Question about Creek 5350SE Amplifier
Some weeks ago while I was listening to the Tuner there was a minor "bang" from the Amplifier with strong smell of burning from the ventilation grill. It was unusable after that. I have had it for 5 years.
    Brigadier General:
  • 8,546 Answers
Clearly it had a traumatic event.
Maybe open it up and sniff for burnt components, but even if you see something obvious and replace it you might not know what the original cause for failure was, so you may just be wasting time and sacrificing new parts.
I
Posted on Apr 04, 2011
Burning smell coming from engine, so strong it is inside the car. Got an oil change about 70 miles ago two weeks ago. It has been burning through oil pretty fast though lately. The smell is like a...
Have you checked the oil,checked to see if dipstick and fuel cap are tight.Do you have oil spots on driveway? Those are the first things I would check,if oil is on driveway is it coming from the oil pan.It 'seems" it May be tied in with the oil change from 2 weeks ago
Mar 05, 2015 | 1999 Subaru Forester
Cadillac allante problems
you need to examine the quality of your automatic transmission fluid for any sign of burning, or metallic content. if the fluid is not a bright, clear red, without any greyish residue or strong smells, then your transmissions torque converter is likely in need of an overhaul, although, simply changing the transmission fluid may work as a temporary fix.
Jul 23, 2014 | Metra 70-1856 1990-1996 Cadillac Into Car...
I got a toaster about a year ago and a couple weeks ago it would start smoking and smell like burning plastic whenever I used it. My dad's a cheapskate and won't get a new one so I kept using it and now...
Please stop using this thing. You are working with deadly voltages and a very high risk setting your house on fire.
Keep in mind, if the thing starts to burn you can't use water to put the fire out.
The heating element must be broke lose of its settings, or someone dropped his or her toothbrush in the apparatus. Never try to repair kitchen equipment when it is connected. Not even when you think it is switched off.
Oct 30, 2013 | Washing Machines
Tuner does not work on my Tuner Amplifier
Check to see if the antenna is loose. Most amplifiers will mute the output if they don't detect a strong radio signal.
Jul 26, 2013 | Televison & Video
I have a 95 GT , I bought the car not to long ago knowing it had minor issues , tune up brakes and clutch , I started with the tune up because the car was banging out at a low rpm and running strong at a...
Check compression on each cylinder. This will eliminate a head gasket problem. Also see if you can get a noid light and make sure all of your injectors are firing properly.
Jun 17, 2013 | Cars & Trucks
Canon MP750. It was turned off when a strong smell of burning plastic got my attention, and it was quickly unplugged. Now dead. major/minor problem?? Is it worth pursuing. Geoff PS unit in excellent...
i would say it has major problem. and not worth fixing as with printers parts are very hard to get and beyound expensive. however if you can get a free quote?? but i would say its had its day
best of luck
Aug 02, 2010 | Canon PIXMA MP750 All-In-One InkJet...
Maytag Neptune Dryer with strong "burned electrical wiring" smell
Sounds like the motor went out. Before trying to start it it needs to be inspected. If you are not comfortable opening up the cabinet then I would would recommend calling a service tech. If you need further assistance please let me know.
Ken
Mar 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Panasonic TV Turned it self off, humming speakers, loud bang & Burning Smell
hi there, you do have a big problem at your tv, the loud bang means a part is broken, maybe you will cost 50 % of the original price of your tv. ty
Dec 26, 2007 | Televison & Video
Strong ozone-like burning smell
Sounds to me like the motherboard inside the unit is on it's way to thermal overload. This is a common problem with this particular model. You'll smell electronics burning and one day it'll quit altogether with a burst of smoke. I had this happen to me and I traced the problem back to a faulty triac (transistor-like device) that overheated and caused the circuit board and wiring harness to burn up from excessive current draw. I repaired my motherboard with a new triac ($6) and rewired the harnesses. A cooling fan on the heatsink of the board would solve this problem.
Nov 12, 2007 | Equator EZ 3612 CEE Front Load...
121 people viewed this question
Top Creek Audio Players & Recorders Experts
 Grubhead
Grubhead
Pieter Vleeshouwers
Pieter Vleeshouwers
ray gallant
Are you a Creek Audio Player and Recorder Expert? Answer questions, earn points and help others
