Question about Garmin StreetPilot 7200 GPS Receiver
Suddenly have no audio from speaker or earphone jack
* Settings
Audio Output--internal speaker
Guidance and tones--On
All volume levels--100%
Mute--Off
What am I missing?
Steve
  • profsteve Aug 12, 2008
    The Garmin is working perfectly except for the sound.
  • profsteve Sep 04, 2008
    To tech 48,
    I just found your comment. Garmin wants $350 ifI return it for service. Thanks for trying
    Steve
    Master:
  • 638 Answers
The settings you have done are proper
This may be a cold solder connection or mechanicaly defective component on the circuit board. There are many parts in that unit that can cause the described fault.
still try this
connect it to my car stero via a
cassette adapter.
hope this helps.
thanks.
please do rate the solution.
Posted on Sep 04, 2008
    President:
  • 624 Answers
You do not seem to be missing anything. Sorry to say, you may just have a bad audio circuit in the unit. You can try resetting it. If it has a reset button press it and see if that helps. If you have no reset button, disconnect power for a few minutes and then reconnect it and see if that helps.
You seem to have the settings right so other than a reset there is not much you can do with it but take it to a service center that works on them. It may be hard to find one locally, parts and service data are not readily available for Garmin products. Here is the information you would need to get in touch with Garmin.
Website url:
http://www8.garmin.com/support/warranty.html
Other information:
STEP 1: Contact Garmin Technical Support to receive an RMA number.
Suddenly have no audio from speaker or earphone ja - greycornerrightcccccc.gif Call or e-mail Garmin Technical Support Specialists to describe the problem you are experiencing and request a Return Material Authorization (RMA) tracking number. You will need to provide the unit's serial number (if applicable), your return shipping address, and a daytime telephone number.
***Aviation Panel Mount or Aviation Remote Mount products require an authorized person to return the aircraft system to service after product repair. Please arrange RMA's through your favorite Authorized Garmin Aviation Service Center.***
Phone: 1-800-800-1020 913-397-8200 Fax: 913-397-8282 For Garmin AT products only: Phone: 1-800-525-6726 (U.S.) 1-800-654-3415 (Canada) 503-391-3411 Fax: 503-364-2138
STEP 2: Ship the unit, along with the RMA number, to Garmin.
greycornerrightcccccc.gif Once you have received the RMA number, securely package the unit and ship it (insured) to the following address:
Garmin International 1200 E. 151st Street RMA Number: (insert your RMA number here - see above) Dock Door #18 Olathe, KS 66062 USA For Garmin AT products only: Garmin AT, Inc. RMA Number: (insert your RMA number here - see above) 2345 Turner Rd. SE Salem, OR 97302
Posted on Aug 08, 2008
    Brigadier General:
  • 3,614 Answers
Is display icon appear on the unit are all normal?
  • micromaster
    micromaster Sep 04, 2008
    did your unit has an earphone plug or any auxillary speaker output.. kindly check and test by plugging an earphone..
    let me know
Audio jack not working for my earphones?
I would try another set of headphones and see if it works. Try changing the volume level and see if that helps. You could also try a set of powered computer speakers to test the jack. The audio jack may not output enough power for your headphones. There is also a chance the audio jack could be defective.
Oct 26, 2016 | Televison & Video
When plugging in a wireless headphone in the audio output the tv's speakers shut down.How can I stop this
The speaker cutout feature whenever the headphone jack is connected is a hard-wired feature of the headphone connector, and cannot normally be bypassed without further electronic circuitry and the associated surgery to install a custom modification in the TV. In order to keep the TV speakers on while using the sound elsewhere, you will have to take the audio output from the IR Audio port, if there is one.
Apr 02, 2015 | Olevia LT37HVS 37 in. LCD HDTV
Macbook pro headphone audio
Go in to the "applications>utilities" folder. Run the "Audio/MIDI Setup" program. Insure the audio out is actually going to the headphone out.
Mar 21, 2013 | Apple Computers & Internet
Suddenly I have no sound on myVizio tv
Assuming that your remote is working and you see the on-screen volume overlay, I would check the audio settings from the setup menu. make sure it has the sound on and output to the internal speakers of the TV. If that is okay, try plugging some kind of audio device like external speakers into the output jacks on the rear of the TV. Audio rarely fails on a TV, however this could require service if you can't get any audio out of the thing.
Feb 03, 2011 | Vizio Televison & Video
Re Sony VAIO F12 (new unit): Audio is barely audible using onboard and external speakers, even though volume bar indicates volume is at highest level. Any way to increase audio volume? Thanks.
1. Yes, check to see if you have the volume up for the wave file turned up that is on the program you are using to listen to the Mp3 or sound wave with.
2. check the speaker connector/ Use another speaker that is know to be good and test. Use a set of earphone in the output jack also to test the output.
If these things are doing the same then you have failing sound card and it needs replacement.
Aug 10, 2010 | Sony VAIO FR130 Notebook
Hook up speakers to 32 inch lcd hdtv
"Line" level audio output is available at the audio output phono jacks at the top of the rear panel, but not speaker-level output. So, you'll need an amplifier to use in conjunction with your external speakers. (An alternative would be "powered" or "amplified" speakers that have their own amplifier, but often are less satisfactory acoustically). You don't necessarily need to get a full-fledged "receiver" with multiple in's & out's... I simply used an inexpensive stereo amplifier.
Connect the "Audio L - R" jacks on the rear of the set to the "line" or "aux" inputs on your chosen amplifier and speakers. If you go into the set's Menu - Option - Output Select and set it to "Variable", the internal speakers will be disabled, and you can control the volume (and muting) of the audio sent to the amplifier, and still have "armchair" control of the volume as before... but now with better stereo!
May 16, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No sound
What kind of monitor is it? What kind of sound is it?
Many companies will let you access and print out their manuals for free online if you input your model and make on their website. Search under "manuals".
Also, the HP w22 LCD I have has internal speakers whose settings and volume levels are controlled through the buttons on the front bottom of the monitor. The monitor has a 'PC Audio In' jack on the back side, which is used to input the digital signal from the back 'audio output' jack of the computer desktop. This HAS to be plugged in with a specific audio cable to power (transmit the digital signal to) the internal speakers.
Check your settings for your external speakers by clicking on 'control panel', then 'hardware', then 'speakers' (IF your computer has located them, meaning that they're plugged in with their driver downloaded). You should be able to configure the speakers and test them for sound.
Windows may have a 'volume mixer' on your taskbar that controls the levels of your Windows application sounds, your device (speaker) sounds, and the Media Player(s).
Dec 11, 2008 | Computers & Internet
Very low volume
check the mode button and make sure you are in the right mode, sounds like you have it in the wrong mode.
Sep 16, 2008 | Icom IC-R10 Handheld Scanner
Volume control doesn't work on the enternal speaker
On some sets that have audio output jacks, the level of the audio output on the RCA jacks is fixed, and it does not change with the TV's volume control. On some sets, such as Sony, you can choose fixed or variable output. I have also seen some sets that have both fixed and variable RCA jacks on the back. With variable audio out, the audio level at the audio output jacks follows the TV's volume control. If you go into the TV's menu and navigate to the audio page, look for fixed or variable output options. If you have the owner's manual, read the section on audio output. If variable output is not an option on your model, then the level is constant and the volume will have to be adjusted with the stereo's volume control.
Aug 25, 2007 | Toshiba 27DF46 27" TV
No sound through speakers, but ok through headset
u have a problem either on the speaker or on the sound amplifying circuit. signal coming from the earphone jack is not amplified. check the speaker first. if its ok then check the audio output ic(integrated circuit). good luck!
Jan 31, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Garmin StreetPilot 7200 GPS Receiver Logo
142 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
