Question about Apple Power Mac G5 Desktop
I need to replace the battery for my apple iMac G4 Powermac.
  • 3,400 Answers
Go to Apple.com -> support - they have step by step instructions.
Posted on Apr 04, 2011
Power mac g5 shows terrible damage in tower from leaking they swear mom board is fine but its hard to believe. are any of the other parts usable for a g3 to g5 imac or g4 powermac or emac
None of the parts are usable in any other machine.
The coolant from a liquid-cooled G5 PowerMac is toxic. If your G5 is leaking, disconnect the power cord IMMEDIATELY. Flush any skin exposed to the fluid with water for at least 15 minutes.
If you want to glove up and extract your hard drive from the machine so as to save your data, do it carefully. Other than that, my recommendation is to bag up the unit and handle it responsibly as toxic waste, using the same guidelines your area uses for antifreeze.
Oct 31, 2010 | Apple iMac G4 Desktop
I want to reboot my powermac g4. i have the startup disk i dont kno wat to type at the black screen
All you should have to do is put in disk and powermac should start from it, if not then replace the pram battery and try again. The battery is on the motherboard and can be bought at any radioshack.
May 01, 2010 | Apple Power Mac G4 Desktop
Powermac g4 shut down
OK it's a G4 iMac.
Burning smells coming from macs often indicate a failure in the power supply module. That said, the G4 iMac (in my experience) has been the most reliable iMac ever and power module failures are very rare.
Your best option is to find a Mac repair centre near you and take in in for a quote. But be warned - it will cost. For some reason known only to Apple power supply modules are expensive (but not as expensive as the equivalent volume of HP ink) and replacing them is not as easy as on many of the other computers.
If it is the power supply, you will not be able to switch it on again. Your data on the HD should be safe (unless the smell was coming from that - - I've had it happen!). So when you get to the workshop and you've had your quote, if you decide not to go ahead with the repair, ask the workshop to remove your HD and put it into an external case so that you can plug it in to another Mac and continue using it.
Let us know what the outcome is.
Oct 07, 2009 | Quicksilver Power Mac G4 (Quicksilver)
Imac g4 lcd black screen replaced pram battery
If you can find an older SVGA monitor, try hooking it up to the port on the back of your mac. If you get video then chances are the LCD display is shot.
Sep 01, 2009 | Apple iMac G4 Desktop
Transferring software and files from PowerPC G3 to PowerMac G4
to mount somthing in a mac is basicly cutting it on for use.
For example if you instal a flash drive or an hard drive via an out side connection, The mac will mount it so you can use it.
Aug 09, 2009 | Computers & Internet
Imac g5 ejecting dvd/cd media
most likely, your dvd burner lens is burnt out(they make the darn things out of plastic!). Just happened on mine. you have to either replace the drive or get an external. There are do it yourself instructions on Apple's website for replacing the drive.
Not all drives are compatible...must be slot loading and I read that it has to be set to master so you can potentially boot from CD's in this drive.
Jan 02, 2009 | Apple Wired Mediapress X SDI MPEG Encoder...
Powermac g4 will not turn
this is a common problem with G4 Quicksilver. Your power-supply is defect and has to be replaced. I have 4 G4s in my lab with the same symptom: a short flash of the power-button light, sometimes it turns on, but mostly the machine is dead.
Richard
May 07, 2008 | Apple Power Supply 344 Watt PowerMac G4...
Need User or Owner's Manual for Mac PowerPC G4
Mac help is built into the operating system on your computer. There really aren't any paper manuals for them. Here is a link to Apple's web site that should get you started: http://www.apple.com/support/imac/g4/
Dec 28, 2007 | Apple Macintosh Server G4
Apple Power Mac G5 Desktop Logo
63 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
