Question about Dewalt 18 Volt Compact Drill Kit
I have a DEWALT DC920 drill-driver and have a bit stuck in the chuck. The chuck adjuster appears to be stripped. Need to remove the bit and replace the chuck. Any ideas on how to get the bit released?
    Problem Solver:
  • 17 Answers
Try tapping on all sides of the chuck lightly with a hammer and wiggling the bit... you can also try to spray some oil into the chuck and see if that loosens the bit for you... You can also clamp the bit in a vise (or get someone with a pair of pliers) and pull, that will sometimes do the trick.
Posted on Apr 06, 2011
My dewalt d21008 drill is stuck in a smaller size bit opening . No bit in the chuck. It just will not open up??
hi
clump the drill in a good size vice then use 36" stilson spanner
adjustable adjust to fit the chuck then an do
Mar 08, 2017 | Dewalt Drills
Chuck keyless removal
drill it out with a drill bit so that you are removing the head of the screw. this will work i have done it many times.
Aug 13, 2013 | Dewalt DC930KA Heavy Duty Xrp 14.4V...
3/8" cordless driver can't change the
If debris enters the chuck it may no longer turn for adjustment. Spray plenty of wd40 into chuck and allow plenty of time for oil to do its magic. Hold chuck/drill pointing down and turn drill in both directions to clean out debris. If chuck is too far gone, remove the center screw (backwards thread) and remove the chuck(threaded on). Replace the chuck with new generic part from Lowes (about $25.).
Sep 20, 2011 | Dewalt Drills
I have a dc 759 it has a plastic cover over the keyless chuck ....it is stripped out.....can i just replace the plastic cover? .... if so how and where can i get one
If the drill is not too old, I would take it to your nearest factory dewalt repair shop. they have a good warranty on their items. If it is older you probably need to replace the chuck itself. You need to remove the plastic to get the chuck open and then there is a screw down inside the chuck that needs removed. The chuck should come right off and just reverse the process to install the new one.
Nov 12, 2010 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
My drill bit has stuck in the chuck of my dewalt sds chuck ,have tried wd40 but still stuck
I had the same problem. I put the drill onto Hammer/Chisel action and it helped release the bit.
May 16, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
How to remove a chuck from a DeWalt hand drill
Open chuck all the way (like for a large drill bit). There should be a set screw at the bottom (where you would put a drill bit). Don't turn too hard - it may be a left handed screw (I don't remember if it is a lefty for sure but try gently each way then with a bit more force each way until it moves).
Good luck.
Mar 19, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Dewalt dw997 drill clutch stuck
your drill required trans assy & clutch assy for $132.00 plus tax canadian max repair/
thanx
Apr 12, 2008 | Dewalt 18 Volt Compact Drill Kit
Chuck will not release bit
the Chuck should be 2 Part.
Use 2 pair of stillsons Or pipe wrenches, Tight On the 2 Chuck Parts, Crack in opposite Directions.
Alternative, Use Wrench On Chuck Jaw, Short sharp Blow With Hammer.
Mike @ compurepair.
Feb 28, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Oct 15, 2007 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18 Volt Compact Drill Kit Logo
306 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
