Question about Samsung Digimax S700 Digital Camera
Hi can I use a sdhc memory card in a digimax s700?
otacon
  • 1944 Answers
SOURCE: Can I use a memory card SD 2Gb in a camera Samsung Digimax S500 ?
Yes, you can use a 2 GB SD card in your camera.
Posted on Feb 27, 2008
Steve5
  • 423 Answers
SOURCE: "Card Not Initialized with 4GB CF memory card"
The 4gb cards are a newer type of SD card called SDHC (Secure Digital High Capacity). Most of the S700 production was before SDHC cards hit the market. Later production S700's had been internally tweaked to accept the SDHC cards. 2gb is the largest you can go on your S700's, but beware, some of the 2gb cards are SDHC also, now.
Posted on Oct 07, 2008
t00nz
  • 4738 Answers
SOURCE: My Powershot 450sd camera is not reading 4GB SDHC
SDHC memory cards are relatively new, and are sadly compatible with only the newest model cameras. For your model camera, recommend a maximum 2GB standard SD card. Fortunately, these days a 2GB card is very inexpensive.
Posted on Dec 29, 2008
  • 3 Answers
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
Posted on Jan 28, 2009
mail2pvs
  • 390 Answers
SOURCE: s d card wont work
hi my understanding the camera can take only a max SD Card size to 2GB you may wanna check on that
Posted on Jul 23, 2009
Is sony sdhc compatible with samsung digimax s500?
The S500 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Apr 04, 2014 | Samsung Digimax S500 Digital Camera
Can I put a 16GB memory card onto an S700 camera
No. The S700 works with MMC and SD cards, which top out at 2GB.
Apr 03, 2014 | Samsung Digimax S700 Digital Camera
I have a Samsung Digimax S700 and the memory card has become locked. How do i unlock it please?
Look for a tab on the side, usually yellow, that has an up arrow that says "Lock". Slide thaqt the opposite way and you card can be used again.
Hope this helped!
Be Sure To Rate macapplezoo 100% Or Whatever You THink I Deserve!
Jun 03, 2011 | Samsung Digimax S700 Digital Camera
Recently bough a Lexar SDHC 8 GB memory card and now my Samsung Digimax A503 camera won't turn on with the card in. It will power up for about 15seconds and than shuts off. The camera works fine without...
Hi.
The 8GB memory card is too big. The Samsung Digimax A503 only supports SD cards up to 2GB and is probably the reason the camera is turning itself off.
Click on the link below to see for yourself.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Samsung/Samsung+Digimax+A503_Memory_Cards
Regards.
May 01, 2011 | Cameras
New 4G memory card states full have re-formatted but still shows full. Have tried a 2G card but that is ok to use any ideas please
Your new 4GB card is an SDHC card. The S700 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to go with cards 2GB and smaller.
Jan 10, 2011 | Samsung Digimax S700 Digital Camera
Will sdhc card work in my fuji s700 camera
The SDHC memory card is a newer version of the SD card and will fit in the memory card slot. However the maximum memory capacity your camera is capable of is 2gig, beyond this the card may not work. You may be able to extend this capacity with a firmware update from the Fuji site.
The SDHC memory card has a lock the same as your SD card here is a diagram to make sure the lock is in the correct position for use. Remember also to format the new card and format after each download of pictures to the computer.
Diagram
Jan 02, 2011 | Fuji FinePix S700 Digital Camera
Will sdhc memory card work with S700?
No. The S700 works with SD and xD cards, not with SDHC cards.
Nov 20, 2010 | Fuji FinePix S700 Digital Camera
I just bought a brand new scandisk 4gb card and it says that the memory is full even though i didn't take any pictures... what do i do?
The S700 uses SD cards. Your new 4GB card is actually an SDHC card. While it will fit into the slot, it will not work in the S700 (as you've discovered). You'll have to limit yourself to SD cards, 2GB and smaller.
Jun 22, 2010 | Samsung Digimax S700 Digital Camera
Memory card saying "full" when its not
Your problem is that you are using an incompatible type of memory card.
Your camera was designed to use SD cards with a maximum capacity of 2GB. It cannot use larger capacity models, and is also incompatible with the later SDHC cards.
SDHC cards are the same shape and will fit your camera, but have differences beneath the skin and so won't work properly in your camera. Without any memory card in place your camera uses internal memory; it's then only by lucky chance that your camera has sufficient SDHC compatibility to allow you to transfer the internal memory image to the SDHC card when you subsequently insert it into your camera.
Your only solutions are to either use an SD card with a maximum capacity of 2GB or to replace the camera with a later model which is fully SDHC compliant.
Apr 29, 2010 | Samsung Digimax D73 Digital Camera
Steve, S700 and S7000 are different beasts.
S7000 is only rated for 1Gb compact flash cards. It apparently works with 2Gb ones but as I and a lot of others have discovered no matter how you tweak around sectors and clusters it won't read the thing.
This is a Fat16 limitation.
Sep 28, 2008 | Fuji FinePix S7000 Digital Camera
Samsung Digimax S700 Digital Camera Logo
71 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
