Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Burn in lines after tv has warmed - Toshiba REGZA 42 in. Flat-Panel LCD HDTV
  • tomcatbois Apr 04, 2011
    The burn in lines are horizontal
    Sergeant:
    Champion:
  • 293 Answers
Vertical problem.Loose connection need for resoldering the vertical section the vertical ic.
Posted on Apr 04, 2011
Need to know if T-Con board needs replacement for my Samsung LCD TV?
Hi Michael,
Before replacing it, please check and thoroughly clean the flat ribbon cables to and from Tcon board. It may help. It is a delicate job and requires all the care. You may watch some Youtube videos about how to do it.
Aug 13, 2015 | Samsung Televison & Video
TV has line across screen, what could be the problem?
Don't leave the tv on you will burn a line into the screen because it's so intense.
You have whats known as "Frame Collapse" Have a tv tech sort it
Apr 11, 2014 | Televison & Video
Fan blows no heat
With engine warmed up, feel of heater hoses under hood to see if both are warm (careful don't burn yourself). If they both are warm, flapper door which directs airflow through heater is not working, probably because the actuator is bad or you have a vacuum leak. Check line under hood which goes to vacuum reservoir for vacuum, and check one way valve(check valve). Replace any old soft or cracked vacuum lines.
Feb 15, 2014 | 2003 GMC Yukon XL
The color is blue tint until tv warms up
this can happen as the set gets a bit older. the lamps inside burn extremely hot and do eventually burn out, this maybe the beginning of things to come. there is no fix shy of replacing a lamp which can be cost ly
May 07, 2010 | RCA P52939 52" Rear Projection Television
Picture goes to a single horizontal line.
Your problem is due to failure of the vertical scanning circuits in your TV. This is quite common and is caused by aging components. Generally drying out capacitors
You got to be careful not to leave it on too long when the picture collapses, it will burn a permanent line across the screen.
If you are an electronics expert you can fix it if you get a schematic. If not please don't attempt to reapir it yourself since there is high voltage in side the TV.
The problem may get worse with time.
Mar 13, 2010 | Toshiba 32D46 32" TV
My CRT TV displays a single horizontal white line across the screen. It will flicker and try to display the picture. If you smack it you'll get a quick picture then back to a line. After about 10-15...
The single line means that the vertical deflection doesn't work. And since it is working when you kick the tv or has warmed it's clearly a bad connection - open the case and reseat the wires going to the tube coil.
Dec 21, 2009 | Toshiba 32A33 32" TV
Black lines in tv
Most likely there are electrolytic capacitors in the power supply, video path, and scan amplifiers that are starting to fail from age. This is common in many of these sets. In consideration of the age of the set, this may not be worth having it serviced.
Jerry G.
Sep 24, 2009 | Toshiba 51H93 51" Rear Projection HDTV
Faint Vertical lines on Samsung LCD TV
Your correct, LCD's don't burn. This sounds like a defective main control module. I would take it in as soon as possible to have it looked at.
May 03, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Red lines across bottom portion of screen
usually strong magnets like those in speakers cause lines on tvs if placed to close to the tv.
so demagnitizing the screen should work .
you may have to take it into a pepair shop to do this.
but if thats not the problem. you moe than likely are seeing a common problem of tv screen burn out. and these new tvs tend to burn out faster than the old ones did.
Apr 26, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
138 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
