Question about Canon ES290 8mm Analog Camcorder
Camcorder won't turn on... Not again!
For some reason if I don't use my camcorder for about a year, when I decide to want to use it, it just won't turn on. What's the deal? I'm getting sick of this.
  • 101 Answers
Batteries Batteries,
When u know you are gonna use the corder for a long time, you need to ensure that the battery is fully discharged.
If you store it in a charged state the battery looses it ability to hold power
Posted on Aug 05, 2008
Won't turn on
I had this same problem! Scoured the web and found no solution. This is what I did to fix it...
Remove battery. Unplug charger. Press and hold the power button for 20 - 30 seconds. While still holding the power button, re-insert the battery and/or plug in the charger. Voila! Came back to life and worked like nothing ever happened.
I also did the same thing with the record button, but it was the power button that got the result.
Hope this helps!
Feb 29, 2012 | Toshiba Camileo S30 HD Camcorder -...
My sony handycam dcr-hc21 won't respond to touch on the touchscreen anymore. I can't rewind, play, etc. I also don't know where the reset button is on this model, or how to calibrate. ...
This is usually caused by a defective LCD module or a defective flex cable that connects the LCD to the camera. I recommend replacing them both at the same time. The LCD / Touchscreen module is no longer available from Sony at a reasonable price for this Model. However, I have a limited supply of them in stock as well as an aftermarket supplier with hundreds of them.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have it repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Oct 25, 2011 | Sony Handycam DCR-HC21 Mini DV Digital...
I have received as a gift a Canon FS300 Digital Video Camcorder . The first time I used it, I followed instruction on how to charge the battery with CA-570 Compact Power Adapter which was included. It wok...
Hi!
Almost sure there is nothing wrong with your battery, charger and camcorder.
The battery loose power even when doing nothing, especially when it is a NiMH type.
Please charge the battery for a couple of hours and try again to start the camcorder.
Aug 09, 2011 | Canon VIXIA FS300 Flash Media Camcorder
I have a Cannon Camcorder and the cassette won't eject out
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair the tape mechanism and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Jun 23, 2011 | Canon ZR40 Mini DV Digital Camcorder
I have had my camcorder for about 2 years, it worked just fine and then all of a sudden the word "DEW" popped up and then it automatically turned itself off. So I turned it off and inserted a...
Doesn't matter where it is, if it detects moisture it will give that warning. Try putting it in the airing cupboard (NOT in its case) for twenty four hours.
Mar 12, 2017 | Sharp Viewcam VL-Z5U Mini DV Digital...
Problem with sony ccd tvr208
CCD-TRV208E is analog Sony Handycam and I think tape was recorder on Digital Handycam.
Digital handyacam model starts with letters DCR-xxx so locate a digital handycam to get tape recordings.
I got this idea when you said, only getting crackling noise and blue screen.
Jan 31, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Fix my camcorder
put your camcorder to your ear closely & turn it on - if you don ' t hear a whirring sound ? ( or instead sounds like a slinky toy ) your tape is wrapped around the heads and the protect circuits are trying to save the tape ; - - moisture can cause this problem if the camera was not in dry or air conditioned environment ( or was left in a car trunk , etc . ) removing a stuck tape is fairly easy but should only be attempted in a clean , dry environment ( if your heads are accidentally damaged , the repairs will be fairly expensive ) ;
Jul 26, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
No power after charging a new battery
Bummer, especially after getting a new battery. Based on what you have described, it appears that there is something definitely fubar with the camcorder. Only thing is that you have to decide if a repair on the unit is cost effective. Given the high price of proprietary parts and labor it might be better for you to just go shopping and walk away from this unit.
Apr 08, 2017 | Canon Optura MVX3i Mini DV Digital...
Camcorder to Mac Sony dcr-hc32
Maybe this FAQ will help ya? Problem: Camcorder will not connect to iMovie - No camera attached Possible Solutions: * Are you using a 4 to 6 pin firewire cable? That is the ONLY thing you can use. No USB cables or anything else * Are you using a compatible camera? Still cameras that take movies are NOT a DV camera * How new is the cable? If it is pretty old or you have kinked, it you may need another one * Is the camera in DV mode? It should be. (Usually in the menu options somewhere) * Have read ALL of Apples help topics on this If your good with all the above: 1. Close iMovie 2. Delete all iMovie plist files for iMovie located in Home/Library/Preferences 3. Plug the camera in to the wall (electricity) 4. Make sure you have a good firewire cable and plug it in to the Mac from the camera 5. Turn off your camera 6. Reset your pram 7. When the Mac is booting, power on the camera 8. Start iMovie Sony camcorder special fixs: 1. Turn your camcorder to Play mode. 2. Press menu button (or relevant touch-screen button) 3. Click the 'ETC' item and then to CONTROL. 4. Select i-link (and not IR). or 1. Turn your camcorder to Play mode. 2. Press the Menu button (or relevant touch-screen button) 3. Scroll down the Menu to the 'ETC' option, if there is one 4. Click the 'ETC' item and choose 'VIDEO EDIT' if it's there 5. Click 'VIDEO EDIT' and 'MARK 1 IN' may appear 6. Click on 'MARK 1 IN' and then exit from the Menu options, by pressing the Menu button again Your Sony cam should now work OK with iMovie. * Reason? The camera and Mac can't decide which device is giving the FireWire instructions, and which is supposed to be receiving and acting on them. Using this sequence (above) lets the camera receive instructions from iMovie.
Sep 14, 2005 | Sony Handycam DCR-HC32 Mini DV Digital...
Can't see the DVD camcorder icon on my desktop.
No connection --- Simply connect USB cable between DVD Camcorder and PC. No power --- Simply turn on. Mode switch is not DVD mode --- Simply set the mode switch to Movie or Photo mode, not SD mode. The wrong UDF device driver, other than the one provided with the DVD Camcorder, was installed – Simply install the UDF driver that came with DVD Camcorder.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Canon ES290 8mm Analog Camcorder Logo
85 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
