Question about U-Line Refrigerator Ice Maker
U-Line Model WCM48
My icemaker will not fill water into the tray. I have checked the water supply and have made certain that the lines are not plugged . Also the inlet screen on the Valve is clean from the supply line. The ejector blades are in the upward position which I think is the correct spot when water is needed. I no longer hear the click sound when the ice maker requested water. Is this a bad Solenoid Valve or a indication that I need a new module. Any test that I can run?
  • 286 Answers
You can try to advance your icemaker by removing the white cover on your icemaker and turn the smaller gear counterclockwise to advance the icemaker. When the icemaker starts wait until the ejector blade gets to 10 oclock position this is where it calls for water. The test would be unplug the coil on the valve and put a meter lead on each one. If you see 120 volts then replace the valve. If you dont see it it could be the water switch inside the head of icemaker.
Posted on May 18, 2009
Troubleshoot SAMSUNG ICEMAKER FOR REFRIGERATOR AND FREEZER UNIT BELOW NEITHER IS FILLING WITH WATER?
do u have a K i N K in hose somewhere do you have water in the line they have that little blue pump make sure you are getting power to it and have a ground ,
Dec 02, 2014 | Samsung RF265AA Bottom Freezer French Door...
Tip
How to repair an ice-maker of a refrigerator
An icemaker receives water through a small, 1/4-inch water supply line that runs from the refrigerator to a water pipe, where it is connected by a tap valve. The water supply line enters a valve in the refrigerator that is controlled by an electric solenoid that sends water through a fill tube into a mechanized icemaker assembly. There, the water freezes and is dumped into an ice bin. When the bin is full, the ice lifts a bail wire that turns off the icemaker. If the water’s route is blocked or the solenoid doesn’t work—or if the bail wire is lifted—the icemaker won’t make ice. (Also note that your home’s water pressure must be strong enough to serve an icemaker.)
Here are a few steps you can take to get your icemaker working (be sure the bail wire above the ice tray is in the down position):
1) If the icemaker doesn’t make ice but you can see the arm swing into motion and you hear a buzz for about 10 seconds after it is finished, the water valve is asking for water that isn’t arriving. This means the valve and the solenoid are probably okay, but the water supply is not. Be sure the water supply line isn’t kinked behind or beneath the refrigerator (1/4-inch copper tubing is much better than plastic fill line).
2) Check to see if something has caused ice to back up around the mechanism—this can cause the fill tube to freeze, blocking the mechanism. When ice cubes are small and seem to be getting smaller, it generally indicates a frozen fill tube.
3) Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, unscrew the copper line from the back of the refrigerator, put the copper line in a bucket, turn on the valve, and see if pressurized water pours out.
4) Check the tap valve; a bad tap valve may cause the problem where the icemaker’s supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the “self-piercing” type). You can do this yourself, or call a repairperson or plumber to install an inline water filter when replacing the valve.
5) The water line attaches to a solenoid at the back of the refrigerator and then travels to the icemaker. The solenoid may be defective or may not be receiving power. You can try removing the sediment screen inside the solenoid and flushing it with water to clean it, and at the same time you can inspect any seals or diaphragms to ensure that they are sound. Unplug the refrigerator first. Unless you’re skilled at home repairs, this job is better left in the hands of an appliance repairperson.
on Sep 02, 2010 | Refrigerators
MY ICEMAKER IS NOT GETTING WATER IN THE FILL TUBE IN THE BACK OF FREEZER
HI .IF WATER SUPPLY IS OK CHECK ICE LEAVER FIRST.IF ON THEN CHECK VALVE.IF OK CHECK ICE MACHINE ICE TRAY.FILL UP WITH WATER IF EMPTY.IF NOT THEN IT COULD BE YOUR ICE MACHINE .GOOD LUCK ali
Jun 24, 2012 | Hotpoint Refrigerators
I moved my GE TFX277PFSB (new in 1994) side by side to my enclosed sun porch 2 years ago when i got a new fridge for the kitchen. Today, I decided to run a water line to it to allow it to make ice again. ...
Make sure the arm on the icemaker is in the down position,if it is up and locked in place the icemaker is off. If it is down and the icemaker is turned on,each time it got cold enough the to cycle the icemaker(usually about a hour) the icemaker started and for 7 years power was sent to the water inlet valve to fill the icemaker and the icemaker side of the water valve is burnt up. The water valve has 1 inlet teh house water supply attaches to and 2 outlets 1 for icemaker and 1 for door dispenser
Gene
Aug 07, 2011 | Kitchen Ranges
I changed the water inlet valve on my roper refrigerator, plugged the refrigerator in but the water did not fill into the ice-tray. Does this mean that the icemaker if bad? or is it something else?
Check the inlet line from the back of the icemaker to the tray. It is probably frozen up. Take a warm bowl of water and with a towel take the warm water and try to thaw the line to allow water to flow through the line to the tray. This happens when flow is restricted to the tray or water is not flowing due to being shut off. It will settle in the line and freeze.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 10, 2011 | Refrigerators
Have viking side by side referagator , freezer model # ddrb304. I installed copper line to ice maker yesterday It is not making ice. Checked that water supply is on. Appreciate any suggestions Lou
make sure you have strong water pressure to the frig.
Do the ice maker have a shutoff arm? or a shutoff switch? either way make sure it is on. by now there should be water in the icemaker tray. if not then manually pour 1/2 cup of water into the icemaker. if it does make ice then replace the water fill valve.
if there is ice still in the ice maker tray you still have to check the water fill valve before we can say the icemaker doesn't work.
need a meter to check the continunity of the water vavle. if the valve is open repalce valve, if there is continunity the the valve is good.
hope this is helpful. if you cant do this ask a friend who is an electrician to help you
Mar 27, 2010 | Freezers
Icemaker not producing ice
you need to troubleshoot the problem, if the wire arm that tells the ice maker to stop making ice when full is in the upright position the ice maker will not make ice. the problem has to be either the switch on this arm malfunction. but probably in MOST cases it is your electronic water valve which has gone out. this is located on the water supply line on the back of the fridge at the bottom probably behind some cardboard or plastic. it is the same kind of water valve as a dishwasher uses, if it malfunctions it will not deliver water to your tray, manually fill the tray and put the arm down, if the maker dispenses the ice out of the tray, chances are your electronic valve is broken.
Apr 07, 2009 | Whirlpool ED2FHEXN Side by Side...
Fill doesn't shut off on Model WCM48
If it is just dribbling then chances are that there is debris in the fill vale preventing it from closing fully. Since it does not seem to flush out on its own then a new valve will likely solve your problem.
Jul 28, 2008 | U-Line Refrigerator Ice Maker
Replace the thermostat or temp control
I found out that it just pulls out. It was a little corroded, which was why it was hard to come out. Also, when it was installed it was not very straight, which made it bind. Thank you.
Jun 26, 2008 | U-Line Icemaker
U-Line Refrigerator Ice Maker Logo
179 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
