Question about HP LaserJet 5200tn Printer
Laser Jet 5200 PRINTER error 52.00 appears - HP LaserJet 5200tn Printer
    Genius:
  • 1,089 Answers
52.00 error is a "scanner motor" problem.
Replace the scanner motor 1st, 2nd replace the DC Controller.
If you are not a printer tech, you will need one.
Posted on Apr 04, 2011
SOURCE: nedd fuser diagram for the hpcolor laser jet 2600n
Replace fuser assembly
Posted on Apr 04, 2009
Prefab
  • 152 Answers
SOURCE: Hp Laser jet M1522nf
52 Scanner Error The product has experienced an internal hardware error.Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the product to initialize.
If a surge protector is being used, remove it. Plug the product directly into the wall socket. Use the power switch to turn the product on.
If the error persists, contact HP. For contact information, see www.hp.com/support/ljm1522 or the support flyer that came in the product box.
This is the internal laser scanner, if the error persists the scanner will need to be replaced by an HP authorized technician.
Posted on Jan 14, 2011
wheatlandsvc
  • 1110 Answers
SOURCE: HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Posted on Jan 05, 2010
Testimonial: "It worked. Thanks. I' just FIXYA again"
seeker5211
  • 1089 Answers
SOURCE: HP Laser Jet 4 Plus error code 52
A 52 error is a Scanner failure. Do you hear a "whirring" sound when you get the error?
That's the sound of the scanner motor running amuck.
You're probably going to have to replace the Laser/Scanner assembly or the DC Controller which controls the Laser/scanner motor.
Posted on Jan 23, 2010
TPWS
  • 52 Answers
SOURCE: My problem with my HP Color Laser Jet 2600n
Internal communication has occurred. Check the power source. formatter board or the DC Controller board could be faulty.
Good luck
Posted on Apr 24, 2010
My printer is showing error 59.0F Hp laserjet cp 2025
see some articles below for similar errors.
It does not appear to be user fixable error unless it is that debris to be cleaned. Printer HP Laser Jet CP4525 59 F0 Printer Error
Apr 28, 2016 | Office Equipment & Supplies
41.2 error hp laserjet 5200
41.2 error hp laser jet 5100
am from Ethiopia but when am check and replace the Formatter board ,beam not working but when am replacing the DC controller and all connecting cables to beam, then it was working god .
Feb 04, 2014 | HP Hewlett Packard LaserJet 5200 Printer
Hplaserjet 5200 rfu error problem
1- we want to instal printer to local computer
2- the computer cant sport the the usb line of hp laser jet 5200
3- the printer menu is locked and we can't change it in the printer screen show the rfu error for upgrade
Jun 11, 2012 | HP LaserJet 5200tn Printer
Hi..,please i want to change the language from chinese to english language for hp laser jet 5200
You will find to set the language in this manual:
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00575070/c00575070.pdf
There is also the possibility to change the settings via Web Server. You will find in the same manual how to use the Web server.
Jul 18, 2011 | HP LaserJet 5200 Printer
ERROR NUMBER 5200 why when i print a cheet on my
in's in caride.
ucan press resume and hold power and press resume 2x
Jan 25, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Hp laser jet 5200 paper jam in fuser unit
Hp printer paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Aug 25, 2010 | HP LaserJet 5200 Printer
52,00 printer error
A 52 error is used to denote incorrect scanner speed.
That is the laser beam scanner motor.
Cheers
DeJudge
Aug 02, 2009 | HP Office Equipment & Supplies
49.FF95 SERVICE ERROR
Please look on: http://www.fixyourownprinter.com/
There are much solutions of this problem listed ...
For example this (it see good):
http://www.fixyourownprinter.com/forums/printer/46157#1
HP Laser Jet 4250n by TLYNN (3/20/07 12:22 PM) reply + / -
Anybody know the error code "49. FF95 Service Error"
We can't get around this...
Firmware Error 49 by Stephen (edited 3/20/07 12:29 PM) reply + / -
It could be a bad job.
First disconnect it from your network and any PC it might be attached to.
Power cycle it, then if it goes to ready status try the built in test pages, do they work?
If the printer will go to ready status and you have a parallel cable with the proper connector, then you can try upgrading the firmware from a PC, you can also try to upgrade the firmware over the network.
More reading:
http://www.fixyourownprinter.com/search/forums?f=&q=49+4250
Re: HP Laser Jet 4250n by TLYNN (3/20/07 12:59 PM) reply + / -
Still won't go back to ready status. Turns on to the same error code....
Cold Reset HP Laser Jet 4250n by Stephen (3/20/07 1:03 PM) reply + / -
Try a cold reset, it will reset the JetDirect settings, but it's the next step.
Cold Reset:
Power off printer, wait about 5 seconds, then power it on, when asterisks start appearing on the display press and hold the check mark until all 3 lights come on solid, then use arrow keys to find cold reset and push check mark to perform the reset.
Re: HP Laser Jet 4250n by TLYNN (3/20/07 1:06 PM) reply + / -
Thank You so much for your help... but that didn't work either. Same error code showed up.
Re: HP Laser Jet 4250n by Stephen (edited 3/20/07 2:27 PM) reply + / -
Then you probably need to replace the formatter.
Do you have another printer you can swap parts with?
There is a slim chance the memory DIMM is bad, you can try it with the DIMM removed, if there is more than one DIMM you can try installing just one and then the other.
A 49 error indicates that the formatter could not understand or execute an instruction within a file or cannot interface with an accessory, DIMM, or EIO device. Troubleshooting 49 errors is done through process of elimination. First determine if the printer functions in a stand-alone mode then test communications to the printer.
These errors can be divided up into two categories; the associated troubleshooting depends on the circumstance the 49 errors are occurring.
A 49 error is always followed by Hexadecimal numbers, for instance, 49.00FF. The Hex code is a memory address. Most Hex codes are not documented.
Re: HP Laser Jet 4250n by dmzcompute (3/20/07 2:26 PM) reply + / -
I do not see anywhere where the printer has been disconected from everything. If you have not done so already disconnect every cable from the printer with the exception of the power cable and turn the printer back on and see if you get the error and if not report back here for further instructions.
Re: HP Laser Jet 4250n by Stephen (3/20/07 3:28 PM) reply + / -
You might also try disabling the embedded JetDirect.
To disable the embedded LAN port
Turn the printer power off.
Power on the printer and watch for the memory count to begin.
Hold down the SELECT (Checkmark) button, when you see the memory count begin.
Continue holding down the SELECT (Checkmark) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until EMBEDDED LAN DISABLED appears on the display
Press the SELECT (Checkmark) button. The printer then continues its power-on sequence with the embedded LAN disabled.
If this works the JetDirect built into the formatter is bad, you can either replace the formatter, or buy an JetDirect to install in an EIO slot.
Re: HP Laser Jet 4250n by Trev Pearson (3/20/07 10:08 PM) reply + / -
The only other thing to try, before spending money, is to get the network administrator to clear the print queue for that particular printer and then turn it on.
The theory being that a 'corrupt' print job is still in the system and as soon as the printer is turned on, that 'corruption' floods the network card with garbage which promptly goes 49.
If the printer comes 'ready', great. Then do a firmware upgrade. If not, then you will have to spend money on a new formatter.
Regards
Trev
Re: HP Laser Jet 4250n by roadrunner178 (6/21/07 2:09 AM) reply + / -
hi.
With a cold reset ,my problem solved.
try this as a first solution.
thank you
Re: HP Laser Jet 4250n by Anonymous (7/31/07 1:20 AM) reply + / -
THANK YOU WERY MUCH
FROM TURKEY
ZAFER
Jan 02, 2009 | HP LaserJet 2420dn Printer
HP LaserJet 5200tn Printer Logo
1,650 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
