Question about Canon Office Equipment & Supplies
I have a Canon IR1023N with a network plug that will not connect to the network. I have changed the wires and checked the IP adress several times put it acts as if the network card is turned off or not installed.
  • 36 Answers
After you change the IP address, you need to restart the Copier to take effect.
Posted on Apr 04, 2011
  • wcollins320 Apr 04, 2011
    I unplugged the unit and restarted it, but I still can not print. How can I check to make sure the network adapter is working properly, I can not ping the IP address from my computer it just times out.
  • Ashish Kumar Singh
    Ashish Kumar Singh Apr 04, 2011
    Please verify that the printer is having the IP address in the same range. Also check there is no duplicate IP to avoid clash.
I P ADRESS FOR MIVAR TV
To have an IP address, your TV must be connected to a home network or the internet...Is your TV a internet-enabled TV?Then there are three ways..
a) On the TV, go to network settings
b) From your router, check the DHCP table of the clients, if your TV is connected to your network, its IP should be listed.
c) Visit IP-details.com and get the IP.
Mar 01, 2014 | ip-adress.com
I have a canon IR5000 and have moved it to a new location, but the IP adress will not renew, How do I get this to Auto assign a IP adress when I plug it into the switch??
if you will not renew IP adress on Copier. you can adjust the all computer or PC in the new location.
then you ping to find connection.
but you must see else in this new location. are there use server for network system or not ?
if it's same with before location. you can do like as above.
try it.....
May 23, 2011 | Canon imageRUNNER 5000 Copier
HOW DO YOU NETWORK A canon imagerunner 1023
do You want to connect the machine on network or .... ?
First check if you on back side of copier have the network connector.
If yes, you need to connect the normal network cable if you have network switch or cross cable if you are connect directly on PC.
Then you must enter the IP adress in machine, under user mode (*) under system settings, under IP adress.Also enter subnet and gateway adress.
Free IP adress you can check on your pc under CMD and type ipconfig, to see your ip, subnet, and gateway.Then type : ping XXX.XXX.XXX.YYY The YYY marks number that you can change and must not be same as yours PC.After typing ping .......... and you have answer DATA LOST that means the ip is awailable and you can type it in copier.
Install drivers and select tcp/ip port.
If these isnt solution that you asked for, you can also contact me on emma.servis@gmail.com with more detailed description.
Hope that helps!
Sep 02, 2010 | Canon imageRUNNER 1023iF Black and White...
How to know ip adress for Canon ir c6800
Network settings are in the additional functions> system settting > network settings. If your printing to the copier the ip address should be there in the network settings.
May 13, 2010 | Canon imageRUNNER C6800 Copier
When I type my IP adress onto the browser nothing happens.
Plug your laptop or wireless device directly to the router using a network cord. If you still cannot access your router through a hard wire connection, unplug the router for 45 seconds and plug it back in. Then restart your computer while it's still hard wired to the router.
Your router IP address by default should be 192.168.1.1. In order to make sure you are on the same network, click on start > run and type cmd or open a command prompt by typing cmd into the search field under vista and windows 7. Once you have a dos window open, type IPCONFIG and make sure that your IP address is 192.168.1.x. x represents any number that would be leased to your computer from the router. If you do not have that a 192.168.1.x ip address, DHCP might be turned off on the router and you will have to set up a static IP address through networking and connections managment, or network properties in windows xp.
In order to do this go to your control panel and into the networking icon. Find your LAN connection and right click and then left click on properties. Once it's open, click on TCP/IP and then click on properties. Change the raido buttons from Automatically Obtain to Manual and for the IP address type the following:
IP Address: 192.168.1.100
Subnet Mask: 255.255.255.0
Default Gateway 192.168.1.1
Click OK twice and try and connect to your router through the default IP address of 192.168.1.1.
If you had to configure your IP manually, make sure you go back in there and change it back after you configure your router for DHCP.
Have a great day.
Jan 23, 2010 | Zyxel Prestige 600WH Wireless Router...
I recieve error that I can't get a Ip adress. WEP security password goes to the router but no Ip adress is making it back . I've tried loading a static IP adress, using another unsecured network. resetting...
Try using the HEX password instead of the ascii passphrase - also try to reset your AP temporarily in order to test the connection without ANY wireless security - if that doesn't connect, then the problem probably lies in the wireless router itself.
Oct 20, 2009 | Microsoft Xbox 360 Elite Console
MX-M350N will not print on Windows Vista
tell your network person set your copier to a staitc IP it seens that each time you turn on your systems depending on what order the computer go on something in your network is assing differant ip address -- or you haver loose cable or bad wiesless netowk to check this you can ping the ip adress of the copier when it not working to see if the request ( times out )if it does -check the router and wires for a loose cable ---i have not seen to many bad network pcb in sharp copiers but that possible too more likliy its juist a set up problem or loose or bad connection
Mar 11, 2009 | Sharp AL 1631 Copier
Can't connect Canon Pixma MX310 to wireless network!
This printer does not have a network interface. There is no ip address for this printer. You must connect via usb.
Jan 21, 2009 | Canon PIXMA MX310 All-In-One Printer
Wireless shows connection,but will not connect.
This kind of problem occur due to dhcp disable in the wireless router for the security purpose. So try to give the ip adress manually by right clicking on the wireless and give the ip adress of the same range in which your network in working e.g 192.168.1.0 is the range of your ip addresses so please select the ip which is not been used by any other computer and than in default gateway enter the ip address of you wireless router and you will be able to access the internet on your system.
Dec 01, 2008 | Linksys Wireless-G WRT54GS Router...
Cant connect to http://192.168.0.50
what you need to do here is manually set your static IP adress, I had this problem as well and I know what to do.
you need to go to your network connections ( Controll panel>network connections) in xp (Controll panel>network and sharing center then left hand it sais: change adapter settings )
then rightclick your wireless connection and look at it's properties. then you need to click on Internet Protocol, for vista/windows 7 it's internet protocol 4 which you need to select. once selected click on properties just a little below.
there you'll see the setting is on: obtain Ip automaticly, but you'll have to choose ( use the following IP adress ) and enter
IP adress: 192.168.0.99
subnet mask: 255.255.255.0 Default Gateway: 192.168.0.50
once entered press OK and now go to your browser and type the routers adress (192.168.0.50) in my case and now you should be in your modems setup menu.
once changed your setting you need to change your IP back to auto obtain IP adress. or your internet still won't work
Oct 20, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
80 people viewed this question
old marine
old marine
