Question about Cell Phones
My friend has a problem calling me, every time he calls me he says that my phone rings only once and then it says its busy, but my phone shows no sign of any missed calls, please help me, i dont know whats wrong
  • ABHIJESH M.N
    ABHIJESH M.N Apr 04, 2011
    Pls send me your phone model no and manufactor.
  • 36 Answers
Please check whether your phone has been set to divert calls.
Posted on Apr 04, 2011
My phone rings once and shows "Incoming call" on the LCD screen and when I answer, no one is there. People calling say the phone only rings once or it goes directly to voice mail.
You have to go into the menu and reset the rings so that the phone will ring at least 4 times. Your owners manual should give you directions to do that. You can also call Panasonic.
Aug 29, 2011 | Panasonic KX TG4023 Cordless Phone
My BB Pearl goes straight to missed call without ringing?
you might have the call dirversion set to on. check that in your call settings
Sep 02, 2009 | RIM BlackBerry Pearl 8100
I bught a kx-ta824, I just have one CO line and i want to put 4 extensions , but i couldn't. I can just recive 1 call and then the line sounds busy.
With one CO line you can only make or receive one external call at a time. You can have extensions connected on intercom calls, but once your CO line is in use, anyone calling in will get a busy signal, as will anyone in the office trying to make an outside call. You'll need additional CO lines if you want to have several outside calls going on at once.
Apr 10, 2009 | Panasonic KX-TA824PK Phone
Extension is locked
the phone is in IN/OUT mode
if you call the phone from another display phone it should show the ext you are calling in a IN/OUT mode.
to remove this you will need to place a key on the phone through programming. the key code is 821.
once you have programmed the key, press it once and the phone will work.
Nov 12, 2008 | Executone 64 Corded Phone
Fax problem
unplug the fax from the phone line. call it from you cell.if you hear your phones ringing in the house, plug the fax machine back into the jack. [you should still be on your cell phone] if the line goes dead or stops ringing, there is a short with the fax machine or wire to the jack.if you hear a busy signal without the fax plugged in, unplug everything you have plugged into phone jacks thruout the house. call your # again.if you hear ringing on your cell phone, plug everything back in one at a time.[again while still on your cell phone] if it was one of the phones plugged into a jack, when you plug the shorted phone back into the jack, the line will go dead again. that phone or cord is the problem.
if still rings busy when everything is unplugged, then call your phone company. it can be an inside wire or jack problem, or the problem is outside your home.
hope this helps
wg
Feb 05, 2008 | HP Officejet 5610 All-In-One InkJet...
Missing calls
I had this problem once and on my phone I would get one ring and then it would stop. Checking the phone I saw I missed a call. I live in the mountains of Puerto Rico and I believe what is happen is the network plays the rings for the caller but the phone isn't doesn't get the signal or start ringing until 3 or 4 rings later. In other words the caller has already heard 4 or 5 rings and has given up. While you have heard only one ring and when you got to the phone you already missed the call. I told my friends to let it rings more then 5 times before giving up and that worked.
Dec 08, 2007 | Kyocera Oystr KX9 Cellular Phone
Sharp UXB700 Fax
Below is for when you are using machine in fax mode, is that how you use it or are you also using the answering machine function? ie TAD mode
If desired, you can change the number of rings on which the fax machine
answers incoming calls in FAX mode. Any number from 2 to 5 can be
selected.
1 Press FUNCTION once and 3 times.
Display:
OPTION SETTING
To select FAX mode, press
(with no document
in the feeder) until the arrow in
the display points to FAX.
RESOLUTION/
RECEPTION MODE
RESOLUTION/
RECEPTION MODE
FAX
A.M.
TEL
Using TEL Mode
58
2 Press once and once.
3 Press once.
4 Enter the desired number of rings (any
number from 2 to 5).
Example: 3 rings
5 Press to return to the date and time display.
Note: If you are using Distinctive Ring, the fax machine will answer calls after
two rings regardless of the above setting.
Oct 16, 2007 | Office Equipment & Supplies
Cell Phones Logo
83 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
