Question about Craftsman Garden
4500 craftsman 42'' cut lawn mower,changed fuel fllter,cutting grass,mower starts cutting off like it's not getting any gas to the carb, it has pump with 3 outlet at top of motor that gas lines feed into ?
    Novelist:
  • 111 Answers
That is the fuel pump. It feeds the fuel into the carburetor. I would take off the fuel bowl and see if there is any water in it. (1/2 in socket will work) Also you can take the line that goes to the carburetor off at the fuel pump and turn the engine over a couple of times and see if the fuel pump is working correctly. (shooting fuel out as the engine turns over) If the fuel pump is working ok, then I would suggest that the problem is with the carburetor.
If you find water in the fuel bowl, then there is most likely water in your fuel tank as well. Wal-Mart sells HEET, which will help to remove and burn the water from the fuel system. It may pop and sputter as the water goes into the engine. But keep fresh fuel handy and you can run the engine close you your house at full throttle and choke the engine if it starts to die, and run it until the fuel tank is dry. Then you can add the fresh fuel into the fuel tank ( I would add some more HEET to the fuel to help remove all of the water). Your engine should run like normal again.
IF you do not have any water in the fuel bowl and you have a couple of wires running to the bottom of the carburetor, then it could be the fuel solenoid is acting up and needs to be replaced.
If that is the case you will need the MODEL, TYPE, and CODE off of the OHV cover. It is stamped into the metal.
I hope this helps to answer your question.
Posted on Apr 05, 2011
Why will lawn mower not keep running?
I would say you probably need to clean or change your plug. And maybe even change your oil/gas mixture. Try some carb cleaner also. It's probably a simple problem to get it running normally again.
Also...if a lawn mower is getting clogged with too much grass, it can stall out on you. Don't try to cut too much off at once, if you've let it get overgrown. Cut off only a couple of inches at a time. Which means, you may have to cut your lawn several times to get it where you want it..You'll also have less chance of ruining your lawn by cutting it this way too. Plus, no more tumbleweed laying on your lawn when your done cutting it.
Jul 03, 2014 | Craftsman Garden
Craftsman LTS 1500 lawn mower - model # 917.28903 started sounding funny while i was cutting VERY high grass. I turned it off immediately and it backfired as it shut off. Wouldn't restart. Waited til next...
I would check the big three first of all. Spark, compression and fuel. Sounds like you have spark and fuel. I would get a compression tester to check actual amount of compression. If all three of those things are good I would check valve lash. You will need make, model and serial number of engine. If you post these I can help find specs for you. Good luck.
Sep 14, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Carburator floods
Possibly the needle valve in the carb. fuel bowl.
Jun 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding mower clicking noise - wont start
RIDING MOWERE JUST CLICKS AND WON'T START HOWEVER IT WAS RUNNING FIND JUST 5 MIN. BEFORE I TURNED OFF.
May 22, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
My Craftsman 15.5 hp 42 in deck lawn tractor starts up and will run for few minutes, then cuts out really bad and dies. I have installed a new spark plug, new fuel filter, cleaned the air filter, and...
Sounds like dirt or water in your fuel system. Have you drained the bowl on the bottom of the carburator? There is a small bolt on the bottom of the bowl; be careful not to over tighten it. If you find anything but fuel in the bowl you may need to drain your tank as well.
Apr 29, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have an 18 HP Craftsman tractor (model 917255980) that will not start. If i remove the fuel line from the carb, gas does not run out freely, hoever, by applying suctin on the line gas does flow breifly....
The pump is not good,to test it,you take out the out fuel pipe start the engine ,see if fuel is coming out fully to the pipe,if sometimes it comes and cut,this means the fuel pump is not working properly.You have to change it.
Sep 06, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Won't start after killing the motor
May need more info. Check for a seat switch to have came unpluged (wiring) this is a safty thing. You have to have your foot on the brake as you sit in the seat to get it to crank. repost if you need more help.
Jul 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftmen mower doesn't cut well on right side
Sounds like you may have made a common mistake, getting one or both of the blades upside down.
Jun 28, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
272 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
