Question about Rule A-Matic Float Switch
Our engine bilge pump is almost inaccessible but I can just about reach it. Lifting the float switch the pump doesn't work but using a switch at the helm the pump works. Is there something I can do without having to remove the engines to access the pump? I have a Hardy Seawings 305 with Volvo KAD32 engines. I've had it from new in 1998 and never yet had to use the pump.
  • 8,206 Answers
Hi, if you can switch on the pump, it's OK. Usually, the pump needs the helm switch on AND the float up. Does the pump not shut off when you push the float down? That would be normal operation, unless the helm switch has both automatic and manual settings.
Posted on Apr 04, 2011
  • 4 more comments
  • f_cutler Apr 04, 2011
    The helm switch overides the float switch and can work the pump independantly. It's the float switch that's not working the pump when it's in the up or down position. The helm switch is a rocker and presumably sits normally in the "ready" position for automatic use with the float.
  • Jeff Turcotte
    Jeff Turcotte Apr 04, 2011
    OK, and are you saying you cannot access the float switch to replace it? I don't have any data on your boat, but I can't imagine having to pull the engines to access the float switch. What I would do if I could reach the switch is to pull the fuse, cut the wires, install a waterproof connector, and connect a new float switch.
    Easier said than done. I was wondering how the switch worked - mercury switch ?? or if there are any known issues with them. The boat's 13 years old and the swwitch has never had to work. can any connections corrode etc?
  • Jeff Turcotte
    Unfortunately this company was bought by ITT, and data from older models is scarce. They used to use mercury, but not sure exactly when they stopped. You can access current literature here: http://www.ittflowcontrol.com/files/artd...
    Thanks for your help.
  • william moore
    william moore Dec 13, 2011
    Typically they were a mercury switch. If you can access the back of the switch on the dash, check to see if it has 3 wires. One (the center one) will be the hot side the other two will be #1 for the manual over ride, and #2 for the auto float. Jumper the hot to the wire that does not run the pump and go lift the float. If it will run the pump, replace the dash switch. Seldom were float switches set to run all the time, you had to turn them on with a 3 way pump switch.
How to resolve oily bilge water problem.
Could be fuel line leak or even exhaust fume condensation.
Mar 05, 2017 | Cars & Trucks
Bilge pump will not shut off
check the float micro switch or that something is not under the float holding it up.
May 25, 2015 | Boating
How to wire a 12 volt automatic bilge pump. In a boat.
Hopefully the float switch for the Bilge pump is under the engine not the pump motor. Having an electric motor under an engine is a fire or explosion hazard Find the float switch for the motor and follow the tubing back to the pump. A replacement pump should have instructions. Only the pump intake should be in an explosive environment.
Aug 24, 2014 | Boating
Little Giant 506065 - 2 did not work after 21 days, different pump better?
Are you running these pumps full-time, even if they're dry? If you are, that's far beyond their design. The sink should drain into a sump or cistern, then the pump should empty the cistern on demand from a float switch.
I don't know of any pump except possibly a bellows-type bilge pump, that can be expected to run full-time, even when dry.
Aug 13, 2014 | Little Giant Plumbing
Pump won't stop running
It has an inbuilt float switch that may be sticking. Pull it out and tap it this may fix it. If not it will have to be replaced. Regards Phil
Apr 12, 2011 | Rule Mate Fully Automated Bilge Pumps...
Stopped working
The float is usually the culprit if it is not turning on. I f you have a floating ball type float switch try lifting it up and shaking it to see if pump starts running. These micro switches stick after several years use. If you have a round canister on the side it is a pressure activated switch that also has a micro switch inside that completes the circut when the pressure on the diafram is enough to click the switch. I f it has a float on a rod it has a switch at the top of the pump that shuts it off when at low level, and turns it on at high water level. Most pumps have a two part cord. The pump plugs into the float control switch, so it does not get power till the float switch clicks on. If you have a two part plug, then separate them and plug the cord in that leads directly to the pump body. This will tell you if the pump is working. If it is then replace the float switch assembly. Also there is either a few screws holding the pump screen on to the pump on the underside. Some simply snap fit to the pump body. Often I will find stones, wood chips string etc. in the pump impeller. That is what pumps the water by squeezing it into the small 1 1/4 output orifice. That about covers it. Please post to fixya.com if it does, so I get the credit for the solve. Let me know if you do need more advice. Good Luck!!!
Mar 18, 2011 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
Pump will not stop runningmjn
This seems like a switch problem resulting in dry cycling. Can you turn on/off the pump by lifting the float switch? Is your switch attached or plugged in to your pump? I believe your on your model it is hard-wired. If so, bring it back to the retailer/wholesaler from whom you bought it.
Feb 18, 2011 | Flotec Automatic Sump Pump Float Switch
I'm trying to wire a 12v bilge manual pump to a
You run your hot wire to the switch (brown) and black wire to the pump (+ve connection). Then from the pump run another wire to the negative terminal of your battery. I used to use a toggle switch on mine, but I do not use a starter motor, still all the lights, radio and echo sounder are connected to it (via a junction box). The only item I fuse is my echo sounder.
Feb 03, 2010 | Boating
Wiring on bilge pump
There's an installation manual available online. Black is negative ground; either brown or brown/white will turn on the pump. The intent is for a three way switch, connecting brown/white directly to positive 12 VDC while brown would go through an automatic switch (e.g., a float switch).
Mar 27, 2009 | NRS Kayak Bilge Pump with Float
Rule A-Matic Float Switch Logo
197 people viewed this question
Top Rule Boating Experts
Jeff Turcotte
Jeff Turcotte
Phil Walker
Phil Walker
Mike
Are you a Rule Boating Expert? Answer questions, earn points and help others
