It make noise when initialising then comes up with dis error code 59.fo
  • 17,129 Answers
If the printer is not responding there are errors in the driver software and so there is faulty communication. So remove your printer from the PC and un-install the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Check the position of cartridge drive and the transport of paper
Posted on Apr 04, 2011
GOT ERROR CODE 59.FO, HOW TO FIX THIS PROBLEM
This indicates an issue with either the transfer belt or the sensors that monitor it. Does the transfer belt turn freely if you turn it by hand using the gear on the side? Do not touch the belt surface.
Sep 08, 2016 | HP Color LaserJet Professional CP5225dn...
Hp laser jet pro 400 m401 printer 59.A0 error
i have nOt used this site before but i believe they do have a description of the error code you describe. it said problem is defuser or main motor error, heres the link
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP LaserJet Error Codes 50 59
Apr 20, 2016 | HP Office Equipment & Supplies
Hp color laserjet cp3525
CP3525-59.FO ERROR. 1. TRANSFER BELT FLAG/ACTUATOR, WORKING? 2. SENSOR CHECK BEHIND CYAN TONER CARTRIDGE, WORKING? THESE 2 ARE IN THE BOOK AND EASY TOO CHECK. 3. MY ISSUES WAS THAT I REPLACED THE FUSER PRESSURE RELEASE MOTOR ASSY, BUT DIDN'T REALIZE GEARS WERE MISSING FROM SECOND HAND UNIT COMPANY ORDERED.:(. GOT MACHINE WORKING, BUT CYAN CAM IS OUT OF ALIGNMENT AND HAVE TO REINSTALL MAIN DRIVE AND CALIBRATE.. THIS ALL STARTING BY NOT USING HP SUPPLIES. BAD TONER CARTRIDGES HAVE TURN THIS JOB REAL UGLEY!!
Apr 17, 2013 | HP LaserJet Office Equipment & Supplies
HP Color LaserJet CP352dn 59.fo error
59.F0 ERROR
The primary transfer-alienation motor has experienced an error.
1. Check to ensure the ITB is installed correctly.
2. Run a sensor test to verify that the primary transfer disengagement roller is functioning. If not replace the sensor (SR17).
3. Run the primary transfer drive test in actuator drive mode. If not functioning replace the ITB (Intermediate transfer belt).
Jul 27, 2011 | HP Laserjet Cp2025n Printer
Hp color laserjet code 59.fo error
All the book says is that one of the motors had a problem.
Power it off for at least 30 seconds. Power back on.
Make sure you are not using a surge protector.
Put the power cord directly into the wall outlet.
I just checked the manual for another printer and the 59.f0
could be the ITB. Make sure that it is seated correctly. If you have
a spare install it and see if problem goes away.
Apr 04, 2011 | HP Laserjet Cp2025n Printer
Problem Error Code 59.FO For HP Color LaserJet 3600 Printer
If you haven't taken your printer apart, somehow the "cams" in the developer drive assembly worked their way out of alignment.
Somebody trained is going to have to align and calibrate the main drive assembly.
Mar 04, 2011 | HP LaserJet 3600n Printer
How can I solve the proble of 59 FO error code appear in the HP laserjet 3800 printer
The error says that "The transfer rollers in the ETB are not
engaged."
If replacing the ETB(electronic transfer belt) doesn't fix the problem, your printer is going to need a technician. Problem could be poor seating of the cables on the ETB motor or the 'transfer-roller separation solenoid or the DC Controller.
It could be a bad ETB motor or solenoid or DC Controller or high voltage power supply.
This isn't something that is going to be fixed by email.
I hope you have a service contract for your printer.
Feb 18, 2011 | HP LaserJet 3800dn Printer
How can i fix hp3600 59.Fo error
59.X PRINTER ERROR A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error 1. Turn the printer off, and then turn the printer on. 2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train. 3. Check the main motor’s cable to ensure that it is seated properly. 4. If the error persists, replace the main motor.
Apr 21, 2010 | HP LaserJet 3600n Printer
HP 5500n 59.ck error code
HP LASER PRINTER 2300 ERROR 59.B, 59.C
1. The Alienation motor error.
2. Replace the alienation motor.
3. Replace the D.C. controller board.
May 15, 2009 | Office Equipment & Supplies
Error co 59
i have printer 5550 error code 59.0 coming so i need hp sevice help
Apr 18, 2009 | HP LaserJet 5550 Printer
153 people viewed this question
jasbo
jasbo
