Question about Grundig S350 AM/FM/SW Radio
Grundig r2001 radio error 3 cant sort it after flat batt
    Problem Solver:
  • 5 Answers
The picture shows an S350 -- if your model looks like that but with a different designation this fix may still work:
Look above the gain knob (bottom right) and then above the Tuning fast -- slow lettering. You should see a reset hole. Use a paper clip to reset the radio.
Ringbearers
Posted on Apr 09, 2011
  • peter green Apr 11, 2011
    no help but thanks anyway
Grundig Sattelit 800 radio-batt blinks w/new Duracell Alkakines from Costco(so they are fresh; good till 2024)
I have talked to the gentleman who designed this radio and he said that in order to correct this problem two pins on the inside of the front panel must be shorted while 6.2 volts dc is fed to the battery terminals. The whole radio must be disassembled to reach these pins, I have not been able to find a service manual to help me locate said pins. If anyone out there can find out where to get a service manual please contact majik2387@aol.com
Oct 20, 2014 | Grundig Satellit 800 AM/FM/SW Radio
My Grundig s350 radio powers off as if it is on some sort of timer. I cannot figure out why or how to stop it.
The ON button is also a SLEEP timer. The timer can be set to 90 minutes, 75, and son on. The shortest time period is about 1 minute. Press the ON/SLEEP button several times. After each press read the number displayed. As you push the button again you will cycle through all available timer settings. Choose one that its long enough for you.
However if you press the ON/Sleep button for a few seconds the radio will play continusously until you turn it off.
Just play with the RED button a few times to get an idea how long to press to make the radio play continuously.
Feb 13, 2013 | Grundig S350 AM/FM/SW Radio
I lost my code for my vectra CD radio
I have a Vauxhall Astra and i have lost the code for its can anyone help me please. Below are the details on the radio
Delphi Grundig
GM497316088
No. 13289921
Thank You
Feb 24, 2010 | Blaupunkt Car Audio & Video
Decode my car radio
The code for GR0971T6197837
is 2 8 8 6
Nov 03, 2009 | Grundig G4B AM/FM/SW/RDS Radio
Need: Volume- and batt indic-levers for grundig satellit1400 (these are the buttons passing through the front)
I will try to get the spare parts here in holland. (Nedis Consumer Electronics e.g.).
Or in the worst case it could be possible to glue the things together.
Thank You for your assistance.
Guus(=August) Janssen
Jul 18, 2009 | Grundig Satellit 800 AM/FM/SW Radio
Grundig yacht boy 400 radio does not work with mains operations
I had the same problem. Examined the wire from the transformer,and found a break. Repair of the wire solved the problem. WLD
Mar 01, 2009 | Grundig YB 400PE AM/FM/SW Radio
G4000A
Once you turn the unit on, the battery indicator should disappear. Make sure the batteries are inserted correctly. With six AAs, I've put them in backwards on more than one occasion.
Hope this helps.
Mar 02, 2008 | Grundig G4000A FM/AM Radio
Grundig car radio codes
There are 3 ways you can get the radio code:
1. Reference your car manual or the Grundig's manual that came with the unit. Most times, there is a sticker on the manual with the radio code printed;
2. Call/visit the car dealer and explain your issue. You may need to show proof of ownership of the vehicle and/or the radio;
3. Use firms who specializes in this. You can try here, here or here.
If the Grundig is the original radio installed when the Vauxhall Astra was new. there are some unconfirmed reports that the radio code is also stenciled on the metal plate where the Vehicle Identification Number is.
Hope that this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Jan 22, 2008 | Car Audio & Video
Grundig car radio
Make sure that the radio and the ignition are both turned off. On the radio, press and hold down the 'AS' button, then turn on the ignition. After about 3 seconds the radio will beep. Release the AS button. enter the code using the buttons 1,2,3, & 4. For example, if the code is 4739 press, button 1: 4 times button 2: 7 times button 3: 3 times button 4: 9 times When you have entered the code, press and hold down the AS button again until it beeps and your radio should now be reset.
Sep 02, 2007 | Radio Communications
I need to know how to set the radio presets for the Grundig.
If you go to this link; http://www.amazon.com/Grundig-G2000A-AM-Shortwave-Radio/dp/B00000JD4T/ref=pd_bbs_sr_3/104-1966292-9407907?ie=UTF8&s=electronics&qid=1175876962&sr=1-3 This is the same model, and under "product details" you can download the manual. Page 21 of the manual (page 10 of the pdf file) should tell you what you need to know. Hope this helps :)
Apr 06, 2007 | Grundig Yacht Boy P2000 AM/FM/SW Radio
Grundig S350 AM/FM/SW Radio Logo
306 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
