Question about Amperite Dayton Solid State Timer On Delay Time Relay
I am looking for a multi function relay similar to the Dayton (1)6A855 but with a 240vac input not 120vac input. Can you assist please. Regards Bruce Peters
1) Dayton 6A855 time delay pin timer
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=dayton+6A855&op=search&Ntt=dayton+6A855&N=0&sst=subset
Grainger owns Dayton, so you might want to contact Grainger
http://www.grainger.com/Grainger/static/help_contactus.html
1-888-361-8649
2) Time delay timers at Grainger:
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=dayton+timer&op=search&Ntt=dayton+timer&N=0&sst=subset
3) Grainger shows time-delay 8-pin 120 or 240V
http://www.grainger.com/Grainger/DAYTON-Relay-1EJN7?Pid=search
Grainger shows 11-pin 120 or 240V
http://www.grainger.com/Grainger/DAYTON-Relay-1EJN6?Pid=search
Searching for "11 pin 240Volt delay timer" turned up results:
4) Following pdf shows knob-adjustable 240V delay-on pin timer
https://www.relayspec.com/specs/020050/T1Series.pdf
5) Signaline has delay timers (800) 862-2875
6) SSAC
http://www.ssac.com/standard/ff-tdr1.htm
7) Another pdf with 240V delay pin timers
http://www.askco.com/pdfs/tdd_tud_data.pdf
8) Not wanting to say what already know, but each 240V circuit is made from two out-of-phase 120V lines. Any 240Volt Load can be turned OFF by turning off one of the 120V lines. In this way, the Dayton 120V timer can be used to control 240V load.
Also the 120V Dayton can operate 120V double-pole contactor, and then the contactor controls 240V Load.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html#contactor
Posted on Apr 04, 2011
Where is the body control module located on 2002 cadillac deville
The body control system consists of the following 3 modules:
• The Dash Integration Module (DIM)
• The Instrument Panel Module (IPM)
• The Rear Integration Module (RIM)
Each of the 3 body control modules integrate a number of functional systems under the control of a single module. Each module is connected to the Class 2 serial data circuit, many of the control functions are implemented by Class 2 messages.
What system (S) are you having problems with ?
The various RIM inputs and outputs are described in the corresponding functional areas as indicated on the RIM electrical schematics.
The RIM functions include the following:
• Automatic level control
• CIGAR relay control
• Class 2 communication requiring RIM interaction
• Content theft deterrent
• Fuel door control
• Fuel level sensor input
• Heated seat control
• HVAC blower control
• LK/CYL relay control
• Park brake relay control
• Rear defog relay control
• Rear park assist chime control
• Retained accessory power (RAP) relay control
• Reverse relay control
• Transmission shift inhibit
• Trunk release relay control
• Various controls for the interior lamps
Instrument Panel Integration Module (IPM)
The various IPM input and output circuits are described in the corresponding areas as indicated on the IPM electrical schematics.
The IPM functions include the following:
• 54 volt VF display input
• Ambient light sensor input
• Class 2 communication requiring IPM interaction
• Fog lamp switch inputs
• Front HVAC air delivery controls
• Front HVAC sensor inputs
• Front HVAC temperature controls
• Fuel door and rear compartment lid release switch input
• Hazard switch input
• HUD active control
• Instrument panel lamps dimmer switch input
• Ignition switch headlight control
• Interior lamps switch input
• Key in ignition switch input
• Traction control switch input
• Twilight sentinel delay input
The various DIM input and output circuits are described in the corresponding functional areas as indicated on the DIM electrical schematics.
The DIM functions include the following:
• Class 2 communication requiring DIM interaction.
• Control of exterior lamps.
• Control of front fog lights.
• Control of the headlights.
• Headlamps on with wiper input.
• Hood ajar switch input w/export.
• Horn relay control.
• Interior lamps incandescent dimming.
• Low side temperature for HVAC compressor.
• Power moding control over Class 2 serial data circuit.
• Reverse lockout solenoid control.
• Steering wheel controls input.
• Storage of the clock settings and, sending a message out on the class 2 serial data circuit in response to requests from other modules.
Jun 19, 2017 | Cadillac Cars & Trucks
Interior lights and door locks not working
The central element here is not a relay but the multi-function alarm lock & lighting (MALL) module. You indicate the 20A fuse in the relay center is OK. The MALL also receives BAT power through 15A CTSY/PWR MIR FUSE 6A and IGN input through 15A IGN CHIME/CLSTR FUSE 10 in the I/P fuse block. Voltage from 20A SIG/BU/LP BTIS/CCR FUSE 18 in the I/P fuse block passes through the park/neutral position switch in PARK position to supply PARK POSITION INPUT to the MALL. All of these inputs are required for the MALL to function correctly.
Apr 21, 2014 | 1996 Oldsmobile 88
I need to know what to set my dials/sttings on 1EJE8 Dayton Timer. What I am trying to do is sound an alarm when I hit reset the timer shuts off the alarm for twenty min before resounding
Question is unclear.
Help me break it down.
You want to push a button and sound alarm?
And then you want alarm to sound until you push button again?
And then you want timer to delay 20 minutes before sounding alarm again for an unknown amount of time?
What is the reset?
Add a comment and say what control you have wired to the timer and a clear 1-2-3 sequence of events and times for possible help.
1EJE8 is 10-function timer, and no manual appears on the internet July2011.
Magnecraft has same-similar timer, the 820 series.
Open following link for detailed manual with illustrations.
http://www.serelays.com/library/section5/105A_820_Series.pdf
Jul 14, 2011 | Amperite Dayton Solid State Timer On Delay...
To palaboy: when you talk about a switch on the left most terminals, you mean with this switch im enable the timer???
Question is not clear.
You posted about Dayton on-delay timer?
This timer has two contacts, and wires similar to a light switch.
Connect 120V power to terminal 1
Connect wire going to load to terminal 3
Maximum Load is 1 amp so this timer should be wire to a contactor/relay and not directly to Load.
If you have Dayton off-delay timer, open following link for wiring diagram, and to see examples of contactors:
If you have a different timer, then add a comment with clear description of timer or in-focus photo of timer posted on Flickr
Jul 11, 2011 | Amperite Dayton Solid State Timer On Delay...
How do you connect up to the dayton ssr 1EGH8?
Wiring diagram is not found on internet for that device
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=dayton+1EGH8&op=search&Ntt=dayton+1EGH8&N=0&sst=subset
Contact WW Grainger for information.
Grainger owns Dayton.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service cal
Mar 26, 2011 | Amperite Dayton Solid State Timer On Delay...
Both headlights quit working simotaneously
There are just (3) possible reasons for this:
(a) your headlight switch has failed, or
(b) your headlight relay has failed.
(c) Fuse 1 (25 Amps) has blown
The headlight relay and fuse 1 are located (I think) in a fuse/relay block under the hood.
The headlight switch is part of the "Multi-function Switch" on the steering column.
Here's how to replace the 2001 PT Cruiser multi-function switch:
Multi-Function Switch Removal & Installation
1. Open the hood.
2. Disconnect and isolate the battery negative cable.
3. Remove both upper and lower steering column shrouds.
4. Disconnect both posi-lock harness connectors at the rear of the multi-function switch.
5. Remove multi-function switch mounting screws and remove switch from vehicle.
To Install the new multi-function switch:
Note:
If replacing the multi-function switch, the combination flasher and windshield wiper/washer switch
must be transferred to the new multi-function switch.
1. Remove the two Torx(R) screws retaining the wiper/washer switch, place next to the new
multi-function switch and install two screws.
2. Place switch into place and install mounting screws. Torque multi-function switch to column
retaining screws to 27 inch-lbs. (3 Nm).
3. Connect both posi-lock harness connectors at the rear of the multi-function switch.
4. Install both upper and lower steering column shrouds.
5. Connect the battery negative cable.
6. Close hood.
7. Verify vehicle and system operation.
Mar 15, 2011 | 2001 Chrysler PT Cruiser
Can't locate parts for DAYTON 4LX45
Hi google dayton heater spare parts then look at pronto .com they do spares
Feb 10, 2010 | Dayton (4LX41) Heater
Maytag Neptune FAV6800AWW Top Loader will not turn on. Power outlet is operable HELP
Hi Sandra,
I assume you have no LED’s lit when you raise and lower the washer lid or press a Wash Cycle or Spin Only cycle. This may not be an easy fix but this how I would proceed to troubleshoot.
From the machine schematic I see no fuses or circuit breakers in the machine that could cause loss of 120VAC distribution to the washer Control Board or other relay inputs. This is what I can tell from washer schematic. 120VAC comes into the machine passes thru and EMI filter is then distributed to the Control Board for +12VDC and +3.3VDC generation and 120VAC distribution to the main system relay, motor control board, drain pump, door locks/unlock solenoid and so on. I would start looking with my DVM to see if I had 120VAC at connector P6-1 the L1 (120VAC) input to the control board referenced to P6-3 or 4 the 120VAC neutral connection. If you have 120VAC at those points I would look to see if I had +12VDC power generated by the control board +12VDC power supply.
+12VDC could be measured at the Control Board Conn P3 Pin 3 or 4 referenced to Control Board common Conn P3 Pin 1. If there was no +12VDC generated by the Control Board I would replace the control Board and see if that restores normal operation. What I’m describing is the troubleshooting path I would take as an electronics technician. If you call in a repair service run my suggestion by them and see what they would suggest. I would make sure they bring out a Control Board for your machine. The Control Board has a 5 yr warranty. They will need your model number which you have and the serial number of your machine. The s/n is located on the back right side of the console. I will attach a couple links for reference. The Service Manual link has Maytag warranty contact info.
Let’s also see if another forum member can offer a solution to this issue that I may be overlooking.
The Service Manual for reference. Sears Parts Direct for reference.
Good luck and let us know if you have additional questions.
Rich
Oct 12, 2009 | Maytag Neptune FAV6800AW Top Load Washer
1997 Ford Aspire Low/High beam headlamps not working
---------- HEADLAMPS Condition Possible Source Action
  • Headlamps Inoperative
  • Fuse.
  • Headlamp relay.
  • Circuit.
  • Multi-function switch.
  • Headlamp bulbs.
  • GO to Pinpoint Test A1 .
Headlamp Relay
  1. Key OFF.
  1. Remove the headlamp relay.
  1. Using a jumper, connect terminal C159-1 and terminal C159-2 on the headlamp relay to the battery positive terminal
    Pin Number Circuit Circuit Function C159-1 7C (R) Hot At All Times C159-2 7B (R) Hot At All Times C159-3 12 (R/GN) Multi-function Switch Input C159-4 11 (R/BL) Multi-function Switch Control
Feb 19, 2009 | 1997 Ford Aspire
Dayton 3EV51 torpedo heater
Dayton heaters at one time were manufactured by DESA or a predecessor and labeled DAYTON for Grainger. I have been unable to find any specific reference material to "Dayton 3EV51".
There were 2 types of motors used. I suspect your heater has a starter relay. The solid state relay was used to allow the energizing of the start winding which would allow the motor to achieve approx 80% of rated speed, then the relay would de-energize the start winding to prevent overheating. The relay is not attached to the motor, except for the wiring.
5ef4624.jpgThis is what the starter relay looks like. If yours has one check to see if it is energizing the starter windings at start-up. If not it is probably defective. The part is still available at www.reddyparts.com, I think, but today's replacement part looks slightly different.
If your motor does not have the relay, then the motor has an internal start-up system which is not serviceable, but the motor is probably still available. Most of the time the motor's part number is printed on the label.
Oct 11, 2008 | Dayton E51 Oil Filled Utility Heater
Amperite Dayton Solid State Timer On Delay  Time Relay Logo
818 people viewed this question
Top Amperite Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you an Amperite Hardware and Accessory Expert? Answer questions, earn points and help others
