Question about Lexmark C534N Printer
960 Service Memory error - Lexmark C534N Printer
5 Suggested Answers
Printtech
  • 1087 Answers
SOURCE: 960 service memory error-a
The printer memory is failing. RAM soldered on the system board is bad. It would be best if you contact Lexmark Technical Support for proper assistance.
Posted on Jul 15, 2011
  • 320 Answers
SOURCE: service 960 memory error- r
A 960 RAM MEMORY FAILURE message indicates a failure of the RAM MEMORY that is soldered onto the printer's main controller/system board.
If the printer is displaying a 960 memory error.
1. Power off the printer.
2. If you have any extra memory SIMMs or code SIMMs installed in the printer, remove them.
3. Power on the printer.
4. If the 960 error continues, the main controller/system board will probably need to be replaced.
5. If the 960 error does not return, try printing a few documents.
6. If these documents print correctly, the cause of the 960 memory error is probably one of the SIMMs you just removed.
To confirm this, do the following:
1. Turn off the printer and reinstall each SIMM one at a time.
2. After you install each memory card, power the printer back on and try printing. If the error returns as soon as you install a particular SIMM, that SIMM is probably the cause of the error message.
Posted on Nov 08, 2010
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: 960 service memory error - a
    The error indicates that the system board's on-board memory has failed. This usually requires a service call but you can try to turn off the printer, then turn on after 15 seconds. If the problem continues, I strongly suggest you contact Lexmark technical support or an authorized service provider for assistance. You may need to know your printer's model type and the serial number when calling for service. Thanks.
    Posted on Sep 10, 2010
    Printtech
    • 1087 Answers
    SOURCE: 960 service memory error how do I solve the
    Theprinter memory is failing. RAM soldered on the system board is bad. It would bebest if you contact Lexmark Technical Support for proper assistance.
    2 3 4 orange blinking lights/ automatic start up and forced shutdown/ optiplex 960
    Log in to: http://www.dell.com/support/home/us/en/04/product-support/product/optiplex-960/diagnose and send this info to Dell. As I recall lights 2,3,4 are either memory or HDD failure.
    Run Diagnostic Run Diagnostic Diagnostics can be run on supported Dell devices with a full version of Windows.
    Already have an error code from running ePSA diagnostics?
    Dell devices come with preboot diagnostics to capture error codes. If you have already run a preboot system assessment (ePSA), enter the error and validation codes with your Service Tag below and complete the steps to resolve your issue. Enhanced Preboot System Assessment Error Code (without 2000-prefix) * Validation Code * Service Tag * Part Serial # (optional) ; ;
    Mar 28, 2015 | Computers & Internet
    OPTIPLEX 960 error codes 3 and 4 at startup. Solid amber light.
    "optiplex 960 error codes 3 & 4 at startup"
    Found out by myself the google suggestion to look up the Dell Diagnostics page:
    http://support.dell.com/support/edocs/systems/Op745/en/UG_en/trouble.htm
    Lights 3 & 4 means "Memory modules are detected, but a memory failure has occurred." Bingo! I didn't actually replace memory sticks, but pulled them out and put back in one by one. Only three out of four sticks were accepted. Works.
    Jun 05, 2012 | Computers & Internet
    960 service memory error-a lexmark c534dn what is wrong how to fix?? Gloria
    Jun 14, 2011 | Lexmark C534dn Color Laser Printer
    960 service memory error how do I solve the problem on a Lexmark C534?
    Mar 29, 2011 | Lexmark C534dn Color Laser Printer
    Service 960 memory error- r for my Lexmark C532n printer
    Nov 08, 2010 | Lexmark C530dn Laser Printer
    Sep 10, 2010 | Lexmark C530dn Laser Printer
    Memory card error
    There are several possible causes for "memory card locked" or "memory card error". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the switch on the side of the card, and the switch internal to the camera. Troubleshooting tips for this problem may be found at this link.
    May 23, 2010 | Canon IXUS 960 IS Digital Camera
    OPTIPLEX 960 error codes 1 and 3 at startup. Both numbers and power button are amber blinking. Doesn't boot. Nothing on screen. Please help auntie.
    Blinking amber ... seems like an isuue with the power supply .. check if you see the power supply fan spinning at the back of the system tower... If its spinning then you could try reseating the memory modules inside the system tower . Opem the tower and then disconnect the green colour ruler shapped modules which has a latch on either sides. then try turning in the system ... check if turns on properly.
    Hope its informative.
    Apr 01, 2010 | Computers & Internet
    Error - NO CARD
    For this problem try the following:
    * Try formatting the memory card using your computer
    * Try using the memory card with other devices
    * If problem still persist call the Tech Number for the memory card manufacturer
    Hope this will help
    Thanks
    Byron
    Sep 23, 2009 | Olympus Camedia C-960 Zoom Digital Camera
    Need manual
    Given that consumer telephones are inexpensive, the cost of repairing the speaker phone on the 960 (assuming you still have it) is probably not worth it.
    Going off of my memory....to program a speed dial you would first press "Program", enter the telephone number you want stored and then press the one of the memory buttons to save the number to. If the number is to be saved on a lower memory position press "Lower" before you press the memory button.
    AT&T's telephone product website has a section where user manuals for many AT&T and Lucent branded telephones.
    http://telephones.att.com/telephones_ui/support/dsp_manuals_list.cfm
    The 960 is no longer listed, but the many of the basic functions are similar to the 922.
    Sep 20, 2007 | Lucent AT&T 960 Corded Phone
    Lexmark C534N Printer Logo
    1,349 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
