start as it isn't registering that the door is closed, the only time it does not do this is if I literally slam the door really hard. Hope this helps you!
Sep 13, 2008 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint ultima plus washing machine door wont open after wash
Hi,I have a 2nd hand Hotpoint Ultima digital washing machine & cant seem to use it as when i turn it on on display screen the childlock icon flashes & beeps,even when door is open/closed,when i select a programme the icon still flashes & beeps therefore i cannot use machine.hope you can help me with my question Thanks.GILLI37
Apr 14, 2008 | Washing Machines
Washing Machines Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
