Question about Cameras
AIPTEX HD720P camcorder will not charge. Red light on but does not change after two hours on charge
  • Michael Kingston Apr 04, 2011
    YES. But having trouble finding a replacement battery. Need Edam 3.7V 1000mAh 3.7Wh. or equivilent one.
  • 12,061 Answers
Hi, well I see this type of thing many times a month in my shop, now usually it is either that the existing battery is faulty, replacement is the ONLY way to properly tell.
The other is that the Power Adapter/Charger isn't working correctly, this would have to be tested with a, meter or a new (another) one to actually tell, again replacement is the only fix.
Another thing it can be is that often inside the actual unit, a part of the power supply, overheats and there is a fault, and it will not then, charge the phone properly, even though it appears to work, this fault also can damage the Power supply and battery. this has to be most likely professionally fixed, unless very good at DIY and had all the parts and service information at at hand?, again by replacing the little power board where possible.
If it eventuates that you need to get the camera repaired, then to get the very best result, please contact either a local or a head off of AIPTEX, and ask them for a referral to an authorised repair place, now when there instruct them to first give you a "Quote" only, as to the cost and type of repairs that need to be done. This way you can make and informed decision as to repair or replace.
Posted on Apr 04, 2011
Addapter connected but not charging for sharp VL-Z500
If not charging,3 reasons may be-
1.Charger is defective.Check adapter
2.Batt is defective.Try with another one
3.Camera is electrically dedective.Can't complete charging.
Oct 20, 2012 | Sharp VL-Z500H Mini DV Digital Camcorder
I just got a brand new flip video mino hd and it wont turn on. i've charged it for atleast 4 hours. when it is plugged in the red light comes on. that is the only response i get from it. any...
I had to charge mine for 7 to 9 hours the first time, and make sure computer is left ON or it won't charge and the red light stays lit until it is fully charged. make sure the red light isn't blinking if it is, plug it into a different USB 2 port and don't use extension with it unless it is a powered USB extension.
Dec 28, 2010 | Pure Digital Flip Video Ultra Camcorder
I just got the flip ultra hd for christmas and was charging it then my computer screen went all weird and couldn't read the screen and all my icons on my computer were all big. i tried this three times and...
FLipSHARE software isn't compatible with Vista Aero and some other visual settings, SO, when you plug in your Fllip camera, the FlipShare software changes your desktop settings to go with their camera. They should go back to how you had visuals set before the camera was plugged in once you remove the camcorder. No green light shows when charged, a Red light shows up and glows during charge and when the red light goes out it is fully charged.
Dec 26, 2010 | Pure Digital Flip Video Ultra Camcorder
Have a new Ultra HD Flip Video. How do I know when it is fully charged? Does the red light go off or what?
Hello there,
The Flip Ultra should have a rechargeable AA battery pack.
To verify it is charging, the battery icon will be flashing lightning bolt. The red light goes from red to green the moment it is fully charged. It takes six hours before it gets a full charge via the USB.
Please let me know if this gave you enough information. Thank you for using FixYa.
Oct 08, 2010 | Pure Digital Flip Video Ultra Camcorder
Flip Mino HD red light won't turn off after charging. Camera won't do anything at all. What do I do?
return it for a refund! i bought one, it did the same as yours. i returned it and bought the 2nd one. It did the same as the first one (and the same as yours.)
It is a piece of junk. Supposedly the previous Flips were good, unfortunately, I didn't have the previous models so my experiences only are bad.
Aug 09, 2010 | Pure Digital Flip Video Ultra Camcorder
It keeps blinking red while it's charging and I got it yesterday.
The red light on the front of the camcorder is supposed to blink when it is charging. That indicates that it is still charging, the light will stop blinking when it is fully charged. Other than that does it work fine?
Aug 07, 2010 | Flip Video Flip UltraHD 8GB High...
How long do you charge the li-ion battery on a Mitsuba HDC-8800?
It usually takes around 16 hours for the first charge. Then a few hours after that. When you charge the battery and it is fully charged, the light on the charger will change from red to green. I would not recommend charging it any less then that amount of time as it will cut battery life back dramatically over time.
Jun 21, 2010 | Mitsuba HDC-8800 Camcorder
Need to know where the record button is
I hve the same one. Look at the front of your camera where the lens is facing. Look under it and there is a part where it flashes. Look under that and you'll see a small red rectangle. Press it and it will record.
May 18, 2009 | Aiptek A-HD 720P Flash Media Camcorder
Charging lights turn red and green...But camcorder will not power on
All right if you have the same problem that i had what you need to do is take the battery out the take the memory card out the put the battery back in then try and turn it on if it works then put the memory card back in and it should be fixed
Apr 29, 2009 | Cameras
My GZ-MG20 wont turn on.
You need a new battery, it has lost its ability to charge.
Jan 22, 2008 | JVC Everio GZ-MG20 Camcorder
Cameras Logo
21 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
