Question about Dometic Refrigerators
RM 2330 ELECTROLUX 3 WAY FRIDGE FRIDGE/FREEZER WORKS ON 240 V, FRIDGE GETS TO 5' ON MAX. WHEN REDUCED TO SETTING 6 INCREASE IN TEMP TO 9' ON GAS FRIDGE PART NOT WORKING PROPERLY, FINS ON RIGHT HAND SIDE ARE COLD, LEFT HAND NOT. FRIDGE/FREEZER DOES NOT SEEM WORK ON 12V. LOOK FORWARD TO YOUR REPLY
SOURCE: we have caravan electrolux rm
Problem is either thermostat or heating element...not sure which yet..but found website supplying most usable parts for RM series fridges. Hope this link is of use.
http://www.leisureshopdirect.com
http://www.leisureshopdirect.com/caravan/ventilation/Dometic-Electrolux_Spares$$6.aspx
Posted on Jul 08, 2008
  • 68 Answers
SOURCE: AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Posted on Mar 18, 2009
VtToolMan
  • 704 Answers
SOURCE: Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
Posted on Aug 03, 2009
SOURCE: Camper fridge does not work on gas.
right where the gas comes out there is an elect igniter do you see or here it clicking some times carbon buildup causes it to ground out inproperly sometimes the bracket gets rusty the bracket needs to be able to fire a spark directly twards the jet good luck
Posted on Apr 12, 2010
mreid542
  • 166 Answers
SOURCE: freezer works fine, fridge cool not cold.
if the freezer is freezing and the fan working in the freezer and the fan at the compressor is working and you have no frost build up on the back wall of the freezer caused from a defrost problem -then turn your controls back to the middle. one of the controls is a thermostat control and the other control is merely an air diverter from the freezer to the refrigerator. if you close this diverter down too much (by putting it on 9)it will leave most of the air in the freezer.
bottom line if the freezer is working properly and freezing good all the time then the refrigerator should be ok as well unless you have diverted most air to the freezer. allow 24 hours after you have changed the settings.
you can feel air blowing in the back of the refrigerator at the top next to the freezer and can adjust the diverter control and feel the difference it makes. most of the time the control you use is labeled freezer and if you put both controls on 9 then your freezer will be the coldest but the refrigerator won't get as much air. the thermostat control can be left at 5 or higher (this is the control that turns the refrigerator off) but leave the other control at 5
if this doesn't work you have probably got problems with your freezer also and may not know it yet.
Posted on May 27, 2010
I have a 2yr. old Maytag Frig.,freezer on top.I cannot get a stable freezing temp. I can set, with the setting control, readings of 4 or 7 with no effect on the actual temp. I bought a freezer thermometer...
If the refrigerator is not cold enough then please check the following and also click on the blue coloured links for more info.
How To Check the Temperature1x1.gif In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
Goodluck,
Please don't forget to rate the solution.
Mar 27, 2008 | Refrigerators
Tip
Freezer working but no cool in Fridge/No Ice making
This is one of the common problem throughout the world. It's because of not going through User Manual before using the fridge. <br /><br />To get better cooling, dispensing water, ice cubes from your refrigerator, please follow the steps. <br />1. Keep temp setting between 3 degree and 5 degree Centigrade.<br />2. Ensure, freezer door and mail door of Refrigerator are closed properly.<br />3. Check freezer fan is working. If struck by frosting behind the freezer, you have to defrost it.<br />4. Defrost cycling is not functioning properly. Because your set temp is less than 3 degree or in minus.<br />5. Auto defrost cycle not activated due to thermostat, timer, heater malfunction. <br />First, locate the defrost timer which may hiddenbehind corners of the fridge at the back bottom, in some models located in theceiling of the fresh food section or behind the cold control cover. Once youlocate the defrost timer, slowly turn the screw in the middle of the defrosttimer with straight screwdriver until the fridge shuts off. Now it's indefrost. If the defrost heater(s) starts, replace the defrost timer and defrostthermostat. If the heater(s) does not start, unplug wire cord to check ohm testfor continuity of heater. If continuity is there, plug cord wire which givespower 120volts (check specification) to heater. If heater no starts, bypassdefrost thermostat by join the 2 wires in the defrost thermostat. If the heaternow comes on, replace the defrost timer and defrost thermostat. If the heateritself is bad, replace it<br />6. Check water line to make ice are not tint or remove kinks in water source line in the back of refrigerator to increase water pressure.<br />7. Check solenoid valve in the rear side of refrigerator back is activated. <br />8. If solenoid activated,no water flow means, have to clean solenoid valve. <br />9. Check shut off arm is not struck due to over ice stores in the ice bucket. Remove it.
on Feb 07, 2011 | Refrigerators
I have a 2453 150 litre caravan fridge not working on 240 but works on gas. What maybe the problem and can i get a mobile repairer
It sounds like the electric heater is not working as you say it works on gas, so the expensive bit is OK.
An appliance engineer should be able to get the spares and fix it.
Mar 07, 2011 | Microwave Ovens
I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Thanks
Jan 23, 2011 | Dometic Refrigerators
Brand new freezer set at 7 is creating excessive frost. Is it set too high or low maybe?
Hi and welcome to FixYa. I am Kelly. Each brand or temp control is silghtly different than even a like model on the display floor. However.... Most temp settings that are normal are right in the middle of the control setting range. Be it a mechanical control or an electronic control. If yours is a mechanical setting and the setting dial goes from 0 to 9 then the average temp setting would be between 4.25 and 5. A freezer should keep ice cream hard. If you do not have a thermometer then a small tub of ice cream makes a great thermometer. Each day i.e 24 hour period you reduce the setting 0.5 until you notice the ice cream is softening. Then once it softens increase the temp setting 0.75 of a between numbers setting. I.e The ice cream was soft at 3.5 then increase setting to 4.25 etc etc.
Thanks for chosing FixYa.
Kelly
P. S. If you need more detailed information please provide your freezer "make and model number" in you next response so we can provide you information applicable to your exact freezer.
Jul 27, 2010 | Refrigerators
Fridge side won't regulate temp. however the freezer will freeze to -9 and stay right there! How do you test the thermostat? or is this a common problem. The fridge was built in 01' and nothing has been...
the thermostat is either off or on, and it controls the fridge temperature the freezer is just a by product of the remaining gas from the fridge usually -20/30 degrees lower than the fridge, two problems would cause this leaked gas would reduce the cooling capacity of the freezer but the fridge should stay ok although the compressor would be constantly on trying to keep temperature. the thermostat can fail after time not being able to keep a regular temp and not switching the compressor on enough to cool the system. unless you have a frost free where is usually a relay that controls the compressor witch have a life time rating of so many operations.
Jul 23, 2009 | Electrolux Refrigerators
rvtech@myway.com
www.coachtech.info
734 777 6432
Jul 26, 2008 | Dometic NDR 1292 Refrigerator
We have caravan electrolux rm 4230 light is on for 240 chilling, but fridge does not cool. appliance does however cool fine on gas.
Jul 05, 2008 | Electrolux Refrigerators
Refrigerators Logo
299 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
