Check the outer soap box - Remove the top panel, usually screwed tight at the back of the machine by 2 screws. After removing the panel, you should see the big detergent outer box, remove its top panel and clean the small water holes at its reverse. What happens here is these holes also get blocked and by unblocking these holes you will allow water to get through.
Good Luck
* If you found this solution helpful, please rat 4 thumbs up and leave a small testimonial. :-)
