Question about Sony Televison & Video
I have a Sony Bravia KDL X2000 The channel selector changes the number at the top of the screen but the channel doesn't change as it used to I can change the channel using the menu Have I just sat on the remote and set something differently or has something gone wrong with the TV ?
  • michael229 Apr 07, 2011
    I managed to fix the problem by un-pluging the TV overnight
    Thanks
    Michael
  • 10,594 Answers
Please intimate complete model number of Sony tv.
Is it connected with cable direct from wall or cable box, I need to know connection setup as how tv gets tv channel signals to provide you helpful info to solve the problem.
Thanks.
Posted on Apr 04, 2011
Hi my sony bravia kdl-46v4100 model is decresing sound before i use 20% volume to hear it but now i use 40% of volume. What should i do? Can you guys help me? Thanks!
It's probably a station channel, channels broadcast different picture and sound quality, therefore when changing channels this can be noticable. It is probably not a tv problem.
Jul 02, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Can not change the channels on my Sony Bravia KDL-46V3000. The remote will turn the TV on and off but will not change the channel.
Is this the original remote or a universal remote? Can you change the channel with the buttons on the right side of the TV?
Can you type in a channel number and go to that channel? (this applies if the channel will not change with the buttons on the TV.) Try to rescan the channels (it could be that the TV has the other channels hidden (or lost the list).
If it is a universal remote, you may not have the correct code (just a close one). Try additional codes for Sony TVs. Also when was the remote built? If it was programmed more than 6 months before the TV was released, then it will not have the correct codes. You would need a newer remote. A substitute remote can be obtained from https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?sessionId=4q4-Cd8shqFs_c5rcVcD_Lw or http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=KDL-V32XBR1&uuid=12842263276080 .
I hope this helps.
Sep 11, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Sep 07, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Blue screen, have AUDIO ON ALL CHANNELS!
Make sure video cable is connected on right socket. for instance AV1. test cable box on other tv to see if it is transmiiiting picture. If so make sure your tv is tuned to cable box if using RF cable or on slected av mode where av cable is connected
Apr 07, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony Bravia KDL-46Z4100
if the line is in the same place all the time im afraid to say that is a pixel problem on your display contact sony they may offer you a replacement display or altleast a way of changing the set.
Mar 10, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony 37" Flat Panel Bravia--cant change from channel 2?
On the original Sony remote control, try typing in a channel manually. Try pressing the numbers "0-4" or "0-5," and waiting for a moment. If the channel changes, then the TV needs to be autoprogrammed. Using the SOny remote control, go into the MENU (or HOME on some Sony remotes), and look for the initial setup screen. It will walk you through the process. The process is also in the original users manual, available on the www.SONY.com website.
Hope this helps you....
Jan 05, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in changing from HD to digital channels
40X2000, both PS3 and DVD player are using a HDMI input and both flicker and loose signal fully, have to turn TV of then back on to get signal back. Sony say they have never heard this problem and replaced board. NOTHING fixed, still same problem.
Mar 09, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
59 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
