Hi, my Panasonic TX-26LXD60 died whilst watching it. It won't switch on and all I get is the constantly blinking red power light. I think I saw in another solution that this would be the power supply board. (Is this the right part? http://www.shopjimmy.co.uk/panasonic-tnp8epl50ab-power-supply.html) How easy is it to fix or does it need a pro? Thanks :o)
4 Suggested Answers
Coldcut
  • 1554 Answers
SOURCE: Static lines one screen
as the top is ok and the bottom has this issue.
It looks like the circuit board has a bad connection to your screen.
it is not repairable by you and not an adjustment.
you need to have it repaired.
don't you miss the old wack on the side fix?
Posted on Feb 17, 2008
jdvillanueva
  • 2098 Answers
SOURCE: Hello, I have a Panasonic TH-50PZ800U
Hi Aaron,
2 blinks error code is definitely a 15VDC SOS detect, but this error code does not means that the fault was came from the D board alone. Remember that this is a supply voltage issue also. In the service manual, stated there that the test point is in the D-board (not specifically replaced the D-board).
Let me know the reading in the connector (P25) pin #1&2 in the D-board to assist you further.
Also just for the confirmation of 5vdc, let me know also the reading in (P25) pin #5&6 in the D-board.
Note : to have an accurate reading, place the test prod of your multimeter on the test point prior from powering on the unit because the supply voltage will cut-off after the self test.
Jdvillanueva
Posted on May 24, 2011
  • 8457 Answers
SOURCE: What is the TV Tuner Signal Board part number for the Sharp Aquos LC-52d64U?
That the board which it have a square aluminun box at the edge of the board with a rounded bolt sticking out for inputs like ANT. input and AV inputs for like wires components inputs like multi colors like YRW,YRWGP holes for AV inputs also have HDMI hubs inputs for the high Def Pic.There are 6 HDMI inputs hubs for the tv Sharp Aquos LC-52d64U.Tvs Tuner board signal boards are also have to been known names to called as the tvs Main Logic boards and the tvs Mother boards also.U are fixing ur tv u must have to take it parts already.U can also compare the pictures between the tv Tuner signal board u are taking aparts out of the tv and the tv Tuner signal board you are buying they'll look axactly alike.The sticker of the serial numbers of the boards a few numbers in the begining on the tv Tuner signal boards should be the same also.
Posted on Dec 06, 2011
I have got panasonic tx-32lx60t problem with it the green light comes on for few seconds and then switches to red light blinking two times continiously with set not switching on.do any one can help me on...
It sounds like a power supply problem. You can visually inspect the power supply for bad capacitors or blown IC's/FETs. After that check for any shorted or open components. You can find replacement boards if you don't feel comfortable repairing to component level. I often use Tri-State Module for replacement boards.
www.tristatemodule.com
Nov 04, 2013 | Panasonic Viera TX-32LX70 32 in. LCD TV
I have a Panasonic HDTV 1080p and it won't turn
You have a 5 year old projection TV with power supply trouble
Jul 13, 2013 | Televison & Video
Panasonic tx-32lx6017 tv blinking
IIC bus clock and/or data lines low at power on 06
6 blinks denotes this. The main digital board should be troubleshooted. If you wish to know more about the blinking codes to Panasonic TVs, check this link.
Feb 25, 2013 | Televison & Video
Panasonic TX-P42X10B wont turn on - goes into standby
Hard to troubleshoot with just this info, the red light can be helpful if its 10 blinks repeating over and over replace the power supply first then the A board. Voltages check on the power supply would narrow down the culprit.
Post again if you measure the power supply voltages
May 03, 2012 | Televison & Video
4 red blinking lights tv will not turn on
I would Google the model number with error blink codes and search that way to see or if Panasonic call their toll free number and ask.
Mar 14, 2012 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic TX-32LXD60 won't switch on. Red standby light flashes quickly and then becomes constant. TV Clicks and slight flicker then nothing. Can anyone help please ?
U have sound at all?Yes,than ur LCD INVERTER backlight board it dead.If power LED light keep flashing nothing on,sound or picture.Than the power supply board is dead.Must replaced the power supply board.Tries Websites Shopjimmy.com,Ebay.com to buy these refurbish boards.
Feb 26, 2010 | Panasonic TX32LXD60 32 in. LCD TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
