Heat sign during heating time blinks but on reaching set temperature stops blinking is it ok
    Brigadier General:
  • 4,736 Answers
Yes, it's functioning correctly.
Posted on Apr 04, 2011
Testimonial: "xcellent"
I need an instruction manual for a cooks essentials air fryer
How to Use Your Fryer:
  • Remove all packaging materials, sticker, and labels.
  • Clean the basket and pan with hot water, soap and a non-abrasive sponge. These parts are dishwasher safe.
  • Wipe the inside and outside of the appliance with a clean cloth.
  • Place the air fryer on a flat and even surface.
  • Put the basket in the pan.
  • Plug unit in to an approved wall socket.
  • Place the ingredients in the basket and then put the basket and pan back into the appliance. The fryer LED will light up.
  • Set your cooking time and temperature by either choosing one of the 8 presets or manually set it with the "+" or "-" buttons. See "Cooking Guide" to determine the right time and temperature.
  • Once you have set your cooking time and temperature, press the "Start" Button.
  • The heating icon and fan icon will be blinking and this means that the fryer is starting and is circulating the hot air in the fryer. NOTE: During hot air frying, you will notice that the heating up icon will blink and stays from time to time. When the heating icon is on, it means that the temperature inside the fryer has reached the set temperature. When the heating icon is blinking, it means that the temperature inside the fryer dropped and is below the set temperature and is currently heating up to the reach the set temperature.
  • Some ingredients may need to be shaken halfway through the cooking cycle (see "Cooking Guide"), To do this, pull the pan out of the air fryer by the handle, the air fryer will automatically shut down. Then shake the contents in the basket, then slide the pan back into the air fryer and it will resume the cooking cycle. CAUTION: Do not press the button on the handle during shaking; this will detach the basket from the pan.
  • When the cooking time has been reacher, the air blower will stop in 20 seconds.
  • Pull the pan out of the fryer and place it on a pot holder. The cooking pan is VERY HOT do not put on surface that can burn. NOTE: Oil from the ingredients will gather in the bottom of the pan, so be careful when pulling the pan out of the fryer.
  • To remove the ingredients, press the button on the handle of the pan to detach the basket. DO NOT TURN THE PAN OVER. PLACE ON A POT HOLDER.
  • Upon placing the cooking basket back into the air fryer, the air fryer will automatically go to the previous cooking cycle and will repeat the previous cooking cycle, press the cancel button to stop and reset the air fryer if desired.
Mar 25, 2016 | Kitchen Appliances - Others
Green power light only on trevi exclusive
When power is turned on, the coffee selection button should blink during warming up. If it is not blinking then the following i possible:
1- The electronic sensor is bad. It is clamp mounted on the boiler to sense temperature and send message to control board to turn the heating off when it is ready to make espresso. The blinking light will be fixed to display this.
2- The heating element on the boiler is bad and not heating. The electronic sensor cannot relay any temperature as it is.not sensing the heating.
3- The electronic control board is bad and not sensing the temperature.
The machine should be opened up to test the sensor or the neating elements, and replace what is bad..
Aug 31, 2014 | Spidem Trevi Automatic Espresso Machine
Legit repair?
The stack blower can fail with the symptom described, but twice within 5 years? Maybe. If the temperature is less than the thermostat setting, there may be a cracked heat exchanger but depends, to some extent, on how old the furnace is.
Dec 11, 2013 | Heating & Cooling
RECO is blinking on the thermostat
The thermostat is in recovery. It automatically senses how long it takes to heat your home so that when you schedule it to turn on at say 6AM, it will turn on in time to reach the set temperature by 6AM.
Oct 15, 2013 | Heating & Cooling
Samsung DMT - 400 delicate light blinking
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
How do you program this heater
temp setting
1. press the temp/timer button untill the temp icon blinks
2 use up and down arrows to set temp.3 the temperture icon will stop blinking and the current room temperture will appear after desired temp. is set.
4 the heat will turn off shortly after the desiredtemp. is reached and the temp. ndisplay will blink.
5 the heater will turn back on when room temperture drops below the set temp.
timer : auto -off press the temp/time button untill timer icon blinks. the hour display will apear. the auto off icon will also appear.
2. use up and down arrow buttons to set the heater operation time between 1 and 10 hours. this function will activate once the timer icon stops blinking.
3. the heater will automaticly turn off when time runs out.
set temperture first so heater will cycle on and off till shut down time reached
Feb 02, 2011 | Comfort Zone CZ9009 Oil Filled Electric...
What is code H4-01
H4 01 Heat roller low temperature
detection (HL2)
•The set temperature is not reached within
the specified time (normally 3 min) when
warming up or resetting from pre-heating.
•Under the ready state.
(An input voltage of 1.21V or below is
detected 5 times continuously.)
Cause
thermistor trouble
Heater lamp trouble
Control PWB trouble
Thermostat trouble
AC power trouble
Interlock switch trouble
Use DIAG (SIM5-2) to check the heater lamp
Blinking operation.
If the heater lamp blinks normally:
Check the thermistor and its harness.
Check the thermistor input circuit in the
control PWB.
If the heater lamp does not light:
Check for heater lamp disconnection and
thermostat disconnection.
Check the interlock switch.
Check the AC PWB and the lamp control
circuit in the control PWB.
Use DIAG (SIM14) to cancel the trouble.
Jan 25, 2010 | Sharp Digital Imager AR-407 Black and...
VW Cooling System
Hi Lori . Sorry but it sounds like your water pump inpeller (The internal part that circulates the water) has broken off or come lose . But i would recomend changing the cambelt and tensioner as well . Regards VW Audi tech
Jan 09, 2009 | 2001 Volkswagen Beetle
Xterra repair
Since this is an intermittent problem, first try to determine if the problem arises due to one of these many intermittent problems:
* Vehicle vibration
* Heat sensitive
* Freezing
* Water intrusion
* Electrical load
* Cold or hot start up
If you can't isolate the cause of the intermittent problem, you can try adjusting the Idle Speed/Ignition Timing/Idle Mixture Ratio:
Idle Speed/Ignition Timing/Idle Mixture Ratio Adjustment
PREPARATION
1) Make sure that the following parts are in good order.
* Battery
* Ignition system
* Engine oil and coolant levels
* Fuses
* ECM harness connector
* Vacuum hoses
* Air intake system
* (Oil filler cap, oil level gauge, etc.)
* Fuel pressure
* Engine compression
* EGR valve operation (If so equipped)
* Throttle valve
* Evaporative emission system
2) On air conditioner equipped models, checks should be carried out while the air conditioner is OFF.
3) On automatic transmission equipped models, when checking idle rpm, ignition timing and mixture ratio,
checks should be carried out while shift lever is in “N” position.
4) When measuring “CO” percentage, insert probe more than 40 cm (15.7 in) into tail pipe.
5) Turn off headlamps, heater blower, rear defogger.
6) Keep front wheels pointed straight ahead.
7) Make the check after the cooling fan has stopped.
INSPECTION PROCEDURE
1 INSPECTION START
1. Visually check the following:
I Air cleaner clogging
I Hoses and ducts for leaks
I EGR valve operation (If so equipped)
I Electrical connectors
I Gasket
I Throttle valve and throttle position sensor operation
2. Start engine and warm it up until engine coolant temperature indicator points to the middle of gauge.
Ensure engine stays below 1,000 rpm.
3. Open engine hood and run engine at about 2,000 rpm for about 2 minutes under no-load.
4. Perform diagnostic test mode II (Self-diagnostic results).
OK or NG
OK ' GO TO 2.
NG ' 1. Repair or replace components as necessary.
2. GO TO 2.
2 CHECK IGNITION TIMING
1. Run engine at about 2,000 rpm for about 2 minutes under no-load.
2. Rev engine (2,000 to 3,000 rpm) two or three times under no-load, then run engine at idle speed.
3. Turn off engine and disconnect throttle position sensor harness connector.
4. Start and rev engine (2,000 - 3,000 rpm) two or three times under no-load, then run at idle speed.
5. Check ignition timing with a timing light.
15°±2° BTDC (in “P” or “N” position)
OK or NG
OK ' GO TO 4.
NG ' GO TO 3.
3 ADJUST IGNITION TIMING
1. Adjust ignition timing by turning distributor after loosening securing bolts.
2. Turn off engine and connect throttle position sensor harness connector to throttle position sensor.
' GO TO 2.
4 CHECK BASE IDLE SPEED
1. Check idle speed.
700±50 rpm (in “P” or “N” position)
OK or NG
OK ' GO TO 6.
NG ' GO TO 5.
5 ADJUST BASE IDLE SPEED
1. Rev engine (2,000 to 3,000 rpm) 2 or 3 times under no-load then run engine at idle speed.
2. Adjust idle speed by turning idle speed adjusting screw.
' GO TO 6.
6 CHECK TARGET IDLE SPEED
1. Turn off engine and connect throttle position sensor harness connector.
2. Start and rev engine (2,000 to 3,000 rpm) 2 or 3 times under no-load then run at idle speed.
3. Check idle speed.
750±50 rpm (in “P” or “N” position)
OK or NG
OK ' GO TO 9.
NG ' GO TO 7.
7 DETECT MALFUNCTIONING PART
Check the following.
1. Check IACV-AAC valve and replace if necessary.
2. Check IACV-AAC valve harness and repair if necessary.
3. Check ECM function by substituting another known good ECM.
(ECM may be the cause of a problem, but this is rarely the case.)
' GO TO 9.
9 CHECK FRONT HEATED OXYGEN SENSOR LH SIGNAL
2. Set “Left bank front heated oxygen sensor monitor” in the Diagnostic Test Mode II.
3. Make sure that MIL goes on more than 5 times during 10 seconds at 2,000 rpm.
OK or NG
OK ' GO TO 12.
NG (MIL does not blink.) ' GO TO 17.
NG (MIL blinks less than 5 times.)
' 1. Replace front heated oxygen sensor LH.
2. GO TO 10.
10 CHECK FRONT HEATED OXYGEN SENSOR LH SIGNAL
1. Warm engine to normal operating temperature.
2. Run engine at approx. 2000 rpm for approx. 2 minutes under no-load.
3. Set “Left bank front heated oxygen sensor monitor” in the Diagnostic Test Mode II.
4. Make sure that MIL goes on more than 5 times during 10 seconds at 2,000 rpm.
OK or NG
OK ' GO TO 13.
NG ' GO TO 11.
11 DETECT MALFUNCTIONING PART
1. Check fuel pressure regulator.
2. Check mass air flow sensor and its circuit.
3. Check injector and its circuit.
Clean or replace if necessary.
4. Check engine coolant temperature sensor and its circuit.
5. Check ECM function by substituting another known good ECM.
' GO TO 2.
13 CHECK FRONT HEATED OXYGEN SENSOR RH SIGNAL
1. Set “Right bank front heated oxygen sensor monitor” in the Diagnostic Test Mode II.
2. Make sure that MIL goes on more than 5 times during 10 seconds at 2,000 rpm.
OK or NG
OK ' INSPECTION END
NG (MIL does not blink.) ' GO TO 16.
' 1. Replace front heated oxygen sensor RH.
2. GO TO 14.
14 CHECK FRONT HEATED OXYGEN SENSOR RH SIGNAL
3. Set “Right bank front heated oxygen sensor monitor” in the Diagnostic Test Mode II.
OK or NG
OK ' INSPECTION END
NG ' GO TO 15.
15 DETECT MALFUNCTIONING PART
3. Check injector and its circuit. Clean or replace if necessary.
' GO TO 2.
16 CHECK FRONT HEATED OXYGEN SENSOR RH HARNESS
1. Turn off engine and disconnect battery ground cable.
2. Disconnect ECM harness connector.
3. Disconnect front heated oxygen sensor RH harness connector.
4. Check harness continuity between ECM terminal 50 and front heated oxygen sensor RH harness connector.
Continuity should exist.
OK or NG
OK ' 1. Connect ECM harness connector.
2. GO TO 18.
NG ' 1. Repair or replace harness.
2. GO TO 9.
17 CHECK FRONT HEATED OXYGEN SENSOR LH HARNESS
3. Disconnect front heated oxygen sensor LH harness connector.
4. Check harness continuity between ECM terminal 51 and front heated oxygen sensor LH harness connector.
OK or NG
2. GO TO 18.
2. GO TO 9.
18 PREPARATION FOR “CO” % CHECK
1. Disconnect engine coolant temperature sensor harness connector.
2. Connect a resistor (4.4 kW) between terminals of engine coolant temperature sensor harness connector.
' GO TO 19.
19 CHECK “CO” %
1. Start engine and warm it up until engine coolant temperature indicator points to the middle of gauge.
3. Check “CO” %.
Idle CO: 1.5 - 9%
After checking CO%,
a. Disconnect the resistor from terminals of engine coolant temperature sensor.
b. Connect engine coolant temperature sensor harness connector to engine coolant temperature sensor.
OK or NG
OK ' 1. Replace front heated oxygen sensor LH.
2. GO TO 10.
NG ' GO TO 20.
20 DETECT MALFUNCTIONING PART
1. Connect front heated oxygen sensor harness connectors to front heated oxygen sensors.
2. Check fuel pressure regulator.
3. Check mass air flow sensor and its circuit.
4. Check injector and its circuit.
5. Check engine coolant temperature sensor and its circuit.
6. Check ECM function by substituting another known good ECM.
' GO TO 2.
Aug 17, 2008 | 2000 Nissan Xterra
Blinking Green Light
Here's what I could find on the your error code:
A blinking clean light that flashes 7 times and cannot be reset, occurs when the electronic control does not detect a water temperature increase during the main wash. This could be an indication of a failed heating element, in line thermostat, electronic control board and/or wiring. This problem can also occur if the main wash pump becomes clogged and it not spraying sufficiently. I hope this helps you.
PS A faulty door latch can also cause this error code.
Jun 23, 2008 | Dishwashers
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
