Ricoh aficio 2090 : sc592 this cod appear when paper pass through finisher
  • 990 Answers
SOURCE: Ricoh Aficio 1224C/1232C problem code SC 792
Hello sir; try to turn off and back on the machine to reset, if don't work next few steps need to follow;
1, press "clear mode" then enter 107 then press and hold "clear/stop" key until SP mode show up.
2, turn power off and back on .
Posted on Jan 09, 2009
SOURCE: Ricoh Aficio AP2000 Laser paper jam
Found solution myself.. The paper sensor arm with flag and sensor was missing from the exit side located on the fuser assembly.. Customer apparently broke off prior to calling for us to repair. Solution-replaced fuser assembly clean and tested works great
Posted on Feb 07, 2008
Joed911
  • 4338 Answers
SOURCE: paper jam in Ricoh Aficio 1515MF
Go to this link, and click on "How to clear misfeed a,p,y"
http://www.ricoh.co.uk/KBase/KBLink.cfm?ProductUID=1878
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 11, 2008
Cogz
  • 1326 Answers
SOURCE: RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Posted on Jan 25, 2009
SOURCE: Ricoh Aficio 1232c is flashing SC 792
that appears to be a finisher communication problem. Check the connectors..
Posted on Mar 27, 2009
What could the Grinding noise be that is coming from Ricoh Aficio MP C2550 for each page copied/printed?
Check for:
-broken plastic gear on right side of copier
-paper or foreign object in paper path
-paper or foreign object near fuser
Oct 15, 2014 | Ricoh Aficio Mp C2550 Copier With Feed,...
Error cod SC626
That is a communications problem between the finsher and the machine, Could be simply a loose connection between the finisher and the machine boards, ( most likely) , or a bad circuit board in either the finisher or the machine. My bet is a bad connection.
Jan 29, 2011 | Ricoh Aficio 450 Copier
Sc 705 da ricoh 2090
SC705 RADF Bottom Plate Motor Error
Jan 05, 2011 | Ricoh Aficio 450 Copier
Ricoh AF/2090 finisher des'nt attached
The finisher for a Ricoh 2090 is not hot-swappable, meaning you have to turn the copier off completely, attach the finisher cable, and then turn the copier on in order for it to correctly recognize the finisher.
Jun 17, 2010 | Ricoh Aficio 1035 Copier
Ricoh aficio 250 I justcleared a ppapaer jam in area D now the LED stills shows paper jam and machinewill not reset. I have looked good and I can not find any paper. Could I have hit a senosr or switch...
This is an older machine and I don't remember where "D" is.
Ricoh uses Optical sensors in most of their equipment so you will be lookind for what looks like 2 LEDs close together in the paper path or a actuator of some sort in the paper path that goes back to a black U shaped device (another type of optical sensor). Start in the area that you found the paper and work your way back to the tray. Since it is optical, even dust or a tiny piece of paper can cause a jam light to stay on.
Jan 20, 2010 | Ricoh Aficio 250 Copier
Service code SC 548 on a Ricoh Aficio SPC 811dn printer, what is it and how to correct?
I have sc 548 error code also. I was following your instruction, but i couldn't enter to service mode. How do i prepare it? Please write this instruction to me step by step.
Apr 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Mar 27, 2009 | Ricoh Office Equipment & Supplies
235 people viewed this question
k24674
jasbo
jasbo
