Question about Panasonic Televison & Video
I have an 'old' DMR-E55EB recorder with my latest two RAM discs suddenly being 'write protected' without me knowing why. Is there any way to make them work in a read, write, and erase way again? If not, the RAM disc are now useless, as format etc won't work Thanks, Dennis R
  • Panasonic Master
  • 467 Answers
Very strange, but not uncommon.
The DMR-E55 (and its variations) is a 2004 model DVD recorder, so it is over 5 years old. If you did not set write/record protection on those discs, then it is likely to be a defect within the recorder, which may require workshop attention. You can always submit the unit to an authorised service centre for a quote and second opinion, to get an idea of the likely cost(s) involved, if a fault is found, then make a decision afterwards. Up to you.
Alternatively, it might be a good idea to cease using DVD-RAM discs and use DVD-RW/+RW discs instead if the unit accepts these as a recording format (or change brand of disc), and you intend to record more than once per disc. Or you could try the same discs in your PC if it has a DVD burner which is capable of reading/writing RAM discs as well as all other formats. If that works, the discs are OK.
If this does not work, then your only other option is to take the recorder to a workshop and have a qualified technician examine it thoroughly; but be warned - it may be expensive if you decide to do so. I hope it is nothing too serious.
Posted on Apr 04, 2011
I need to know whether the Panasonic DVD recorder takes minus discs or plus discs DMR-E55EB/EBL
Hello there,
According to the manual, i believe that this particular model takes DVD-R discs.
I hope this helps! Thumbs up are much appreciated.
May 05, 2011 | Video Game Consoles & Games
I am trying to record with a sony dvd-r disc and the recorder don't recognize it. the only disc that works is the dvd ram 4.7 but that disc does not work on other standard dvd players. what is the answer?
According to the official description of that recorder, you should have no problem, this is from the description for the DMRES15:
Recordable DVD Media
Record your favorite shows onto DVD-RW, DVD-R, DVD+RW, and DVD-RAM DVD discs. The DMR-ES15 is also compatible with DVD+R Double layer media and provides up to 14 hours of media recording.
Multi-Format Player
Don't worry about limited playback capabilities, the DMR-ES15 can play DVD, DVD-RW (VR Mode), DVD-RW (Video Mode), DVD-R, DVD+R, DVD+RW, DVD-RAM, VCD and CD-DA discs. Also, you can play your favorite songs from CDs or MP3 files, and JPEG images.
Nov 29, 2009 | Panasonic DMRES15 DVD Recorder
The display keeps saying please wait. I unplugged the unit and plugged it back in and it still displays please wait.
The display keeps saying please wait. I unplugged it a million times. Please help me resolve this problem.
Aug 01, 2009 | Panasonic DMR-E85H DVD Recorder
Panasonic DVD Recorder DMR-E55EB/EBL On turning this appliance on, the self check message appears and does not disappear, even after an hour or so. In the manual it says waiting until the message...
i have a Panasonic TV model no MDR-E55EB/EBC WITH FREE VIEW BUILT IN HOW CAN I RECORD TO A DVD RECORDER I CAN RECORD THE ANALOGUE STATIONS OK BUT NOT FROM THE FREE VIEW PLEASE HELP ME THANK YOU
Oct 18, 2008 | Televison & Video
Panasonic dvd recorder model dmr-e55eb/ebl. played dvd,no problem - ejected dvd - green/blue colouring appeared on TV which disappeared when dvd recorder switched off. since then unable to play dvds. ...
This is a problem with either the logic or the power supply. Without seeing the machine and taking measurements inside, I can't state for sure the exact problem. These are decent machines. I would suggest that you bring it to an authorized Panasonic service center for a repair estimate. Post the results here and we'll suggest the next steps.
Dan
Apr 23, 2008 | Televison & Video
Trouble with my Panasonic DVD recorder DMR-E55EB
Hi Dengle
The heat is caused by IC001 which is a regulator that is mounted on a completely inadequate heatsink on the power board. This component gets very hot during normal operation.
The regulator will usually last a couple of years, depending on how often the machine is used and then start playing up. The symptoms are intermittent operation, continuous self checking and rebooting, not being able to read discs and so on.
Eventually the component can short-circuit, burn out and take other components with it. The on-board fan is thermostatically controlled. It does not operate all the time, only when the unit gets hot enough. By using an external fan, you are keeping the unit cool enough for its own fan never to cut in. The additional cooling is probably squeezing a bit more life out of the regulator and is stopping its own fan from operating.
I have repaired lots of these and have never found a faulty fan, or fan switching fault. There's always a first time of course.
It is more likely that the regulator IC001 is faulty and if you are technically skilled, I would suggest you seriously consider replacing it. Use some heatsink compound and an extra heatsink, and it will probably do the trick. The regulator is an STRG6353. You can get these easily online from a number of outlets. Don't attempt a repair if you are unsure of what you are doing. Regards..
Nov 18, 2007 | Panasonic DMR-E55 DVD Recorder
Suddenly won't read discs
just try playin the lens cleaner disc....
Sep 18, 2007 | Panasonic DMR-ES10 DVD Recorder
Permanent Disc Protection
Hi, UnFormat Problem 1. Try Panasonic DVD-RAM, format that on the recorder, donot finalize OR 2. Try this http://www.videohelp.com/forum/archive/repair-guide-for-panasonics-dmr-e60-gh-quot-unformat-quot-error-t299504.html There is a jpg image on the above URL for guidance Hope your problem vanishes :) Moulee mbchandru@gmail.com
Aug 03, 2007 | Panasonic DMR-E75V DVD Player/VCR
Televison & Video Logo
108 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
