Question about SigmaTel, Inc. Digital Audio MP3 & WMA Player
I installed Windows 7 on my Intel DQ965 motherboard. Audio output seems to work fairly well but the line in and the microphone jack are unable to detect audio input. I've tried installing the Windows XP drivers that came with the motherboard installer, the microphone and line in inputs are there but this process scrambles the audio output. I can't get both the audio input and output to work well and I can't find Sigmatel drivers for Windows 7 anywhere.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • SigmaTel, Inc. Master
  • 1,476 Answers
SOURCE:
When i install application or games on my sony ericsson aino it display operation failed, how can i fix this?
Sony IC RECORDER ICD BX-800 (!without USB connection!)
What you need:
- newests audio drivers in Windows 7 (updated audio-drivers)
- audio cable 3,5 M (male) both ends M-M (male-male)
- freeware application Audacity for Windows (with LAME)
Howto step by step:
- one end of audio cable connect to dictaphon's headset (earphones) jack in recorder Sony IC RECORDER ICD BX-800
- other end of audio cable connect to PC/notebook microphone (or LINE IN)
- nothing special setup (adjust) regarding Audio in Windows 7, the device for record Audio keep Microphone (default)
- in Audacity set very little volume "Input Volume Slider" and "Output Volume Slider" (for example both 0,1)
- in Audacity like Input Device set "Input (Audio device High Definition Audio)": !Don't set in Audacity like Input Device "Microphone"!
- Audio Host: MME
- Output Device set "Speakers (Audio device)"
- Input Channels set "2 (Stereo) Input"
- Sampling (Hz) set 4410
Jul 10, 2013 | Audio Players & Recorders
Intel(R) Desktop Board D945GCL,Window 7 ultimate is installed.After installing Audio Driver (Version 5.10.5208.0) Sigma High Defination Codec,in speaker properties,Jack is showing Jack information not...
Please ensure that your bios setting is enabled for audio.
1. Have you installed the correct windows 7 driver or have you configured with the vista driver?
2. If you have installed with windows 7 driver, check it for 32 bit or 64 bit and you are installed perfectly!
3. Check the windows service. Go to "run", type "services.msc" and press enter. In that opened window, direct to "windows audio". Open it and check the service is started or not. Also ensure that the startup type is set to be "automatic".
Hoping you will be short out!
Aug 19, 2011 | Intel D945GCL Motherboard
Hello. Has Intel d946gzis internal connector SPDIF to add a cable with coaxial or optical exit? Thank you.
No, according to intel, it only has: • Front panel audio connector, including functionality for: ? Line out ? Microphone in Desktop Board Features • Back panel audio connectors that are configurable through the audio device drivers: ? Line in/retasking jack ? Line out/retasking jack ? Mic in/retasking jack Audio drivers and utilities http://support.intel.com/support/motherboards/desktop/
Jul 03, 2011 | Intel D946GZIS Motherboard
I can't find where my microphone goes
Is your computer a laptop or a desktop? How old is it? Which make/model of computer do you have?
For an older desktop, the microphone input will be on the back of the computer. There are usually three 3.5 mm jacks for audio connections. The pink connector is for the microphone. The black connector is for Line In and the green is line out (speakers). Often they are towards the far side of the motherboard connections from any PS2 (keyboard and mouse) ports. Otherwise, they will line up with one of the card slots.
Newer desktop computers often have additional audio ports for surround sound. However, the pink jack for the microphone is standard. If the computer has front audio ports, you may find that the same color labels the jacks. Otherwise look closely at the icons next to the ports. These will be in addition to the back audio ports.
Laptops can have the audio ports on the front, back or side depending on the model. There will be a small icon with a stand microphone indicated for the microphone port.
If you have one of the newer USB microphones, plug it into an available USB port.
If the computer has no working audio ports, either get a USB microphone or add a sound card.
I hope this helps. If you add a comment with your computer's brand and model number, I'll try to provide the exact audio port details. (There are some computer motherboards that do not have on-board audio and you will need a sound card.)
(on Windows computers, you may have to change the default audio input. Click Start > Control Panel > Hardware and Sound > Sound > Manage Audio Devices. (for Windows 7) For other versions of Windows, you may find slightly different titles in the Control Panel.)
Jun 24, 2011 | Compaq PC Microphone (Black or Beige)...
I am using windows 7 32bit. now my front audio
you need to right click the audio icon on the bottom right under windows 7 and then select default audio output device as headphones that you have plugged in the front. unlike that in windows xp both rear and front jacks were active at the same time in windows 7 you need to select the same manually.
Jun 23, 2010 | Intel D945GTP Motherboard
The audio support is disabled when i check the bios menu and i want to enable it but nothing i do seems to be working, i tried to install AC 97 wdm audio but it shows that some "rtlvaac" is missing the...
If the bios shows audio as disabled and you are unable to enable the audio in bios, you need to update the firmware of the motherboard. You can find the firmware on Intel website by searching with model number of motherboard.
May 30, 2010 | Intel Motherboard
G41tm-e43 + windows 7:
just install ur orignal window 7 driver for ur motherboard
http://www.msi.com/index.php?func=proddesc&prod_no=1791
follow this link
Mar 06, 2010 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
I have installed Win 7 on a separate partition, dual booting with my previous XP. I find that, to get any audio output in Win 7, I have to connect my 'line out' jack to the pink 'microphone' socket instead...
if you have the full version audio driver then you can set the pins at your own choice. the full version driver have a utility that will help you to change the pins audio in one of the windows.
Jan 07, 2010 | ASUS K8S-MX Motherboard
Sigmatel audio sofware
installation problem:-
i have already install winxp sp2
and all dirvers by cd with attach
motherboard D945GNT,and
one day sound driver was unistall automaticaly ,and never again install driver
Jan 17, 2008 | Intel D945GTP Motherboard
Computers & Internet Logo
50 people viewed this question
Top SigmaTel, Inc. Computers & Internet Experts
Alun Cox
Are you a SigmaTel, Inc. Computer and Internet Expert? Answer questions, earn points and help others
