Hi, I have a Sansui RZ-3700AV which was operating fine until one day it simply stopped outputing to the speakers. i have the same problem as this guy, i bought mine like that, what can the problem be?
SOURCE: No Audio OutPut When Cooling Fan Starts
I have the same rz 6880 av 5.1! bt im not facing that problem. Iv connected my Bose III series speakers to it...and it plays well. Maybe you need to check your system with a qualified personnel.
Posted on Feb 17, 2008
  • 4234 Answers
SOURCE: Sansui amp problem
This sounds like you lost the 5V supply. If you can solder, look for bad solder connections around the voltage regulator ICs. These look like transistors (3 legs) and may be attached to a heatsink. They will be marked 7805 +/or 7905.
Dan
Posted on Mar 24, 2008
SOURCE: Sansui RZ 1500 II-Manual
i have the same problem but my receiver doesn't change sources and its blocked on the last station llistened. the problem appeared when i washed the face of the receiver with a special spray. i think that i have done something very wrong like a short cut in the command processor. any help, please?
Posted on Nov 08, 2008
ravichetty
  • 158 Answers
SOURCE: No Sound
try switching the prologic mode on in the audio setup menu also switch front spks to small in the speaker setup
Posted on Jul 31, 2009
  • 3 Answers
SOURCE: My Sansui AU 999 blows a fuse every time it is turned on
If you haven't repaired your au 999 and wish to part it out, I'd be willing to buy a part or 2 from you. You can reach me at 1269@yahoo.com. Thanks, Mike
Posted on Aug 16, 2010
On my Sansui sw-100 sub, I have 2 speakers connected to the high level output, that dont operate
Yes in order to have audio going to your spare speakers from the sub .You would need to use the hi level inputs comming from the reciever outputs connected to these hi level inputs..The sub will then crossover the audio to their proper outputs..Hope this helps you
Jan 15, 2014 | Audio Players & Recorders
Sansui rz 9500 av ... there is not sound output from this unit. when I test the test tone... there is sound ... all the speaker is in good condition ... it work for the pass few week but suddenly not
Please check the settings and speaker connections. Do keep it unplugged then reset.
Sep 28, 2012 | Electronics - Others
SANSUI STEREO AV RECEIVER RZ -2605AV NO SOUND
Sansui RZ-2605 A/V Receiver no sound
• Check to see if the sound on the stereo receiver has been muted.
• If the stereo receiver has a headphone jack, make sure
no headphones are connected.
• Try a different audio setting on the stereo receiver.
• Check the speaker wires to make sure they are
connected securely to the stereo receiver.
• Try connecting different speakers to the stereo receiver
If these have already been done,
Symptoms still persist, service may be required.
hope these helps,
thanks for choosing Fixya for assistance.
Aug 07, 2012 | RCA Audio Players & Recorders
RZ-5100 Has Protector signal and wont turn on
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 23, 2011 | Sansui RZ-5300AV Receiver
I have a Sansui RZ-7001 home theater system but cannot get surround sound when connecting my LG Blu-ray BD 550 to it. What am I doing wrong?
fred i dutoi,
Check your connections first. Make sure your input on the Sansui RZ-7001 menu is selected to dvd. Also, make sure the blue ray cables are also inserted in the correct inputs on the rear of the receiver(dvd input). via. rca cables(red, white & yellow) the yellow is the video, hdmi, or optical. If you do not hear sounds coming from your speakers you need to check the separate volume levels for the speakers within the receiver itself. Front and rears having different volume levels within the receiver. Hope this helps. Also make sure you check the volume on the dvd player. Thanks for visiting FixYa.com. Have a great day !
techguy21
Jul 06, 2011 | Audio Players & Recorders
Feb 01, 2007 | Sansui RZ-5300AV Receiver
85 people viewed this question
 Grubhead
Grubhead
