Question about Acer XD1150 DLP Projector
Power supply exploded - Acer XD1150 DLP Projector
  • 442 Answers
What would you like to know?
Posted on Apr 04, 2011
Samsung tv made loud noise and will not power up
Sounds like capacitor exploded. Check power supply area. Flat panel tv's use cheap capacitors. Most likely this capacitor is in the power supply area. The top will be popped, they're made to pop when they go bad. Have professional fix it.
Feb 14, 2014 | Samsung Televison & Video
The system does not power on. When the power supply was opened up, the 50 V capacitor exploded. When replaced, it got very hot and eventually exploded again.
Replace the caps and this time disconnect power supply rails that go to the amp module, then check positive rail for +30V and -30V, if they are present then your power amp ic's that if i remember correct are TDA7293 are blown, or at least one of them, let me know your results.
Aug 10, 2013 | Peavey Escort 3000 300 Watt Portable PA...
Lg power supply
Do an internet search for lg power supply for LG37H30 replace the entire power supply! (because the damage may have caused other bad coponents do to that one ic exploding avoid a headache replace the entire power supply and start watching TV again.
Jan 21, 2013 | LG 37LH30 37 in. LCD HDTV
My plasma PDP-503HDE exploded: a saw a flash flollowed by some smoke and it doesn't work any more
hi,
You have to check the power supply board. Its a common problem with the power supply of the Pioneer PDP. As it is using smd coponnents there is no repair possible with the power supply . You have to replace the power supply board with a new one. You can find the part number in the board. Serch with the part number to find a new board.
OK
Sep 24, 2011 | Pioneer PureVision PDP-503HDE 50 in....
Standby light flushing tv not switching on tv transistor exploded on switching on
Ur tv have a total power supply board failer.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jul 14, 2011 | LG 42LC2D 42 in. LCD HDTV
Loud bang from system.Unit starts immediately power is supplied.Power switch does nothing.H/Drive and players run.No video ( card OK ) checked with another card. Can the problem be motherboard?
The load bang is most like an exploding capacitor in the switch mode power supply, especially if there is a burnt electrical smell from the power supply.
I suggest you borrow a switch mode power supply, remove the old power supply and install the replacement power supply. make sure it has the same or larger wattage unit.
If the computer still does not boot up then the exploding power supply has damaged the motherboard, and you need to replace then motherboard too. This may not be a cost effective solution.
This is an opportunity to get a new and better computer.
May 16, 2011 | Computers & Internet
Alienware aurora desktop with 525 Watt Power Supply was working fine then all of sudden started making a loud noise like it was going into overdrive or something then emitted a horrible like burning...
The switch mode power supply in the desktop computer has failed. Most likely the capacitors in the power has exploded.
You need to open the desktop computer and remove the old power supply and replace it with a new one. Take the old power supply with you to your friendly computer shop and get a replacement power supply with the same wattage or greater wattage.
Jul 25, 2010 | Alienware PC Systems Alienware True 480...
My Samsung is delaying turning on
Reason for your problem is that there is not proper power being supplied to the tv. Solution- on the power supply there is 2 capacitors 1 of which is exploded already. You would need to replace those with new ones. spotting and exploded cap, good caps are flat on the top and bad caps swell out.
current cap- 10v 2200mf
replace with -16v 2200mf or 25v 2200mf
repair will include soldering.
Apr 27, 2010 | Samsung SPN4235 42 in. Plasma HDTV
Tv will not turn on but makes a beeping sound
better take skilled tech person  help as it is high voltage problem.
Oct 14, 2007 | RCA F36668 36" TV
Acer XD1150 DLP Projector Logo
118 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
