How to rotate screen to vertical and back? 203b
  • 32,281 Answers
An upside down image - this is caused by unintentionalpressing Ctrl-Alt plus the down arrow key. Restore by pressing Ctrl-Alt plus the up arrow key. ALSO To change the display from portrait to landscape Press Ctrl-Alt plus a left or right arrow key. Some computers do not have this function.
Posted on Apr 04, 2011
Allwinner A20 dual core android tab screen want rotate
Allwinner A20 is a name of a processor, so I'm not sure what tablet are you using.
There is an option to block rotation, for example if you want to read an e-book while laying on your back. Go to settings and try to find an option to unlock rotation.
Also, some tablets have a hardware (physical) switch on the side that locks rotation.
Jan 17, 2014 | Samsung Galaxy Tab Tablet PC
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Feb 15, 2013 | Samsung N120-12GW Netbook
Nothing on the screen
if their is a an power indicator in the front but with out a display or black screen, the cause it could be a busted back light or dry joint connector for inverter board for screen back light.
Aug 15, 2012 | Samsung SyncMaster 203B LCD Monitor
My screen is side ways how do i put it back to normal
Do you have a rotating monitor? There are a few that can be rotated 90 degrees in the plane of the screen for a "portrait view" instead of the standard landscape view, and they will automatically swap horizontal and vertical signals as needed. If you have one of these, the position detector switch is stuck in the wrong position. You may be able to get it unstuck by rotating to the other position and back again.
There are some programs (e. g., Acrobat Reader) that let you rotate the view of the file you have open, but that only affects the contents of the window, not everything on the screen. I'm not aware of a program that rotates the full screen view for the entire system.
Nov 19, 2010 | Computers & Internet
My samsung syncmaster 203b, the screen has just gone black with no picture but the power light is still on, i unplugged it and swapped it with my other samsung syncmaster monitor which is working but the...
This model is a great one and well worth repairing. The display problem you are having is caused by bad capacitors on the power supply board. To repair the unit you will need to replace 6 capacitors and one fuse on the board, this is very easy to do, it just requires a little soldering. Here is a picture of the power supply board with the capacitors and the fuse circled and here is a link to additional information on the capacitors needed.
http://www.ccl-la.com/catalog/product_info.php?products_id=229
Aug 12, 2010 | Samsung SyncMaster 203B LCD Monitor
How to rotate display vertically on HP L1925
Press control alt arrow key (up or down to rotate vertically and right or left to rotate horizontally) simultaneously to rotate the screen.
Good Luck and have a nice day
Jun 02, 2010 | HP L1925 19" LCD Monitor
Syncmaster 203b power light comes on, but no image...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 20, 2010 | Samsung SyncMaster 203B LCD Monitor
SyncMaster 203B (Black) LCD Monitor: Monitor will not stay on (Samsung Syncmaster 203B)...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 16, 2010 | Samsung SyncMaster 203B LCD Monitor
Samsung monitor blue flashing light, black screen
The picture board of your monitor has developed fault. That is why the screen is black.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity, because the fault is not something you can fix in other not to complicate issues..
The repairer will help diagnose and replace the faulty picture board and your monitor is back and better.
Take care.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
How to rotate display when I rotate screen - SyncMaster 203B
You ought to be able to bring up the video card settings from your control panel and change it there. For instance I have a nVidia graphics card. When I bring up the settings panel it offers me the opportunity to change the rotation there.
Dec 28, 2008 | Samsung SyncMaster 203B LCD Monitor
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
